2010 AUDI HEAD UNIT CODING REQUEST
keysallied
Zimbabwe
C?ID=336229
Hie mates
May you help the coding for the head unit it no long shows oil level.
Monday,29,June,2020,12:04:28:53861
VCDS Version: 20.4.1.0  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8K0AA064166   License Plate: AFB 3755
Mileage: 94670km-58825mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 52 53 55
          56 57 62 72
VIN: WAUZZZ8K0AA064166   Mileage: 94670km-58825miles
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AJ    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0002
   Revision: E1H15---
   Coding: 0104000C240F0060
   Shop #: WSC 63860 741 186740
   ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
   ROD: EV_ECM20AVS.rod
   VCID: 77BE1F80CE1F213E3A-8022
7900 - Right Engine Mount Solenoid Valve (N145)
          P1577 00 [047] - Open Circuit
                    Mileage: 94417 km
                    Date: 2009.06.27
                    Time: 19:22:41
                    Engine speed: 0.00 /min
                    Coolant temperature: 101 °C
                    Intake air temperature: 42 °C
                    Ambient air pressure: 870 mbar
                    Voltage terminal 30: 12.392 V
2886 - Catalyst System; Bank 1
          P0420 00 [104] - Efficiency Below Threshold
                    Mileage: 94461 km
                    Date: 2009.06.28
                    Time: 01:05:51
                    Engine speed: 1703.00 /min
                    Normed load value: 25.5 %
                    Vehicle speed: 41 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 40 °C
                    Ambient air pressure: 860 mbar
                    Voltage terminal 30: 13.853 V
5671 - Boost Pressure Regulation
          P0299 00 [109] - Control Range Not Reached
                    Mileage: 94648 km
                    Date: 2009.07.01
                    Time: 04:29:59
                    Engine speed: 2967.50 /min
                    Normed load value: 74.5 %
                    Vehicle speed: 94 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.321 V
4060 - Cylinder 3
          P0303 00 [237] - Misfire Detected
                    Mileage: 94647 km
                    Date: 2009.07.01
                    Time: 04:28:49
                    Engine speed: 2517.50 /min
                    Normed load value: 80.0 %
                    Vehicle speed: 62 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 13.099 V
7960 - Cylinder Disabling
          P130A 00 [044] - -
                    Mileage: 94649 km
                    Date: 2009.07.01
                    Time: 04:31:33
                    Engine speed: 4426.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 110 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 12.510 V
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [109] - -
                    Mileage: 94647 km
                    Date: 2009.07.01
                    Time: 04:28:49
   Part No SW: 8K1 927 156 AA    HW: 0B5 927 156 E
   Component: 0B5 20TFSIRdW H04 0012
   Revision: --H04---    Serial number: 0000000959
   Shop #: WSC 50938 000 1048576
   ASAM Dataset: EV_TCMDL501 A02203
   ROD: EV_TCMDL501.rod
   VCID: 74A4288CDF694A261F-8020
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 094508
   Shop #: WSC 06325 000 00000
   VCID: 7AB806B4F50D3C5645-802E
                    Fault Status: 00101101
                    Reset counter: 171
                    Mileage: 94345 km
                    Date: 2009.07.04
                    Time: 02:39:18
                    Hex Value: 0x0040
                    Hex Value: 0x0782
                    Hex Value: 0x0026
                    Hex Value: 0x468D
                    Hex Value: 0x00FF
                    Reset counter: 171
                    Mileage: 94345 km
                    Date: 2009.07.04
                    Time: 02:39:20
                    Hex Value: 0x0040
                    Hex Value: 0x2282
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0324
   Coding: 051100
   VCID: 0444784C87C97AA62F-8050
   Serial number: 0209000068680014
Address 07: Control Head        Labels: None
   Part No SW: 8T0 035 730 G    HW: 4E0 035 729 C
   Component: Interfacebox    H41 2100
   Revision: 00000000    Serial number: 337I0097518577
   Coding: 0000000
   VCID: 3522D5885C93132EE8-8060
   Subsystem 1 - Part No: 8T0 919 609 E
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000348283
   Subsystem 3 - Serial number: 0117.09.090000000100010395ÿ
   Subsystem 4 - Serial number: 010395ÿ
                    Time Indication: 15
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01280920090862
   Coding: 64046000
   VCID: 76A01284C115583621-8022
                    Reset counter: 171
