2004 8p a3 abs code 01044 - Control Module Incorrectly Coded
Jphowden
C?ID=167785
Hi i have been working on a car that has been to various garages to try and solve his issues and i am only left with the abs fault now 01044 - Control Module Incorrectly Coded - 003 mechanical failure.
this code is confusing me, coding and mechanical failure dont add up to the same fault to me.
i cant get any useful info from the owner as he doesnt know whats been done other than a steering rack was fitted.
Can anyone confirm what the fault is? is it possibly the wrong wrack fitted or coding that has been messed around with?
thanks in advance
Mark
Tuesday,30,June,2020,11:01:11:21450
VIN: WAUZZZ8P74A100872   License Plate: SW53FWF
Mileage: 247720km-153926mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56
VIN: WAUZZZ8P74A100872   Mileage: 247720km-153926miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CA    HW: Bas isX 3
   Component: MOTRONIC ME7.1.1    5629
   Revision: 00000000    Serial number: AUX7Z0C9FNE0FL
   Coding: 0000172
   Shop #: WSC 06435 000 00000
   VCID: 4CC198508ACE2BCBFFA-8018
Readiness: 0110 1001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No: 1K0 907 379 E
   Component: ESP ALLRAD MK60     0103
   Coding: 0021122
   Shop #: WSC 00046 000 00000
   VCID: 3431E0B0F23E530B87A-8060
            003 - Mechanical Failure
   Part No SW: 8P0 820 043 F    HW: 8P0 820 043 F
   Component: KlimavollautomatH12 0150
   Revision: 000816      Serial number: 8P0820043F
   VCID: 2F3BEFDC1B1870D3FA8-807A
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 184
                    Mileage: 245703 km
                    Date: 2019.12.24
                    Time: 19:15:12
                    Temperature: 12.5°C
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H29 0501
   Revision: 00029000    Serial number: 00000000301201
   Coding: 018C4F01A0141000000000000000000000
   Shop #: WSC 00000 067 57207
   VCID: 3B23CB8CDF609C73460-806E
   Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00064784
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
   Component: Airbag 8.4ED    H01 0130
   Coding: 0411602
   VCID: 45D7AD74A9A4DA83204-8010
   Part No SW: 1K0 953 549 AM    HW: 1K0 953 549 AM
   Component: J0527           037 0071
   Coding: 0001012
   VCID: 7DA7059481F45243384-8028
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 980 J    HW: 8P0 920 980 J
   Component: KOMBIINSTR. VDO H25 0110
   Revision: D07         Serial number: 2249CD07003225
   Coding: 0014403
   Shop #: WSC 00861 067 57207
   VCID: 3E25C298CC72895B61E-806A
   Part No SW: 1K0 907 530 B    HW: 1K0 907 951
   Component: Gateway         H08 0090
   Revision: 08          Serial number: 24001039166772
   Coding: BD0F0342070101
   VCID: 26150AF834E2319B09E-8072
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3635DAB8E442411BB9E-8062
   Revision: D07         Serial number: AUX7Z0C9FNE0FL
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: 392FD184D55CAE6354C-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.5       1202
   VCID: 2E05F2D81C1279DBF1E-807A
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433
   Component:    KSG          H02 0040
   Coding: 008800186D288505485AC63000
   VCID: 79AF118495DC6E6314C-802C
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH23 0100
   Revision: 00001       Serial number: 10000001076878
   VCID: 70B92CA0C6A62F2BA32-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
   VCID: 3A2DCE88D05AA57B5D6-806E
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 195     HW: 8P0 035 195
   Component: symphony II EU  H55 0400
   Revision:      19S    Serial number: AUZ5Z4C5337409
   Coding: 0001001
   VCID: 6FBB2FDCDB9830D3BA8-803A
End----------(Elapsed Time: 00:58, VBatt start/end: 12.0V/12.1V)-----------
Try:
0021128
0021190
Jphowden
C?ID=167785
Try:
0021128
0021190
Thanks for getting back to me, i have checked the rack that was fitted and the part numbers don't seem to match up to what should be on the vehicle so ive sent him back to the original garage to get that changed to the correct part.
if i don't come back to post anymore info the rack was the issue, if not ill be back to update
