Just bought this car with timing chain tentioner issues, but decided to yank motor and solve any known problems' (pistons, rear seal etc.)
Put it back in and it seems to run just fine, but shows many codes! (even though I erased them)
Could it be that I need to set the readiness? And if so, could someone steer me in the right direction?
Thanks!
Thanks!
Sunday,28,June,2020,08:13:44:08677
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUEFAFL9BN001856 License Plate:
Mileage: 176890km-109914mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
77
VIN: WAUEFAFL9BN001856 Mileage: 176890km-109914miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H17 0002
Revision: E1H17---
Coding: 0104010A02070160
Shop #: WSC 55548 001 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74B120CF1E3931FB473-8020
16 Faults Found:
U1113 00 [047] - -
Mileage: 176892 km
Date: 2010.01.22
Time: 00:04:55
Engine speed: 0.00 /min
Coolant temperature: 31 °C
Intake air temperature: 32 °C
Voltage terminal 30: 12.274 V
4527 - Coolant Fan Control Circuit 1
P0480 00 [032] - Electrical Malfunction
Mileage: 176892 km
Date: 2010.01.22
Time: 00:03:56
Coolant temperature: 12 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.015 V
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:56
Vehicle speed: 255 km/h
Coolant temperature: 30 °C
Intake air temperature: -40 °C
Voltage terminal 30: 7.279 V
4608 - Fuel Pressure Regulator Valve (N276)
P2294 00 [032] - Open Circuit
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:22
Voltage terminal 30: 8.033 V
9491 - Oil Pressure Regulating Valve
P164E 00 [032] - Electrical Malfunction
Mileage: 176892 km
Coolant temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 9.588 V
2670 - Throttle Position Sensor (G69)
P0122 00 [096] - Signal too Low
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:22
Voltage terminal 30: 8.128 V
2674 - Angle Sensor 2 for Throttle (G188)
P0222 00 [096] - Signal Too Low
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:22
2697 - Fuel Pressure Sensor (G247)
P0190 00 [032] - Circuit Malfunction
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:22
Voltage terminal 30: 8.080 V
2731 - Throttle Actuator (G186)
P1558 00 [032] - Electrical Malfunction
Mileage: 176892 km
Voltage terminal 30: 7.986 V
2799 - Bank 1: Camshaft A (Intake)
P0010 00 [096] - Position Actuator Malfunction
Mileage: 176892 km
Date: 2010.01.31
Time: 14:17:24
Engine speed: 206.00 /min
Normed load value: 34.9 %
Coolant temperature: 15 °C
Intake air temperature: 17 °C
Voltage terminal 30: 10.130 V
5664 - Mass Air Flow Sensor (G70)
P0100 00 [237] - Supply Voltage
Mileage: 176892 km
Date: 2010.01.22
Time: 00:05:19
Engine speed: 227.50 /min
Voltage terminal 30: 11.214 V
4737 - Signal Line for Fuel Pump Electronics
P3089 00 [096] - Electrical Malfunction
Mileage: 176892 km
Date: 2010.01.22
Time: 00:05:19
Voltage terminal 30: 11.237 V
2979 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [032] - Electrical Malfunction
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:22
4187 - Intake Air Temp. Sensor (G42)
P0113 00 [032] - Signal too High
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:24
Voltage terminal 30: 7.821 V
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [175] - Malfunction
Mileage: 176892 km
Date: 2010.01.22
Time: 00:03:56
Intake air temperature: 13 °C
4261 - System Voltage
P0562 00 [096] - Too Low
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:35
Voltage terminal 30: 8.457 V
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K1 927 155 J HW: 0AW 927 156 H
Component: 0AW 20TAVSUSA H05 0004
Revision: --H05--- Serial number: 0000000162
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMVL381 A02018
ROD: EV_TCMVL381.rod
VCID: 3B23CBF373E7BE83469-806E
2223 - Load Signal
P1857 00 [047] - Error Message from ECU
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:51
Engine speed: 100.00 /min
Transmission input speed: 1 /min
Transmission output speed: 1 /min
Engine torque: -32 Nm
Transmission fluid temperature: 22 °C
Accelerator position: 0.0 %
Clutch status: 1
Occurrence_counter_over_length_of_life: 1
8786 - Function Restricted due to Insufficient Voltage
U1400 00 [044] - -
[14 Volt Power Module System Voltage Low]
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:57
Transmission fluid temperature: 26 °C
Clutch status: 1
Occurrence_counter_over_length_of_life: 4
7052 - Internal Control Module
P0606 00 [044] - Processor Fault
[Internal Control Module Memory Check Sum Error]
Mileage: 176892 km
Engine torque: -80 Nm
Transmission fluid temperature: 12 °C
Clutch status: 1
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BH HW: 8K0 907 379 BH
Component: ESP8 front H04 0050