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:35:41
                    Reset counter: 171
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:01:15
                    Reset counter: 171
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:39:15
                    Temperature: 23.0°C
                    Reset counter: 144
                    Mileage: 91967 km
                    Date: 2020.05.08
                    Time: 17:50:05
                    Temperature: 21.0°C
                    RPM: 1520 /min
                    Speed: 73.0 km/h
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000350685
   Coding: 260010800030AF010001000000001D0D0F1D430800010141000000
   VCID: 3A38C6B4B58DFC5605-806E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 220909  H05 0070
   Serial number: SWF09090225272
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10607732
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000504110770
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H45 0390
   Revision: 00045004    Serial number: AUZ5ZBI8882573
   VCID: 2B16F3F08AD755DE8E-807E
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD05YYH6
   Coding: 30373435363030303030554A3052384B3053
   VCID: 41CAB158D05BAF8E44-8014
   Serial number: 6334MSME4C047570C
   Serial number: 6344MSME4C33712EK
   Serial number: 6352QSME3C3C5738U
   Serial number: 6362QSME663B3C20L
   Serial number: 63732SME533C2402U
   Serial number: 63832SME3E3C2F1AH
9443859 - Driver's Front Airbag Crash Sensor
          B101A 15 [136] - Open or Short to Plus
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:35:38
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:35:38
   Revision: --------    Serial number: 90315IIN000DE
   Coding: 000032
   VCID: 3D32CDA8A4A3CB6E20-8068
   Part No SW: 8K0 920 930 B    HW: 8K0 920 930 B
   Component: KOMBIINSTR.   H20 0255
   Revision: 00000000    Serial number: CIV71WW99
   Coding: 2F0609000200000C010000
   VCID: 2C14F0EC4FD952E687-8078
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E099098041
   Coding: 00C303
   VCID: 52E88E140D3D2416ED-8006
   Component: J367-BDM  H06 0170
   Serial number: 1908EFE3040909
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H20 0850
   Revision: 00000000
   Coding: 030000
   VCID: 2B16F3F04AD755DE8E-807E
Address 37: Navigation (J0401)       Labels: None
   Part No SW: 8T0 919 888 A    HW: 8T0 919 888
   Component: J0401 NAV JP  H32 0340
   Revision: 0000005S    Serial number: AUZBZ7J2716163
   VCID: 48DCAC7CFB619EC683-801C
   Subsystem 1 - Part No SW: 4F0 035 503 C    HW: 4F0 035 503 C
   Component: ETC-VICS-Ant.  H02 0020
   Subsystem 2 - Part No SW: 4F0 919 813 C    HW: 4F0 919 813 C
   Component: Card reader  H02 0100
   Subsystem 3 - Part No SW: 4E1 910 336     HW: 4E1 862 335
   Component: Interface Han  H09 0050
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009356313
   Coding: 011C12205001410001
   VCID: 45C2A548CC7383AE78-8010
   Revision: 00002001    Serial number: 0121681686
   Coding: 01000E22003904810130010000000000
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Fault Frequency: 19
                    Reset counter: 179
                    Mileage: 90490 km
                    Date: 2009.07.02
                    Time: 01:03:06
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 01101001
                    Fault Frequency: 12
                    Reset counter: 141
                    Mileage: 90490 km
                    Date: 2009.07.04
                    Time: 20:38:30
                    Fault Status: 00101100
                    Reset counter: 179
                    Mileage: 90491 km
                    Date: 2009.06.26
                    Time: 01:11:39
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AG    HW: 8T0 035 223 G
   Component: DSP STD       H08 0310
   Revision: S2700000
   Coding: 010201
   VCID: 73A62B90D2674D1E06-8026
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 82
                    Mileage: 90490 km
                    Date: 2009.07.02
                    Time: 01:03:05
                    Voltage: 10.40 V
                    Temperature: 52.0°C
                    Bin. Bits: 00000011
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 82
                    Mileage: 90490 km
                    Date: 2009.07.02
                    Time: 01:03:05
                    Voltage: 10.40 V
                    Temperature: 52.0°C
                    Bin. Bits: 00000011
00418 - Front Right DSP Mid-Bass Speaker (R102)
                    Reset counter: 82
                    Mileage: 90490 km
                    Date: 2009.07.02
                    Time: 01:03:05
                    Voltage: 10.40 V
