2012 Audi A4 2.0T Quattro EA888 Gen 3 engine
A4 RICH
Texas, USA
C?ID=391643
I think I drowned my AUDI... can anyone help me to with what I should do firstly...
ITuesday,23,June,2020,14:37:53:40587
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUKFAFL2CN006207   License Plate:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 40 42 46 47 52 53 55
          56 5F 62 6C 72
VIN: WAUKFAFL2CN006207   Mileage: 211680km-131531miles
40-AC Compressor -- Status: Cannot be reached 1100
47-Sound System -- Status: Malfunction 1010
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0002
   Revision: E1H20---
   Coding: 0104010A290F0160
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74B1DB27EE32C71B473-8020
          U1113 00 [047] - -
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 05:51:55
                    Engine speed: 1452.50 /min
                    Normed load value: 32.9 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 11.803 V
5663 - Mass Air Flow Sensor (G70)
          P0102 00 [096] - Signal too Low
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 05:51:55
                    Engine speed: 1163.50 /min
                    Normed load value: 82.4 %
                    Vehicle speed: 17 km/h
                    Coolant temperature: 97 °C
                    Voltage terminal 30: 11.991 V
4000 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
          P1297 00 [101] - -
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 05:51:57
                    Engine speed: 1668.00 /min
                    Normed load value: 31.4 %
                    Vehicle speed: 18 km/h
                    Voltage terminal 30: 11.826 V
   Part No SW: 8K0 927 158 S    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H08 1003
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 46D551EFC82E058B297-8012
2505 - Torque Management Feedback Signal A
          P2637 00 [047] - -
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 05:51:58
                    Voltage terminal 30: 11.749 V
                    Transmission output speed: 501.00 /min
                    Driving position: d
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                    Transfer speed from ESP: 20.92 km/h
                    Transfer speed from ESP: valid
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D0D18
   Shop #: WSC 02391 823 56573
   VCID: 025D8DFFA406F9AB45F-8056
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 223
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 05:51:55
                    Hex Value: 0x1000
                    Hex Value: 0x4006
                    Hex Value: 0x1226
                    Hex Value: 0x4697
                    Hex Value: 0x00FF
                    Reset counter: 223
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 05:51:56
                    Hex Value: 0x1100
                    Hex Value: 0x6206
                    Hex Value: 0x1232
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CH    HW: 8K0 907 064 CH
   Component: BCM2 2.0      H05 0435
   Coding: 0D0100
   Shop #: WSC 02399 823 56573
   VCID: 78A9EF17F2DAA37B6BB-802C
   Serial number: 2311000153674011
   Revision: C1000000    Serial number: 01250720111245
   Coding: 64102000
   VCID: 005987F7AA0AEBBB53B-8054
01273 - Fresh Air Blower (V2)
                    Fault Status: 00101001
                    Fault Frequency: 30
                    Reset counter: 8
                    Mileage: 211458 km
                    Date: 2020.06.19
                    Time: 19:09:02
                    Temperature: 35.0°C
                    Speed: 21.0 km/h
                    Voltage: 2.60 V
                    Current: 0.000 A
                    Voltage: 13.00 V
01844 - Control Module for Fresh Air Blower (J126)
                    Fault Status: 00101110
                    Reset counter: 7
                    Mileage: 211459 km
                    Date: 2020.06.19
                    Time: 19:10:32
                    Temperature: 34.0°C
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000984205
   Coding: 26001091073CAF010000080300003D0D0F1C520802010161000000
   Shop #: WSC 12345 123 61029
   VCID: 3C21330786624F5B4F3-8068
   Component: WWS 220711  H07 0070
   Serial number: SWF11070226607
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11545416
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000407110966
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0081
   Revision: 11001001    Serial number: 36891119209461
   Coding: 200103
   Shop #: WSC 26116 444 13914
   VCID: 4ACD65DFDCB6E1EBCDF-801E
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0NU0G-
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 45D756E3F5280E9320D-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R110000609V
   Serial number: 6334MSME62120F0A9
   Serial number: 6344MSME607370726
   Serial number: 6352QSME335D0852G
   Serial number: 6362QSME102E127CH
   Serial number: 63732SME3E5C3768E
   Serial number: 63832SME430B4A5C6
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KGJ001KZ
   Coding: 000036
   VCID: 3D273E039D78465378D-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
   Component: KOMBIINSTR.   H70 0402
   Revision: 00000000    Serial number: KI0157E7C
   Coding: 831F09000B00D705020000
   VCID: 3333183BAB3C80239E9-8066
   Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0117
   Revision: FC100058    Serial number: 5800F1170201BE
   Coding: 00C303
   VCID: 04518BE7BE12F79B773-8050
   Component: J367-BDM  H07 0170
   Serial number: 1102AA88180711
03408 - Control Module for A/C Compressor
                    Reset counter: 217
                    Mileage: 211454 km
                    Date: 2020.06.19
                    Time: 18:48:54
                    Bin. Bits:    01111
                    Voltage: 13.20 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 25.40 s
                    Reset counter: 8
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 06:07:00
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 10
                    Bin. Bits:    10011
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 8
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 06:31:23
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 7
                    Bin. Bits:    10011
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00000006355400
   Coding: 00581B00000000000000
   VCID: 3B23301B836C4863469-806E
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0000001
   VCID: 3C2133078A624F5B4F3-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F10.07.1100H010003C320690ÿ
   Subsystem 4 - Serial number: 320690ÿ
Address 40: AC Compressor
Address 46: Central Conv. (J386)       Labels: None
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C13204E00410001
   VCID: 53F378BB0BFCA023BE9-8006
Address 47: Sound System        Labels:
   VCID: 55F786A30C08BE1350D-FFFE
Address 52: Door Elect, Pass.        Labels:
Address 53: Parking Brake
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 C    HW: 8H0 907 357 C
   Component: AFS 1           H01 0040
   Revision: 00H01001    Serial number:
   Coding: 0000019
   VCID: 323D1D3F5826892B95F-8066
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H02 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH02 S001
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H52 0076
   Revision: AB001007    Serial number: 156G$0B7535238
   Coding: 020007010000000001
   VCID: 1F1BE48B37B434434A1-804A
   Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
   Component: H-BN-NA       H52 0165
   Revision: --------    Serial number: 490G-0B7629510
   Coding: 010200000006A1EF51000B0E000000030000
   VCID: 392F2A1389507A73545-806C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466G$0B0620787
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000882389
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
                    Reset counter: 8
                    Mileage: 211687 km
                    Date: 2020.06.23
                    Time: 06:30:53
                    Voltage: 12.20 V
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C13204000210001
   VCID: 56F581AF180EB50B597-8002
   Revision: --H05---    Serial number: 525PA8-J1X90LE
   Coding: 1000006
   VCID: 38292F17BE5A637BABB-806C
   Component: TSG HR        H06 1501
End----(Elapsed Time: 01:53, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