Coding: 080D18
Shop #: WSC 02391 823 56573
VCID: 00597C1F5A011D5B53B-8054
02214 - Tire Pressure Warning
Reset counter: 3
Mileage: 176276 km
Date: 2018.09.20
Time: 16:02:08
Hex Value: 0x5700
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1BB0
Hex Value: 0x00FF
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:46
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0032
Hex Value: 0x0279
Hex Value: 0x00FF
Fault Frequency: 31
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:47
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0038
Hex Value: 0x337F
Hex Value: 0x00FF
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:00
Hex Value: 0x0000
Hex Value: 0x1082
Hex Value: 0x0003
Hex Value: 0x2462
Hex Value: 0x00FF
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:52
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0026
Hex Value: 0x4688
Hex Value: 0x00FF
01200 - ABS Valves Supply Voltage
000 - - - Intermittent - MIL ON
Fault Status: 10100000
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:10:45
Hex Value: 0x0000
Hex Value: 0x0280
Hex Value: 0x0002
Hex Value: 0x4098
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H04 0430
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 76B51AC708C523EB797-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H50 0070
Serial number: 0510000032363018
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000078875009
Fault Frequency: 86
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:56
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:07
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:24
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Revision: C1000000 Serial number: 01190520101336
Coding: 64002000
Fault Status: 01101000
Fault Frequency: 15
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:50
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:43
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:43
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:02:41
Temperature: 1.0°C
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:23
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0380
Revision: 10029001 Serial number: 00000000677810
Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
VCID: 3C21C8EF7669B9BB4F3-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 230510 H06 0070
Serial number: SWF10050235002
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10917966
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000001505100598
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
8 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 01101100
Reset counter: 238
Mileage: 176892 km
Date: 2010.02.01
Time: 05:51:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 238
Mileage: 176892 km
Date: 2010.02.01
Time: 05:51:00
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 238
Mileage: 176892 km
Date: 2010.02.01
Time: 05:51:00
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 238
Mileage: 176892 km
Date: 2010.02.01
Time: 05:51:00
Fault Frequency: 64
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:00
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:00
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0G2LCI
Coding: 303837354230303030304A55304C384B3053
VCID: 45D7AD0B0523F87320D-8010
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R10000078RP
Serial number: 6334MSME5334540DA
Serial number: 6344MSME533317657
Serial number: 6352QSME305F20248
Serial number: 6362QSME6A603C38Q
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:45
9444115 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:45
B10B4 00 [008] - Function Restriction due to Undervoltage
[Bladder Mat: functional restriction because of low voltage]
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:36
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JEP0008M
Coding: 000016
VCID: 3D27C5EB6D73B0B378D-8068
Component: E221 - MFL H02 0010
Fault Frequency: 31
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:01
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:56
Part No SW: 8K0 920 950 H HW: 8K0 920 950 H
Component: KOMBIINSTR. H20 0258
Revision: 00100000 Serial number: EIL30TH5A
Coding: 8B1609000300D705020000
VCID: 3431E0CF5E3971FB873-8060
Fault Frequency: 75
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:31
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1052080F6
Coding: 00C303
VCID: 015F791B510B14535C5-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1001B0D6130510
Fault Frequency: 36
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:29:00
Bin. Bits: 00000
Voltage: 11.80 V
Count: 17
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:23
Bin. Bits: 00000
Voltage: 7.50 V