                    Temperature: 52.0°C
                    Bin. Bits: 00000011
                    Reset counter: 171
                    Mileage: 90490 km
                    Date: 2009.07.15
                    Time: 20:01:35
                    Voltage: 9.20 V
                    Temperature: 41.0°C
                    Bin. Bits: 00000011
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009321538
   VCID: 44C4B84CC749BAA66F-8010
   Revision: 00000003    Serial number: 10000000325854
   VCID: 3424E88C97E90A26DF-8060
                    Reset counter: 171
                    Mileage: 94345 km
                    Date: 2009.07.04
                    Time: 02:39:19
                    Voltage: 12.00 V
                    Count: 58
                    Hex Value: 0x02E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77BE1F80061F213E3A-8022
                    Fault Status: 11101010
                    Fault Priority: 8
                    Reset counter: 83
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:39:14
                    Fault Priority: 8
                    Reset counter: 83
                    Mileage: 90490 km
                    Date: 2009.06.26
                    Time: 00:39:14
   Part No SW: 4E0 910 541 N    HW: 4F0 035 541 K
   Component: TUNER Japan     H42 0180
   Revision: 00000000    Serial number: 338IX097513328
   Coding: 0000003
Address 57: TV Tuner        Labels: None
   Part No SW: 4F0 919 148 B    HW: 4F0 919 148
   Component: R78 DTV-JP          0180
   Revision: R0H06000    Serial number: 79300600730402
   Coding: 0000016
   VCID: 2C14F0EC8FD952E687-8078
   Subsystem 1 - Serial number: -ÿ
02283 - Video Connection to Output [End Unit]
                    Fault Status: 00101010
                    Fault Frequency: 110
                    Reset counter: 160
                    Mileage: 92501 km
                    Date: 2020.05.19
                    Time: 04:12:13
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101972891
   Coding: 010C12204001210001
   VCID: 42C8BE54DD5DB4965D-8016
   Revision:             Serial number: 0000101972903
End----------(Elapsed Time: 01:30, VBatt start/end: 12.3V/12.1V)-----------
Control Module Part Number: 8T0 035 730 G
  Component and/or Version: Interfacebox    H41 2100
           Software Coding: 0000000
            Work Shop Code: WSC 00000
           Additional Info: 8T0919609E  E0380 BedienteilH08 0100
           Additional Info: Geraet 00000
Advanced Identification
     Identification: JTB-074
     Revision: 00000000
     Date: 26.09.09
     Test stand number: 6371
     Manufacturer number: 0019
     Identification: PRE-001
     Revision: 00000001
     Date: 17.09.09
     Test stand number: 0001
     Manufacturer number: 0395
Software
     X2100
     M010911
     M0200
     X06131AFC6AB320100
Misc.
     Hardware number: 4E0 035 729 C
VCDS Info:
       Labels: None
Address 46: DTCs cleared
Address 07: DTCs cleared
Mari
C?ID=150535
I wouldn't worry about not showing the oil level, plenty of faultcodes in your autoscan that do need attention!
I absolutely agree with Mari in regards to all of the fault codes but Address 07 appears to be new (or rebuilt?):
Coding: 0000000
I believe this is MMI 2G using PR-Code 8DZ Radio "HIGH" Japan but any additional infotainment specific history you can provide would be helpful so I add it to the VCDS redirect file correctly.
In the meanwhile this general coding chart can be used and I believe 07 would have been factory coded to something like 0000108
00x0?0x: Mute
1 = Mute-Wire active
00x0x??: Language
08 = Japanese​
.. but that won't help with the missing Adaptations (including the oil menu) and I'm not sure if you want it coded to Japanese?
The list of Adaptation values on that Wiki page should apply as well but all of those channels are additive. If you need assistance please include the Adaptation function Control Module Map of address 07 in reply with the history.
keysallied
Zimbabwe
C?ID=336229
thanks diana, i dont want it coded to japanesse, this car was had option to show oil level but after an engine repairs the menu was gone, the client needs it. i have been trying to have it disply oil level.
Mari
C?ID=150535
Engine repairs do not change codings of head-unit.... did you check the link to the general coding chart in Dana's post?
Thanks for the known history.
8T0 035 730 G isn't the factory installed part number and I can't locate it in ETKA, PL24 or any TSB/TPIs where an official flash update might have taken place so I suspect this is an exported vehicle missing repair/modification history. I went ahead and redirected it to the existing 8T0-035-7xx-07-H.CLB file for now so the next VCDS update will have a label file.
