2007 VW EOS
I’m trying to diagnose an issue where my battery runs low everyday. As far as I know, nothing in the car goes dead(radio, lights), except the car will not start. It dwindles down throughout the day until I’m not able to crank. The radio is on fine, and I believe my lights work fine. Battery is brand new . As far as I can see everything works, but will not crank at the end of the day. Obviously, the car is living off the battery.
Is there a module in VCDS to test the altenator or/and starter.? I ran a scan, and nothing shows up. I’ve been keeping it on life support (battery mainter).
Should I start by Replacing the battery cable? Any suggestions?
Saturday,27,June,2020,23:17:00:35951
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWAA71F87V053104 License Plate:
Mileage: 214470km-133265mi Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 65 72
VIN: WVWAA71F87V053104 Mileage: 214470km-133265miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1Q0 907 115 E HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G23NT7V0
Coding: 041C010A18070160
Shop #: WSC 07208 444 85814
VCID: 2E050BD97C1F838BF17-807A
004917 - Engine Torque Monitor 2
P1335 - 008 - Control Limit Exceeded - Intermittent
Mileage: 212383 km
Time: 11:55:09
RPM: 1820 /min
Load: 73.7 %
Temperature: 93.0°C
Temperature: 45.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.938 V
U0155 - 008 - - Intermittent
Temperature: 15.0°C
Temperature: 15.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.573 V
P0300 - 008 - - Intermittent
Mileage: 213826 km
Time: 19:56:26
RPM: 1204 /min
Load: 39.2 %
Temperature: 27.0°C
Temperature: 27.0°C
Voltage: 12.573 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Mileage: 213826 km
Time: 19:57:05
RPM: 1132 /min
Load: 28.6 %
Temperature: 35.0°C
Temperature: 27.0°C
Voltage: 12.954 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021218
Shop #: WSC 00020 000 00000
VCID: 73B3DAADD7BDEE635E9-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Q0 907 044 D HW: 1Q0 907 044 D
Component: ClimatronicPQ35 111 0202
Revision: 00111021 Serial number: 00000000000000
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000006983681
Coding: 118C0F0340041500470000000F00000000285D035C000100000000000000
VCID: 71BFD0A5ADA1DC73AC5-8024
Component: Wischer 140507 021 0501
Coding: 00038805
Shop #: WSC 00020
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 74 Airbag VW8C 0180
Revision: 92009018 Serial number: 003B3001YPXO
Coding: 0014132
VCID: 3A2D3789B0575F2B5DF-806E
Subsystem 1 - Part No: 1Q0 959 339 A
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 3LWUH
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332SRB4041285A8-ÿ†63
Subsystem 5 - Serial number: 285A8-ÿ†6342SRB40412449AXÿ†63
Subsystem 6 - Serial number: 2449AXÿ†6372URB40240CCC8Bÿ†63
Subsystem 7 - Serial number: 0CCC8Bÿ†6382URB40240CD968ÿ
Subsystem 8 - Serial number: 0CD968ÿ
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0000021
VCID: 00598561960BC5FB53B-8054
Part No SW: 1Q0 920 953 D HW: 1Q0 920 953 D
Revision: V0003000 Serial number: VWX7Z0G23NT7V0
Coding: 0023207
VCID: 323D1FA96827A76B95F-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300107426010B
Coding: 3DBF234007005000
Shop #: WSC 00020 999 00000
VCID: 2F3B16DD7B158A83FA1-807A
Component: IMMO VDD 1610
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 F HW: 1Q0 959 255 F
Component: Verdecksteuergeraet 0854
Revision: 0033100Q Serial number: 103340273
Coding: 0655360
Shop #: WSC 01150 444 101446
VCID: 3B23328DBF6D6623469-806E
Part No SW: 1Q0 959 701 D HW: 1Q0 959 701 D
Component: Tuer-SG 006 1209
Coding: 0001207
VCID: 353724B59949B053B0D-8060
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 13908A800186281B0804040FB0080E0488DCA0
Shop #: WSC 05110 444 99599
VCID: 045189718213D9DB773-8050
Part No SW: 1Q0 959 702 D HW: 1Q0 959 702 D
Coding: 0001206
VCID: 363523B9844FBB4BB97-8062
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7G6249039
Coding: 0040401
VCID: 1E65DB190CBF130B417-804A
Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
Component: Tuer-SG 006 1203
Coding: 0000128
Shop #: WSC 00020 000 1012544
VCID: 343119B19233A95B873-8060
014 - Defective
Component: RDK 0440
Coding: 0100101
Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
Coding: 0000128
End(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.9V. VIgn 11.9V, udsna)--