Count: 7
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 392FD1FB795B8C93545-806C
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:10
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:23
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C03204000410001
VCID: 53F38353FBF756C3BE9-8006
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:27
Revision: 00002001 Serial number: 0130600023
Coding: 0106023A00FA440480B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000254138
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 22
Reset counter: 238
Mileage: 170454 km
Date: 2018.04.25
Time: 08:40:14
Fault Frequency: 91
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:56
014 - Defective
Fault Status: 01101110
Reset counter: 238
Mileage: 176892 km
Date: 2010.04.17
Time: 11:52:40
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:23
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74B120CF1EB931FB473-8020
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:39
Voltage: 7.50 V
Temperature: 36.0°C
Bin. Bits: 00000010
Bin. Bits: 00000001
Bin. Bits: 00000000
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52FD8657C4ED5FCBB5F-8006
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:27
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000515428
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:02:31
Voltage: 7.30 V
Count: 44
Hex Value: 0x0170
Hex Value: 0x0082
Hex Value: 0x0101
Fault Status: 11101101
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:46
Voltage: 9.80 V
Count: 80
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:53
Voltage: 11.00 V
Count: 58
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000004
VCID: 77AB17C303CF5AE3621-8022
Fault Status: 11101010
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:13:24
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.22
Time: 00:13:24
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6J1410097
Coding: 04020002010185004359070800
VCID: 46D5AA0738A5F36B297-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 23
Mileage: 176209 km
Date: 2018.09.18
Time: 21:00:53
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:32
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:22
02983 - Connection between Impedance Converter 1 and Window Antenna
Fault Status: 00101011
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:02:32
Fault Status: 00100111
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:02:32
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C03204000210001
VCID: 56F57A47E80543EB597-8002
Reset counter: 23
Date: 2064.00.00
Time: 00:00:02
Component: TSG HR H06 1401
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:27
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005081717
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3D27C5EB6173B0B378D-8068
Reset counter: 23
Mileage: 176892 km
Date: 2010.01.22
Time: 00:01:40
End----------(Elapsed Time: 01:56, VBatt start/end: 12.6V/12.5V)-----------
Monday,29,June,2020,11:55:00:08677
77
Revision: E1H17---
U1113 00 [047] - -
Mileage: 176892 km
Date: 2010.01.23
Time: 15:32:09
Engine speed: 1204.00 /min
Normed load value: 11.8 %
Coolant temperature: 36 °C
Intake air temperature: 30 °C
Voltage terminal 30: 11.850 V
Mileage: 176892 km
Engine speed: 235.50 /min
Normed load value: 32.9 %
Voltage terminal 30: 11.402 V
Readiness: 0110 0101
2223 - Load Signal
Mileage: 176892 km
Date: 2010.01.23
Time: 15:32:09
Engine speed: 1175.00 /min
Engine torque: 8 Nm
Transmission fluid temperature: 28 °C
Clutch status: 13
Occurrence_counter_over_length_of_life: 3
Coding: 080D18
Reset counter: 239
Mileage: 176892 km
Date: 2010.01.23
Time: 15:32:09
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x0026
Hex Value: 0x4695
Hex Value: 0x00FF
Reset counter: 239
Mileage: 176892 km
Date: 2010.01.23
Time: 15:32:10
Hex Value: 0x0040
Hex Value: 0x6282
Hex Value: 0x0032
Hex Value: 0x0296
Hex Value: 0x00FF
Coding: 090100
Coding: 64002000
Coding: 00FD11
Coding: 025028
Serial number: 63732SME4A5F53200
Serial number: 63832SME445F3600.
Coding: 000016
Fault Status: 00101101
Fault Frequency: 88
Reset counter: 22
Mileage: 176892 km
Date: 2010.01.22
Time: 00:00:31
Coding: 00C303
Revision: 00000000
Coding: 020302
014 - Defective
Reset counter: 238
Mileage: 176892 km
Date: 2010.01.23
Time: 15:23:57
Reset counter: 239
Mileage: 176893 km
Date: 2010.01.23
Time: 15:44:34
Revision: S2200000
Coding: 0203010102
Reset counter: 239
Mileage: 176892 km
Date: 2010.01.23
Time: 15:32:10
Voltage: 12.10 V
Count: 58
Hex Value: 0x02E0
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000004
Component: Display
Coding: 0010370
End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.3V)-----------