In the meanwhile I'd use the coding chart on that Wiki page and experiment with the Language options. If you need assistance with the Adaptations please post the Adp map. You can open it with Notepad and wrap it in [code] ... [/code] tags like a scan. Doing so will allow us to see how channels 001 through 012 are configured so we can make suggestions based on the PR-Codes. I'll paste that list below in the event that you take a crack at it:
[TABLE="class: vinInfoTable"]
[TR]
[TH]Vehicle Identification No.[/TH]
[TD="colspan: 2"]WAUZZZ8K0AA064166[/TD]
[/TR]
[TR]
[TH]Model[/TH]
[TD="colspan: 2"]audi a4 qu. 2,0
A4[/TD]
[/TR]
[TR]
[TH]Date of production[/TH]
[TD="colspan: 2"]05.10.2009[/TD]
[/TR]
[TR]
[TH]Model year[/TH]
[TD="colspan: 2"]2010[/TD]
[/TR]
[TR]
[TH]Sales type[/TH]
[TD="colspan: 2"]8K206Y[/TD]
[/TR]
[TR]
[TH]Engine Code[/TH]
[TD="colspan: 2"]CDNC[/TD]
[/TR]
[TR]
[TH]Transmission Code[/TH]
[TD="colspan: 2"]LZL[/TD]
[/TR]
[TR]
[TH]Axle drive[/TH]
[TD="colspan: 2"]7A[/TD]
[/TR]
[TR]
[TH]Equipment[/TH]
[TD="colspan: 2"]QE[/TD]
[/TR]
[TR]
[TH]Roof color[/TH]
[TD="colspan: 2"]P5[/TD]
[/TR]
[TR]
[TH]Carpet color code[/TH]
[TD="colspan: 2"][/TD]
[/TR]
[TR]
[TH]Exterior color / Paint Code[/TH]
[TD="colspan: 2"]P5 / X7W[/TD]
[/TR]
[TR]
[TH]Seat combination no.[/TH]
[/TR]
[TR]
[TH]Number of Z-Orders[/TH]
[/TR]
[/TABLE]
[TR]
[TH]Special editions[/TH]
[TD="class: prCode"]E4J[/TD]
[TD]"S-line"[/TD]
[/TR]
[TR]
[TH]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PA[/TD]
[TD]Standard wheel bolts[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation
powertrains/platform parts[/TH]
[TD="class: prCode"]0HV[/TD]
[TD]Vehicle class differentiation -8K0-[/TD]
[/TR]
[TR]
[TH]Emission standard[/TH]
[TD="class: prCode"]7MG[/TD]
[TD]Emission standard EU5[/TD]
[/TR]
[TR]
[TH]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]Without trailer hitch[/TD]
[/TR]
[TR]
[TH]airbag[/TH]
[TD="class: prCode"]4UE[/TD]
[TD]Airbag for driver and front passenger[/TD]
[/TR]
[TR]
[TH]Label for central electric system[/TH]
[TD="class: prCode"]0W2[/TD]
[TD]Label for central electric system
English-speaking countries[/TD]
[/TR]
[TR]
[TH]Storage compartment package[/TH]
[TD="class: prCode"]QE1[/TD]
[TD]Storage compartment package 1[/TD]
[/TR]
[TR]
[TH]Applications[/TH]
[TD="class: prCode"]GS4[/TD]
[TD]Applications[/TD]
[/TR]
[TR]
[TH]Exterior mirror adjustment[/TH]
[TD="class: prCode"]6XE[/TD]
[TD]Exterior mirrors, power-folding/
adjustment, heated[/TD]
[/TR]
[TR]
[TH]Follow-on warranty[/TH]
[TD="class: prCode"]EA0[/TD]
[TD]Without subsequent warranty[/TD]
[/TR]
[TR]
[TH]Left exterior mirror[/TH]
[TD="class: prCode"]5SJ[/TD]
[TD]Left exterior mirror, convex[/TD]
[/TR]
[TR]
[TH]Right exterior mirror[/TH]
[TD="class: prCode"]5RU[/TD]
[TD]Right exterior mirror, convex
(large viewing field)[/TD]
[/TR]
[TR]
[TH]Drive type[/TH]
[TD="class: prCode"]1X1[/TD]
[TD]Four-wheel drive[/TD]
[/TR]
[TR]
[TH]Multimedia/video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH]Equipment lines[/TH]
[TD="class: prCode"]A8S[/TD]
[TD]Standard equipment[/TD]
[/TR]
[TR]
[TH]Rear brakes[/TH]
[TD="class: prCode"]1KW[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[TD="class: prCode"]J0Z[/TD]
[TD]Battery 520 A (110 Ah)[/TD]
[/TR]
[TR]
[TH]Front brakes[/TH]
[TD="class: prCode"]1LA[/TD]
[TD]Disc brakes in front[/TD]
