Hie mates
May you help the coding for the head unit it no long shows oil level.
Monday,29,June,2020,12:04:28:53861
VCDS Version: 20.4.1.0 HEX-NET CB: 0.4508.4
VIN: WAUZZZ8K0AA064166 License Plate: AFB 3755
Mileage: 94670km-58825mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 52 53 55
56 57 62 72
VIN: WAUZZZ8K0AA064166 Mileage: 94670km-58825miles
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (CL0MA-CDNC) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AJ HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0002
Revision: E1H15---
Coding: 0104000C240F0060
Shop #: WSC 63860 741 186740
ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
ROD: EV_ECM20AVS.rod
VCID: 77BE1F80CE1F213E3A-8022
7900 - Right Engine Mount Solenoid Valve (N145)
P1577 00 [047] - Open Circuit
Mileage: 94417 km
Date: 2009.06.27
Time: 19:22:41
Coolant temperature: 101 °C
Intake air temperature: 42 °C
Ambient air pressure: 870 mbar
Voltage terminal 30: 12.392 V
2886 - Catalyst System; Bank 1
P0420 00 [104] - Efficiency Below Threshold
Mileage: 94461 km
Date: 2009.06.28
Time: 01:05:51
Engine speed: 1703.00 /min
Normed load value: 25.5 %
Vehicle speed: 41 km/h
Coolant temperature: 98 °C
Intake air temperature: 40 °C
Ambient air pressure: 860 mbar
Voltage terminal 30: 13.853 V
Unlearning counter according OBD: 38
5671 - Boost Pressure Regulation
P0299 00 [109] - Control Range Not Reached
Mileage: 94648 km
Date: 2009.07.01
Time: 04:29:59
Engine speed: 2967.50 /min
Normed load value: 74.5 %
Vehicle speed: 94 km/h
Coolant temperature: 89 °C
Intake air temperature: 33 °C
Voltage terminal 30: 12.321 V
4060 - Cylinder 3
P0303 00 [237] - Misfire Detected
Mileage: 94647 km
Date: 2009.07.01
Time: 04:28:49
Engine speed: 2517.50 /min
Normed load value: 80.0 %
Vehicle speed: 62 km/h
Coolant temperature: 75 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.099 V
7960 - Cylinder Disabling
P130A 00 [044] - -
Mileage: 94649 km
Date: 2009.07.01
Time: 04:31:33
Engine speed: 4426.50 /min
Normed load value: 99.6 %
Vehicle speed: 110 km/h
Coolant temperature: 96 °C
Intake air temperature: 34 °C
Voltage terminal 30: 12.510 V
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [109] - -
Mileage: 94647 km
Date: 2009.07.01
Time: 04:28:49
Part No SW: 8K1 927 156 AA HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H04 0012
Revision: --H04--- Serial number: 0000000959
Shop #: WSC 50938 000 1048576
ASAM Dataset: EV_TCMDL501 A02203
ROD: EV_TCMDL501.rod
VCID: 74A4288CDF694A261F-8020
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Coding: 094508
Shop #: WSC 06325 000 00000
VCID: 7AB806B4F50D3C5645-802E
Fault Status: 00101101
Reset counter: 171
Mileage: 94345 km
Date: 2009.07.04
Time: 02:39:18
Hex Value: 0x0040
Hex Value: 0x0782
Hex Value: 0x0026
Hex Value: 0x468D
Hex Value: 0x00FF
Reset counter: 171
Mileage: 94345 km
Date: 2009.07.04
Time: 02:39:20
Hex Value: 0x0040
Hex Value: 0x2282
Hex Value: 0x0032
Hex Value: 0x0296
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0324
Coding: 051100
VCID: 0444784C87C97AA62F-8050
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000068680014
Address 07: Control Head Labels: None
Part No SW: 8T0 035 730 G HW: 4E0 035 729 C
Component: Interfacebox H41 2100
Revision: 00000000 Serial number: 337I0097518577
Coding: 0000000
VCID: 3522D5885C93132EE8-8060
Subsystem 1 - Part No: 8T0 919 609 E
Subsystem 2 - Serial number: 00000000348283
Subsystem 3 - Serial number: 0117.09.090000000100010395ÿ
Subsystem 4 - Serial number: 010395ÿ
Time Indication: 15
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01280920090862
Coding: 64046000
VCID: 76A01284C115583621-8022
Reset counter: 171
Mileage: 90490 km
Date: 2009.06.26
Time: 00:35:41
Reset counter: 171
Mileage: 90490 km
Date: 2009.06.26
Time: 00:01:15
00256 - A/C Pressure/Temperature Sensor (G395)
Reset counter: 171
Mileage: 90490 km
Date: 2009.06.26
Time: 00:39:15
Temperature: 23.0°C
Reset counter: 144
Mileage: 91967 km
Date: 2020.05.08
Time: 17:50:05
Temperature: 21.0°C
RPM: 1520 /min
Speed: 73.0 km/h
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000350685
Coding: 260010800030AF010001000000001D0D0F1D430800010141000000
VCID: 3A38C6B4B58DFC5605-806E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 220909 H05 0070
Serial number: SWF09090225272
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10607732
Coding: 025028
Component: E1 - LDS H03 0031
Serial number: 00000000000504110770
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H45 0390
Revision: 00045004 Serial number: AUZ5ZBI8882573
VCID: 2B16F3F08AD755DE8E-807E
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD05YYH6
Coding: 30373435363030303030554A3052384B3053
VCID: 41CAB158D05BAF8E44-8014
Serial number: 6334MSME4C047570C
Serial number: 6344MSME4C33712EK
Serial number: 6352QSME3C3C5738U
Serial number: 6362QSME663B3C20L
