barbalatte
AUDI SQ5 - Is it Normal....
Guys, is it normal to have all these error codes pop up?
I cleared them about 6 months ago.
Saturday,20,June,2020,18:12:37:63594
VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
VIN: WAUZZZ8R9DA071750 License Plate:
Mileage: 85360km-53040mi Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 36 42 44 46 47 52 53 56 5F
62 6C 6D 72 A9 C0
VIN: WAUZZZ8R9DA071750 Mileage: 85360km-53040miles
0F-Digital Radio -- Status: Cannot be reached 1100
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 HW: 4G0 907 589
Component: 3.0BTD EDC17 H24 0001
Revision: 57H24---
Coding: 2A2A4032252603020000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30BTD0118K5907589 001004
ROD: EV_ECM30BTD0118K5907589.rod
VCID: 7EA5022DD078F357B89-802A
Part No SW: 8R0 927 158 AE HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1002
Revision: --H16---
ASAM Dataset: EV_TCMAL551211 002020
VCID: 00597CD5AA8C85A7CA5-8054
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AB HW: 8R0 907 379 AB
Component: ESP8 quattro H09 0050
Coding: 245D0C01
Shop #: WSC 06335 000 00000
VCID: 00597CD5AA0C85A7CA5-8054
Part No SW: 8K0 907 064 GR HW: 8K0 907 064 FR
Component: BCM2 2.0 H12 0633
Coding: 05B54040000000000000
VCID: 06556ACD8828AB97F09-8052
00956 - Key 2
Reset counter: 43
Mileage: 83690 km
Date: 2020.04.02
Time: 12:47:59
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01180220130830
Coding: 3625628080
VCID: 3A2DCE3D8C501F77C41-806E
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000555658602
Coding: 260080118134AFF0018140C300001D0D4F9DC70827090201000008004401030100000034000000
Shop #: WSC 06335 123 12345
VCID: 78A91435F2DCCD67F25-802C
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130124 H11 0050
Serial number: 90243015130121190815
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21003873
Coding: 03005C
Component: E1 - LDS H03 0031
Serial number: 00000000001302131026
Serial number: 30380296000000000001
03110 - Active Steering Control Module (J792)
Reset counter: 111
Mileage: 80679 km
Date: 2019.12.08
Time: 17:32:16
Address 0F: Digital Radio
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Serial number: 003JPD92UVBE
Coding: 304A3431313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48C9A4F5C23C7DE7425-801C
Serial number: 6334MSME74160A68F
Serial number: 6344MSME777301537
Serial number: 6352QSME5328476EQ
Serial number: 6362QSME6628377EV
Serial number: 63732SME712B4D688
Serial number: 63832SME582B3D7CI
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MBD000L6
Coding: 000037
VCID: 43D3B3D9FB9A5EBF977-8016
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 931 K HW: 8R0 920 931 K
Component: KOMBIINSTR. H35 0556
Revision: 00100000 Serial number: UWY24KC2E
Coding: B3AF220003010008010700
VCID: 3D27C5219D7E284FE13-8068
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y132138073
Coding: 80CD07FF00
VCID: 4ACD9EFDDCB08FF7541-801E
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000001461041901
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 13038002403011200410
02230 - Digital Radio (DAB) (R147)
Reset counter: 111
Mileage: 80679 km
Date: 2019.12.08
Time: 18:28:15
Bin. Bits: 11111
Voltage: 14.00 V
Count: 6
Bin. Bits: 10000
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000051749369
Coding: 01781B00000000000000
VCID: 42DDB6DDE48057B79C1-8016
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000051960460
Coding: 011D12205E01440004
VCID: 4FFB8FE927D2AADF03F-801A
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0013268912
Coding: 100000010001
Shop #: WSC 06334 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B23CB3983EA267FDF7-806E
Revision: 00002001 Serial number: 0301338329
Coding: 01040E2220B93095872005368004000F
Shop #: WSC 44406 123 104857
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813011164102
VCID: 2D07F5614D1EB8CF513-8078
Reset counter: 12
Voltage: 14.70 V
Temperature: 9.0°C
Temperature: 10.0°C
Bin. Bits: 00000100
Bin. Bits: 00001000
Bin. Bits: 00000000
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000052677644
VCID: 4EC592ED20D8A3D7089-801A
02117 - Motor for Mirror Folding
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 53
Mileage: 85282 km
Date: 2020.06.18
Time: 17:19:47
Fault Status: 00100111
Reset counter: 53
Mileage: 85359 km
Date: 2020.06.20
Time: 16:38:10
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001259528
ROD: EV_ParkiBrake_AU48.rod
VCID: 3829D435B2DC0D67325-806C
Part No SW: 4G1 035 053 G HW: 4G1 035 053
Component: Radio U Basic H41 0121
Revision: AB001007 Serial number: 227B30D7696709
Coding: 040003010000000001
VCID: 231313591BDA7EBFF77-8076
Part No SW: 8R2 035 754 B HW: 8R2 035 754 C
Component: H-BN-RW H45 0639
Revision: -------- Serial number: 210BP0D7509640
Coding: 1A0A01060205E1FF4780CB4E00000403FC0000020000000000
VCID: 3635DA0DB848FB17209-8062
Subsystem 1 - Part No: 8R0 060 884 AS
Component: ROW 2013 0506
Component: DU7 High H42 0104
Serial number: A130BL0D2659121
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001419569
Component: CD-Database 4949
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000052596016
Coding: 010C12204001240004
VCID: 46D5AACDC8A86B97B09-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2ZA1XA
Coding: 1020010
VCID: 3431E005A234E9071ED-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B23CB39836A267FDF7-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000052278425
Reset counter: 48
Mileage: 85056 km
Date: 2020.06.12
Time: 09:11:25
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 130201200540
VCID: 79AF1131C956D46F8DB-802C
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0002
Serial number: 130206200331
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 71BF291191269C2F35B-8024
0006 - Actuator 1 for Engine Noise Simulation
C113C 13 [008] - Open Circuit
Mileage: 80679 km
Date: 2019.12.08
Time: 17:32:16
End----(Elapsed Time: 01:55, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
VCDS Release 19.6.0: SRI Reset
Control Module Part Number: 8R0 920 931 K Labels: .8R0-920-xxx-17.clb
Component:KOMBIINSTR. H35 0556, Coding:B3AF220003010008010700
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 ---
40 Distance since Service km x100 13 ---
41 Time since Service Days 61 ---
42 Minimum Distance to Service km x100 150 ---
43 Maximum Distance to Service DIST x100 0 ---
44 Maximum Time to Service Days 730 ---
45 Oil Quality 1 ---
47 Soot Quantity DIST x100 34 ---
48 Thermal Load DIST x100 24 ---
49 Minimum Time to Service Days 730 ---
50 Basic Distance Value for Oil Change km x100 160 ---
51 Basic Time Value for Oil Change Days 365 ---
52 Basic Distance Value for Inspection km x100 160 ---
53 Distance since Inspection km x100 13 ---
54 Basic Time Value for Inspection Days 365 ---
55 Time since Inspection Days 61 ---
56 Day Counter Days 2670 ---
Address 09,8K0 907 063 DH,channel 37,adapted from,3,to,4,
Address 09,8K0 907 063 DH,channel 63,adapted from,0,to,2,
Address A9,8R0 907 159 ,channel IDE04472-Volume of structure-borne noise actuator,adapted from,100.0 %,to,100.0 %,
Address C0,8R0 907 160 ,channel IDE06804-Engine noise generation actuator volume,adapted from,100.0 %,to,100.0 %,
