How does A8 D3 LED acuation work?
golfi_vend
Tartu, Estonia
C?ID=195131
Hi
Back with "How does...?" questions. :)
This time I'm trying to figure out how does the LED light work in A8 D3-chassis. What kind of "info" does move in bi-directional wire?
Problem is that the light is sometimes at 100%, some other times it works as it is supposed to. Weirdly the problem doesn't move sides when i swapped L and R light. Wires check out.
Now i don't have autoscan from this vechicle, because the latest VCDS update doesn't like to finish the autoscan. - I've contacted Eric already.
Sunday,15,February,2015,15:43:19:01666
VCDS Version: 15.2.0.0 (x64)
Data version: 20150130
VIN:    License Plate: AUDI A8
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 4E1 910 409 A    HW: 4E1 907 409
  Component and/or Version: 4.2L V8TDI  G000AGMŖ0070
           Software Coding: 0011773
            Work Shop Code: WSC 84140 472 13379
                      VCID: 224B18CDFDC9732855-8077
005746 - Coolant Fan Control 1
               P1672 - 001 - Open or Short to Ground - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 243
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:26:40
                    RPM: 630 /min
                    Torque: 81.9 Nm
                    Duty Cycle: 9.5 %
                    Voltage: 13.68 V
                    Duty Cycle: 9.5 %
                    Duty Cycle: 9.5 %
005697 - Please check DTC Memory of A/C Controller
               P1641 - 001 -
                    Fault Status: 01100001
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:26:41
                    RPM: 630 /min
                    Torque: 81.9 Nm
                    Duty Cycle: 0.4 %
                    Voltage: 13.53 V
                    Bin. Bits: 00101000
                    Bin. Bits: 00000000
006480 - Radiator Fan (V7)
               P1950 - 001 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 9
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:27:16
                    RPM: 630 /min
                    Torque: 81.9 Nm
                    Duty Cycle: 9.5 %
                    Duty Cycle: 9.5 %
                    Duty Cycle: 9.5 %
                    Duty Cycle: 9.5 %
Readiness: 0 0 1 1 1
                Address 06: Seat Mem. Pass       Labels: None
           Software Coding:
            Work Shop Code:
                      VCID: 55A17311BC07D49060-FFFF
No Faults Found
                Address 08: Auto HVAC       Labels: None
Control Module Part Number: 4E0 910 043 B    HW: 4E0 820 043 C
  Component and/or Version: KLIMAAUTOMAT    016 0400
           Software Coding: 1054785
            Work Shop Code: WSC 02311 785 00200
                      VCID: 1C372635DFAD45D89F-8049
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 160
                    Mileage: 212064 km
                    Date: 2015.01.25
                    Time: 01:35:46
                Address 19: CAN Gateway       Labels: 4E0-910-468.lbl
Control Module Part Number: 4E0 910 468 B    HW: 4E0 907 468 E
  Component and/or Version: Gateway         H10 0080
           Software Coding: FCFEFBDE2B3504
            Work Shop Code: WSC 02313 785 00200
                      VCID: 275D09D996EB960002-8072
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 169
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:28:52
                    Reset counter: 169
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:28:54
                Address 1E: Media Player 2       Labels: None
Control Module Part Number: 4E0 910 119 B    HW: 4E0 035 119
  Component and/or Version: CD-Single       H41 0240
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                      VCID: 204F12C5F3C5613843-8075
00468 - CD-ROM Drive (R92)
                    Fault Status: 00101110
                    Fault Frequency: 9
                    Reset counter: 205
                    Mileage: 212671 km
                    Date: 2015.02.07
                    Time: 21:05:29
                    Time: 0.00 ms
                Address 42: Door Elect, Driver       Labels: 4E1-910-802-42.lbl
Control Module Part Number: 4E1 910 802 B    HW: 4E1 959 801 B
  Component and/or Version: Türsteuer.FS BRM003 0100
           Software Coding: 0028460
                    Fault Frequency: 0
                    Reset counter: 169
                    Mileage: 212912 km
                    Date: 2015.02.15
                    Time: 15:40:08
                Address 46: Central Conv.       Labels: 4E0-910-289.lbl
Control Module Part Number: 4E0 910 289 B    HW: 4E0 907 289
  Component and/or Version: Komfortgeraet   H05 0010
           Software Coding: 0004695
           Additional Info: 4E0907719   Neigungssensor  H04 0020
           Additional Info: Geraet 00200
                      VCID: 285F0AE59BF599780B-807D
00985 - Right Tail Light (M2)
                    Reset counter: 169
                    Mileage: 186967 km
                    Date: 2013.12.13
                    Time: 08:06:31
                Address 76: Park Assist       Labels: 4E0-910-283.lbl
Control Module Part Number: 4E0 910 283 C    HW: 4E0 919 283 C
  Component and/or Version: Parkhilfe 8-Kan H12 0030
           Software Coding: 0201108
                      VCID: 23451DC9E2D37A205E-8076
01548 - Sensor for Parking Aid; Rear Right (G206)
                    Reset counter: 169
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:37:56
                Address 77: Telephone       Labels: 4E0-910-333.lbl
Control Module Part Number: 4E0 910 333 E    HW: 4E0 862 333 C
  Component and/or Version: TELEFONMODUL EU     0700
           Software Coding: 0000004
                      VCID: 214917C1F8CF68304C-8074
02387 - Telephone Mount (R126)
                    Reset counter: 169
                    Mileage: 212923 km
                    Date: 2015.02.15
                    Time: 15:26:11
