Golf Mk7 manual ac tweak question. Possible?
Hello, all,
I had a ride in awful rain. Now i want that my manual ac OFF button worked as front window defoger (That function which climate control have. you push a window button and ac turn's on, the air starts blowing only to front window and with max speed). I almost crashed trying to find possition of flaps to blow air into window. Is that even possible??? Here's my autoscan (that falt is already gone ):
Thanks for replys.
Tom
Hello, all,
Wednesday,24,June,2020,10:16:44:12071
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZGW281735 License Plate: JFR405
Mileage: 64872km-40309mi Repair Order: patikrinimas_2020_06_24
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW281735 Mileage: 64872km-40309miles
Address 01: Engine (J623-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 6336
Revision: 22004001
Coding: 01114012430411092000
ASAM Dataset: EV_ECM16TDI03004L906056CL 004011
ROD: EV_ECM16TDI03004L906056_004.rod
VCID: 79AFEBA7495BA0B3145-802C
Readiness: N/A
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 90476000013399
Coding: 01FA62A12428096D077E060341C82580462490E06082A4F300400078C002
VCID: 7EA5F8BB5075878B217-802A
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 T HW: 5G0 907 426 T
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00020104202100001000000000000002
VCID: 3C2132B306E9559B4F3-8068
Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
329220 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Reset counter: 184
Mileage: 63323 km
Date: 2020.06.12
Time: 08:45:46
Voltage terminal 30: 11.9 V
Outside air temperature: 19.5 °C
Air distribution flap: actual value: 223
Air distribution flap: actual value: 73.0 %
Air distribution flap: specified value: 78
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061606701128
Coding: 00000842C20100530BA44080B10403081000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 025D8C4B248DE36B45F-8056
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160228 043 0551
Serial number: 160305010014
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY113040EGL
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000064966215
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1JNEG
VCID: 41DF4347610B38731C5-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 803 16
Serial number: 357670000008C328C91/
Subsystem 2 - Part No SW: ----------- HW: 480 001 403 16
Serial number: 3586700000092244A91R
Subsystem 3 - Part No SW: ----------- HW: 480 401 203 16
Serial number: 3516502B9200CA04217.
Subsystem 4 - Part No SW: ----------- HW: 480 401 203 16
Serial number: 3526502C31F93A04A37E
Subsystem 5 - Part No SW: ----------- HW: 480 401 103 16
Serial number: 3556502B11F3539262B9
Part No SW: 5Q0 953 507 GB HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 15031604220935
Coding: 0600
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 7CA1F2B34669959B0F3-8028
Part No SW: 5G1 920 741 A HW: 5G1 920 741 A
Component: KOMBI 202 6420
Coding: 07A41A002380000801080A001400000000000000
VCID: 2517F7D79563F45300D-8070
Part No SW: 5Q0 907 530 AG HW: 5Q0 907 530 D
Component: GW MQB Low 126 1244
Revision: -------- Serial number: 0004640316
Coding: 030000041F087300FB000048080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 76B5E09B7845CFCB797-8022
Subsystem 2 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 4481909503
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 071115BK618589
Coding: 003002208000040100001000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0103
VCID: 44D14A537E192D5B373-8010
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 021115BJV04229
Coding: 003000208000040100801000
VCID: 40D946436A01317B13B-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 5G0 035 867 C HW: 5G0 035 867 C
Component: MU-E--ER 851 6490
Serial number: 11031600010494
Coding: 02730000FF0000004011000100010000000000040000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW37.rod
VCID: 2C0102F3F689C51BDF3-8078
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.2V)-----------
Thanks for replys.
Tom
