Inherited this car and trying to get to pass North Caroline Inspection, need horn to work, all fuses check, 451 relay is on order but don't suspect its that, do I need to pull steering wheel and check Clock spring? is there a way to check communications ?
Friday,19,June,2020,16:52:09:56813
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWVD63BX3E417269 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWVD63BX3E417269 Mileage: 266400km-165533miles
Address 01: Engine Labels: 06B-906-018-AWM.clb
Part No SW: 4B0 906 018 DA HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0006
Coding: 0016501
Shop #: WSC 05311 000 00000
VCID: 6393AA2C374866C32E9-5160
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 00000
VCID: 2517F4347CFCD8F300D-51F2
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-00 - Open or Short to Plus
35-00 - -
66-10 - Not Matched - Intermittent
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 2411E93077C621FB173-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05314
VCID: 2F3B161C2E0092A3FA1-5160
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 07235
WVWVD63BX3E417269 VWZ7Z0C7452650
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05311
VCID: 70B9D560F3BECD5BA3B-513C
Part No: 1C0 959 799 C
Component: 80 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
VCID: 372B2E7CD6505A63A21-4B1E
Subsystem 1 - Part No: 1C1959801
Component: 80 Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C0959802A
Component: 09 Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 80 Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812
Component: 80 Tõrsteuer.HR KLO 0009
01141 - Luggage Compartment Unlocking Switch (E165)
27-00 - Implausible Signal
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 E
Component: Radio NP2 0008
Coding: 04031
Shop #: WSC 05311
VCID: 221DEF286DD22FCB65F-513C
37-10 - Faulty - Intermittent
End----(Elapsed Time: 04:29, VBatt start/end: 11.8V/11.8V. VIgn 0.0V)------