[/TR]
[TR]
[TH]Components with special surface[/TH]
[TD="class: prCode"]6FA[/TD]
[TD]Components without special surface
appearance[/TD]
[/TR]
[TR]
[TH]Handset (telephone)[/TH]
[TD="class: prCode"]QF0[/TD]
[TD]Without receiver (car phone)[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacities[/TH]
[TD="class: prCode"]NY2[/TD]
[TD]Increased battery capacity[/TD]
[/TR]
[TR]
[TH]Component sets for country-specific
prescriptive standards[/TH]
[TD="class: prCode"]B0L[/TD]
[TD]Component parts set, complying with
vehicle type for Japan, various parts[/TD]
[/TR]
[TR]
[TH]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH]Owner's manuals[/TH]
[TD="class: prCode"]0VR[/TD]
[TD]Information kit in Japanese[/TD]
[/TR]
[TR]
[TH]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH]CD-ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH]CD changer/CD player[/TH]
[TD="class: prCode"]7D3[/TD]
[TD]CD changer[/TD]
[/TR]
[TR]
[TH]Driving mode selection[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH]General operating license additions[/TH]
[TD="class: prCode"]C00[/TD]
[TD]Operating permit, initial registration[/TD]
[/TR]
[TR]
[TH]Cd-enhancing underbody panel[/TH]
[TD="class: prCode"]2D0[/TD]
[TD]Without cd enhancing underbody panel[/TD]
[/TR]
[TR]
[TH]Shock absorption/suspension system[/TH]
[TD="class: prCode"]1BV[/TD]
[TD]Sports suspension/shock absorption[/TD]
[/TR]
[TR]
[TH]Roof rails/roof rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]Without roof insert (standard roof)[/TD]
[/TR]
[TR]
[TH]Decorative films/emblems[/TH]
[TD="class: prCode"]6F1[/TD]
[TD]Emblems[/TD]
[/TR]
[TR]
[TH]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH]Theft protection system[/TH]
[TD="class: prCode"]7AA[/TD]
[TD]Electronic immobilizer[/TD]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]5TG[/TD]
[TD]Decorative inserts, brushed, matte
aluminum[/TD]
[/TR]
[TR]
[TH]Scuff plates[/TH]
[TD="class: prCode"]7M8[/TD]
[TD]Scuff plates in door apertures[/TD]
[/TR]
[TR]
[TH]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH]Electric interface for external use[/TH]
[TD="class: prCode"]UF0[/TD]
[TD]Without electric interface[/TD]
[/TR]
[TR]
[TH]Differentiation for manufacturing
process[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH]Headlight activation[/TH]
[TD="class: prCode"]8K0[/TD]
[TD]Without special headlight control[/TD]
[/TR]
[TR]
[TH]Parking brake[/TH]
[TD="class: prCode"]UH2[/TD]
[TD]Parking brake[/TD]
[/TR]
[TR]
[TH]Vehicle tracking system[/TH]
[TD="class: prCode"]7G0[/TD]
[TD]Without preparation for VTS (Vehicle Tracing System)[/TD]
[/TR]
[TR]
[TH]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH]Transmission types/gear shift mechanisms[/TH]
[TD="class: prCode"]0G7[/TD]
[TD]tiptronic[/TD]
[/TR]
[TR]
[TH]Weight category for rear axle[/TH]
[TD="class: prCode"]0YG[/TD]
[TD]Weight range 7
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH]Weight category for front axle[/TH]
[TD="class: prCode"]0JE[/TD]
[TD]Weight category front axle
weight range 5[/TD]
[/TR]
[TR]
[TH]Base engine[/TH]
[TD="class: prCode"]TG6[/TD]
[TD]4-cylinder SI engine 2.0 l
unit 06H.G[/TD]
[/TR]
[TR]
[TH]Tie down straps/net/pocket[/TH]
[TD="class: prCode"]6M0[/TD]
[TD]Without tie down straps/net/pocket[/TD]
[/TR]
[TR]
[TH]cruise control system[/TH]
[TD="class: prCode"]8T0[/TD]