Serial number: 63732SME533C2402U
Serial number: 63832SME3E3C2F1AH
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [136] - Open or Short to Plus
Mileage: 90490 km
Date: 2009.06.26
Time: 00:35:38
9444115 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [136] - Open or Short to Plus
Mileage: 90490 km
Date: 2009.06.26
Time: 00:35:38
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IIN000DE
Coding: 000032
VCID: 3D32CDA8A4A3CB6E20-8068
Part No SW: 8K0 920 930 B HW: 8K0 920 930 B
Component: KOMBIINSTR. H20 0255
Revision: 00000000 Serial number: CIV71WW99
Coding: 2F0609000200000C010000
VCID: 2C14F0EC4FD952E687-8078
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E099098041
Coding: 00C303
VCID: 52E88E140D3D2416ED-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1908EFE3040909
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 030000
VCID: 2B16F3F04AD755DE8E-807E
Address 37: Navigation (J0401) Labels: None
Part No SW: 8T0 919 888 A HW: 8T0 919 888
Component: J0401 NAV JP H32 0340
Revision: 0000005S Serial number: AUZBZ7J2716163
VCID: 48DCAC7CFB619EC683-801C
Subsystem 1 - Part No SW: 4F0 035 503 C HW: 4F0 035 503 C
Component: ETC-VICS-Ant. H02 0020
Subsystem 2 - Part No SW: 4F0 919 813 C HW: 4F0 919 813 C
Component: Card reader H02 0100
Subsystem 3 - Part No SW: 4E1 910 336 HW: 4E1 862 335
Component: Interface Han H09 0050
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009356313
Coding: 011C12205001410001
VCID: 45C2A548CC7383AE78-8010
Revision: 00002001 Serial number: 0121681686
Coding: 01000E22003904810130010000000000
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Fault Frequency: 19
Reset counter: 179
Mileage: 90490 km
Date: 2009.07.02
Time: 01:03:06
02616 - Fuel Tank Cap; Unlock
Fault Status: 01101001
Fault Frequency: 12
Reset counter: 141
Mileage: 90490 km
Date: 2009.07.04
Time: 20:38:30
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101100
Reset counter: 179
Mileage: 90491 km
Date: 2009.06.26
Time: 01:11:39
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AG HW: 8T0 035 223 G
Component: DSP STD H08 0310
Revision: S2700000
Coding: 010201
VCID: 73A62B90D2674D1E06-8026
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Fault Status: 01101011
Reset counter: 82
Mileage: 90490 km
Date: 2009.07.02
Time: 01:03:05
Voltage: 10.40 V
Temperature: 52.0°C
Bin. Bits: 00000011
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 82
Mileage: 90490 km
Date: 2009.07.02
Time: 01:03:05
Voltage: 10.40 V
Temperature: 52.0°C
Bin. Bits: 00000011
00418 - Front Right DSP Mid-Bass Speaker (R102)
Reset counter: 82
Mileage: 90490 km
Date: 2009.07.02
Time: 01:03:05
Voltage: 10.40 V
Temperature: 52.0°C
Bin. Bits: 00000011
Reset counter: 171
Mileage: 90490 km
Date: 2009.07.15
Time: 20:01:35
Voltage: 9.20 V
Temperature: 41.0°C
Bin. Bits: 00000011
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009321538
VCID: 44C4B84CC749BAA66F-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000325854
VCID: 3424E88C97E90A26DF-8060
Reset counter: 171
Mileage: 94345 km
Date: 2009.07.04
Time: 02:39:19
Voltage: 12.00 V
Count: 58
Hex Value: 0x02E0
Hex Value: 0x0001
Hex Value: 0x0101
Part No: 8K5 907 357
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 77BE1F80061F213E3A-8022
Fault Status: 11101010
Fault Priority: 8
Reset counter: 83
Mileage: 90490 km
Date: 2009.06.26
Time: 00:39:14
Fault Priority: 8
Reset counter: 83
Mileage: 90490 km
Date: 2009.06.26
Time: 00:39:14
Part No SW: 4E0 910 541 N HW: 4F0 035 541 K
Component: TUNER Japan H42 0180
Revision: 00000000 Serial number: 338IX097513328
Coding: 0000003
Address 57: TV Tuner Labels: None
Part No SW: 4F0 919 148 B HW: 4F0 919 148
Component: R78 DTV-JP 0180
Revision: R0H06000 Serial number: 79300600730402
Coding: 0000016
VCID: 2C14F0EC8FD952E687-8078
Subsystem 1 - Serial number: -ÿ
02283 - Video Connection to Output [End Unit]
Fault Status: 00101010
Fault Frequency: 110
Reset counter: 160
Mileage: 92501 km
Date: 2020.05.19
Time: 04:12:13
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101972891
Coding: 010C12204001210001
VCID: 42C8BE54DD5DB4965D-8016
Component: TSG HR H10 0306
Revision: Serial number: 0000101972903
End----------(Elapsed Time: 01:30, VBatt start/end: 12.3V/12.1V)-----------
Control Module Part Number: 8T0 035 730 G
Component and/or Version: Interfacebox H41 2100
Software Coding: 0000000
Work Shop Code: WSC 00000
Additional Info: 8T0919609E E0380 BedienteilH08 0100
Additional Info: Geraet 00000
Advanced Identification
Identification: JTB-074
Revision: 00000000
Date: 26.09.09
Test stand number: 6371
Manufacturer number: 0019
Identification: PRE-001
Revision: 00000001
Date: 17.09.09
Test stand number: 0001
Manufacturer number: 0395
Software
X2100
M010911
M0200
X06131AFC6AB320100
Misc.
Hardware number: 4E0 035 729 C
VCDS Info:
Labels: None
Address 46: DTCs cleared
Address 07: DTCs cleared