[TD]Without cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH]Transmission specification[/TH]
[TD="class: prCode"]G1D[/TD]
[TD]7-speed automatic transmission for
four-wheel drive[/TD]
[/TR]
[TR]
[TH]rear axle differential[/TH]
[TD="class: prCode"]GH1[/TD]
[TD]Basic rear differential[/TD]
[/TR]
[TR]
[TH]Rear trim panel[/TH]
[TD="class: prCode"]6V2[/TD]
[TD]Rear trim panel[/TD]
[/TR]
[TR]
[TH]Manufacturer[/TH]
[TD="class: prCode"]A51[/TD]
[TD]Audi AG[/TD]
[/TR]
[TR]
[TH]Rear spoiler[/TH]
[TD="class: prCode"]5J0[/TD]
[TD]Without rear spoiler[/TD]
[/TR]
[TR]
[TH]Molded headliner[/TH]
[TD="class: prCode"]6NQ[/TD]
[TD]Standard molded headliner[/TD]
[/TR]
[TR]
[TH]Rear seats[/TH]
[TD="class: prCode"]3NZ[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH]Heating system/air conditioning system[/TH]
[TD="class: prCode"]9AQ[/TD]
[TD]Air conditioning plus[/TD]
[/TR]
[TR]
[TH]Main headlamps[/TH]
[TD="class: prCode"]8BP[/TD]
[TD]Bi-functional headlamp with gas
discharge lamp[/TD]
[/TR]
[TR]
[TH]Customized installation[/TH]
[TD="class: prCode"]FC1[/TD]
[TD]Customized installation[/TD]
[/TR]
[TR]
[TH]Dashboard inserts[/TH]
[TD="class: prCode"]U1A[/TD]
[TD]Instrument cluster with km/h
speedometer, clock, tachometer and trip
odometer[/TD]
[/TR]
[TR]
[TH]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L6[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming[/TD]
[/TR]
[TR]
[TH]Body forms[/TH]
[TD="class: prCode"]K8B[/TD]
[TD]Notchback[/TD]
[/TR]
[TR]
[TH]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SS[/TD]
[TD]Luggage compartment floor covering[/TD]
[/TR]
[TR]
[TH]Climate zones[/TH]
[TD="class: prCode"]0Y2[/TD]
[TD]Tropical zones[/TD]
[/TR]
[TR]
[TH]Head restraints in rear[/TH]
[TD="class: prCode"]3Q1[/TD]
[TD]headrest for seat, rear[/TD]
[/TR]
[TR]
[TH]Fuel filling volume[/TH]
[TD="class: prCode"]1Z5[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH]Fuel quality[/TH]
[TD="class: prCode"]0U0[/TD]
[TD]Fuel quality 98 RON[/TD]
[/TR]
[TR]
[TH]Fuel systems[/TH]
[TD="class: prCode"]1A2[/TD]
[TD]Fuel system for SI engine with direct
injection (FSI)[/TD]
[/TR]
[TR]
[TH]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH]License plate carrier in front[/TH]
[TD="class: prCode"]6W4[/TD]
[TD]Front license plate carrier (small,
Japan)[/TD]
[/TR]
[TR]
[TH]Paint preservation/transport protection[/TH]
[TD="class: prCode"]5K4[/TD]
[TD]Full body cover (shape-adapted system)
with additional transport protection
measures[/TD]
[/TR]
[TR]
[TH]Luggage/load compartment floor in rear[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH]Lighting package (lighting)[/TH]
[TD="class: prCode"]QQ1[/TD]
[TD]With additional lights (interior
lighting)[/TD]
[/TR]
[TR]
[TH]Steering system setup[/TH]
[TD="class: prCode"]L0R[/TD]
[TD]Right-hand drive[/TD]
[/TR]
[TR]
[TH]Steering system[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH]Lumbar support in backrests[/TH]
[TD="class: prCode"]7P1[/TD]
[TD]Power-adjustable lumbar support in front
seats[/TD]
[/TR]
[TR]
[TH]steering wheels[/TH]
[TD="class: prCode"]1XX[/TD]
[TD]Leather-wrapped multi-function sports
steering wheel with tiptronic[/TD]
[/TR]
[TR]
[TH]Driving on the left/right side[/TH]
[TD="class: prCode"]AV0[/TD]
[TD]Driving on the left[/TD]
[/TR]
[TR]
[TH]Loudspeaker installation[/TH]
[TD="class: prCode"]9VD[/TD]
[TD]active loudspeakers[/TD]
[/TR]
[TR]
[TH]Leather parts[/TH]
[TD="class: prCode"]7HA[/TD]
[TD]Without leather trim[/TD]
[/TR]
[TR]
[TH]Headlight range control[/TH]
[TD="class: prCode"]8Q3[/TD]
[TD]Dynamic headlight range control
(self-adjusting while driving)[/TD]
[/TR]
[TR]
[TH]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH]Variants[/TH]
[TD="class: prCode"]FM0[/TD]
[TD]Basic equipment variant[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q4[/TD]
[TD]Multi-function display/trip computer
with check control[/TD]
[/TR]
[TR]
[TH]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH]Engine specification[/TH]
[TD="class: prCode"]D2D[/TD]
[TD]4-cylinder petrol engine 2.0 L/155 KW (16 V)
Turbo FSI, homogeneous
Basic engine is: TM2/TV2/TG6/TJ6/TD6[/TD]
[/TR]
[TR]
[TH]Navigation system[/TH]
[TD="class: prCode"]7Q6[/TD]
[TD]Navigation system for Japan,
color screen[/TD]
[/TR]
[TR]
[TH]Front fog lamps/additional headlamps[/TH]
[TD="class: prCode"]8WB[/TD]
[TD]Front fog lamps[/TD]
[/TR]
[TR]
[TH]Model upgrade measures[/TH]
[TD="class: prCode"]GP0[/TD]
[TD]Vehicles without special upgrade
measures[/TD]
[/TR]
[TR]
[TH]Audi Sport/ Quattro GmbH[/TH]
[TD="class: prCode"]FQ1[/TD]
[TD]Wheels of Audi Sport/ Quattro GmbH[/TD]
[/TR]
[TR]
[TH]Quality class[/TH]
[TD="class: prCode"]AQ0[/TD]
[TD]Standard-production quality[/TD]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]C8S[/TD]
[TD]Alloy wheels 8J x 18[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[TD="class: prCode"]8DZ[/TD]
[TD]Radio "HIGH" Japan[/TD]
[/TR]
[TR]
[TH]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K0[/TD]
[TD]Without tyre pressure monitor[/TD]
[/TR]
[TR]
[TH]tire[/TH]
[TD="class: prCode"]H7U[/TD]
[TD]Tires 245/40 R18 93Y[/TD]
[/TR]
[TR]
[TH]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G5[/TD]
[TD]Space-saving spare wheel, same size
(same rolling circumference) as original
equipment tires[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PQD[/TD]
[TD]SPORT DESIGN[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]WQV[/TD]
[TD][/TD]
[/TR]
[TR]
[TH]Side airbag[/TH]
[TD="class: prCode"]4X4[/TD]
[TD]Side airbag in front and rear
with curtain airbag[/TD]
[/TR]
[TR]
[TH]Gearshift knob/gearshift handle[/TH]
[TD="class: prCode"]7F9[/TD]
[TD]Gearshift knob/handle in plastic/leather[/TD]
[/TR]
[TR]
[TH]Self pick-up/special control[/TH]
[TD="class: prCode"]A00[/TD]
[TD]No self-collection[/TD]
[/TR]
[TR]
[TH]Special labels[/TH]
[TD="class: prCode"]0SL[/TD]
[TD]Labels in Japanese[/TD]
[/TR]
[TR]
[TH]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SK[/TD]
[TD]Taillight assemblies with diodes (LED)[/TD]
[/TR]
[TR]
[TH]Closing/opening mechanism
tailgate/trunk lid/rear gate[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH]Bumper systems[/TH]
[TD="class: prCode"]2K7[/TD]
[TD]bumper reinforced[/TD]
[/TR]
[TR]
[TH]Seat belt reminder[/TH]
[TD="class: prCode"]9P3[/TD]
[TD]Seat belt reminder, electric contact in
buckle[/TD]
[/TR]
[TR]
[TH]seat covers[/TH]
[TD="class: prCode"]N7V[/TD]
[TD]Seat trim covers in fabric and pearl
napa leather[/TD]
[/TR]
[TR]
[TH]Seat adjustment[/TH]
[TD="class: prCode"]3L5[/TD]
[TD]Both front seats power-adjustable[/TD]
[/TR]
[TR]
[TH]seat heater[/TH]
[TD="class: prCode"]4A0[/TD]
[TD]without seat heater[/TD]
[/TR]
[TR]
[TH]Safety certificates[/TH]
[TD="class: prCode"]0LG[/TD]
[TD]With special labels
safety certificates for Japan[/TD]
[/TR]
[TR]
[TH]Start-stop system/regenerative braking[/TH]
[TD="class: prCode"]7L7[/TD]
[TD]Regenerative braking with 12.5 V[/TD]
[/TR]
[TR]
[TH]sun visors[/TH]
[TD="class: prCode"]5XK[/TD]
[TD]Sun visors on driver and front passenger
side[/TD]
[/TR]
[TR]
[TH]Voice control system/voice control[/TH]
[TD="class: prCode"]QH0[/TD]
[TD]without voice control[/TD]
[/TR]
[TR]
[TH]Lane change system/lane keeping system[/TH]
[TD="class: prCode"]7Y0[/TD]
[TD]no lane change assistant[/TD]
[/TR]
[TR]
[TH]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH]Sun blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH]Outlet[/TH]
[TD="class: prCode"]7B0[/TD]
[TD]without socket[/TD]
[/TR]
[TR]
[TH]Control of production/pre-production[/TH]
[TD="class: prCode"]FA0[/TD]
[TD]Control of series production[/TD]
[/TR]
[TR]
[TH]Headlamp washer system[/TH]
[TD="class: prCode"]8X1[/TD]
[TD]Headlamp washer system[/TD]
[/TR]
[TR]
[TH]Intermittent windshield wiper control/
light/rain sensor[/TH]
[TD="class: prCode"]8N6[/TD]
[TD]Windshield wiper intermittent control
with light/rain sensor[/TD]
[/TR]
[TR]
[TH]Special approval measures[/TH]
[TD="class: prCode"]3M3[/TD]
[TD]Passenger car design[/TD]
[/TR]
[TR]
[TH]Door and tailgate/trunk lid locking
mechanism[/TH]
[TD="class: prCode"]4F2[/TD]
[TD]Central locking system "Keyless Entry"[/TD]
[/TR]
[TR]
[TH]Type-approval testing countries/
countries with specific requirements[/TH]
[TD="class: prCode"]B29[/TD]
[TD]Type approval country Japan[/TD]
[/TR]
[TR]
[TH]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D4[/TD]
[TD]Carrier frequency 315 MHz
without panic button[/TD]
[/TR]
[TR]
[TH]Transport protection[/TH]
[TD="class: prCode"]NT1[/TD]
[TD]Transit coating (type 2)[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV2[/TD]
[TD]TV reception for Japan[/TD]
[/TR]
[TR]
[TH]Installation parts for engines
(engine mount system)[/TH]
[TD="class: prCode"]1VG[/TD]
[TD]Installation parts for four-cylinder
engine[/TD]
[/TR]
[TR]
[TH]Front-end underbody cladding[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH]Identification labels[/TH]
[TD="class: prCode"]1EJ[/TD]
[TD]Special identification plate[/TD]
[/TR]
[TR]
[TH]Type signs[/TH]
[TD="class: prCode"]2Z1[/TD]
[TD]Type sign at rear
and "Quattro" nameplates respectively[/TD]
[/TR]
[TR]
[TH]First aid kit/warning triangle[/TH]
[TD="class: prCode"]1T2[/TD]
[TD]warning triangle[/TD]
[/TR]
[TR]
[TH]Front seats[/TH]
[TD="class: prCode"]Q1D[/TD]
[TD]Sports front seats[/TD]
[/TR]
[TR]
[TH]Telephone/telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH]Maintenance contract[/TH]
[TD="class: prCode"]EW0[/TD]
[TD]Without maintenance contract[/TD]
[/TR]
[TR]
[TH]Thermal energy storage system/auxiliary
heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH]Windshield[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH]Decorative trims[/TH]
[TD="class: prCode"]4ZB[/TD]
[TD]Bright decorative trims[/TD]
[/TR]
[TR]
[TH]Additional body protective covers, side[/TH]
[TD="class: prCode"]6EP[/TD]
[TD]Additional stone guard body covers[/TD]
[/TR]
[TR]
[TH]Additional child seat anchorage[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH]Auxiliary heater[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
