Audi A4 B8 Died, Not starting & no codes
Ford5030
Ireland
C?ID=329762
Hi all,
Looking at a 2008 Audi A4 B8 which has us scratching our heads, The owner started the car one morning, pulled out of his laneway and got about 50 metres down the road and the car died, just slowed to a stop on the road like the key was pulled out.
He got the car pulled back to his house now where it's being sitting a week and its refusing to start, I tried cranking it over with jump leads on to make sure its not a power problem and its definitely getting fuel since we pulled the fuel line going to the filter and its flowing plenty diesel.
He only has one key for the car and its the type that you slot into the dash. I'm thinking it could a immobilizer problem but I don't know if there would be a immobilizer fault light on the dash if its not working.
Other things I'm thinking of is something like air in the fuel system (Fuel Rail?) after the filter causing it to airlock but I'd think it should throw some kind of code if it was.
I've a auto scan attached and another after I cleared codes to see what's new but the fault codes showing up I don't think are related with the problem. Perhaps they are but I'm not sure.
1st Scan
VIN: WAUZZZ8K68A037984   License Plate: 08DL11452AUDIB8
Mileage: 280220km-174120mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72
VIN: WAUZZZ8K68A037984   Mileage: 280220km-174120miles
Address 01: Engine (J623-CAGA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 B    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 3210
   Revision: --H01---
   Coding: 0104002C18072018
   ASAM Dataset: EV_ECM20TDI03L906022B A01014
   ROD: EV_ECM20TDI03L906022.rod
   VCID: 2411113E7E5961AB173-8070
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [039] - Electrical Fault
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 08:04:36
                    Engine speed: 0.00 /min
                    Coolant temperature: 11 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.440 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 11440 mV
                    Coolant temperature: 11.7 °C
                    Glow status-Bits 0-7: 0
                    Preheat time: 2000 ms
                    Fuel temperature: 10.9 °C
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [039] - Electrical Fault
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 08:04:36
   Part No SW: 8K0 907 379 AQ    HW: 8K0 907 379 AQ
   Component: ESP8 front    H03 0210
   Coding: 160500
   Shop #: WSC 06325 000 00000
   VCID: 0849658EE231A5CB1BB-805C
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0134
   Coding: 031100
   VCID: 3039ED6E3A21CD0BE3B-8064
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0608000005294005
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000006585011
   Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D0000000    Serial number: 0113.03.080335
   Coding: 34040000
   VCID: 3C21C95EE669396B4F3-8068
                    Reset counter: 38
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 07:53:21
                    Temperature: 12.0°C
   Part No SW: 8K0 907 063     HW: 8K0 907 063
   Component: BCM1 1.0      H21 0253
   Revision: 01021001    Serial number: 00000000015024
   Coding: 690040B10014A7000001000000005F5F001D020800000141000000
   VCID: 6C81391ED68969EB9F3-8038
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 200308  H05 0060
   Serial number: SWFBIE 0000520
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10086319
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002103080489
                    Reset counter: 38
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 07:53:00
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330808906488
   Coding: 000003
   VCID: 3829D54ED251154BABB-806C
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD143MSF
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C21C95EE6E9396B4F3-8068
   Serial number: 6334MSME480063723
   Serial number: 6344MSME3853230CA
   Serial number: 6352QSME5B0C355BT
   Serial number: 6362QSME5A571903I
   Serial number: 63732SME5470301DW
   Serial number: 63832SME5D4B107FD
   Component: Lenks.Modul   H11 0012
   Revision: --------    Serial number: 90304HCR0001E
   Coding: 000012
   VCID: 3D27C45AFD73306378D-8068
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H15 0221
   Revision: 00000000    Serial number: 7BY19CW38
   Coding: 2F04080002002600010000
   VCID: 313FE86A312BC403EC5-8064
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G08307805D
   Coding: 000303
   VCID: 46D5ABB6A8A573BB297-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
   Serial number: 1800DA59110308
                    Reset counter: 78
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 07:50:00
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000006947945
   Coding: 011002204001410001
   VCID: 40D9BDAE8A815D8B13B-8014
   Revision: 00002001    Serial number: 0110340950
   Coding: 011B062200390440002001
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
   Component: DSP Prem      H13 0210
   Revision: 00013001    Serial number: 34833000803204
   Coding: 0203010301
   VCID: 3E25C356F0752B7B617-806A
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000006863703
   VCID: 3FDBBE52F77F22736A1-806A
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 00000000097431
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 B    HW: 8T2 035 186 B
   Component: Concert3      H11 0150
   Revision: 00000512    Serial number: AUZ5Z6H1038960
   Coding: 0003008001010D00035B070000
   VCID: 372BD672DF4F1A33A21-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000006957261
   Coding: 010002204001210001
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101025093
   VCID: 44D1B1BE9E9941AB373-8010
End----(Elapsed Time: 01:25, VBatt start/end: 11.5V/11.6V. VIgn 11.5V)-----
The second scan where I had codes cleared and had jump leads on.
   Revision: --H01---
   Coding: 160500
   Coding: 031100
   Coding: 34040000
                    Reset counter: 38
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 08:28:16
                    Temperature: 12.0°C
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 38
                    Mileage: 280220 km
                    Date: 2020.06.22
                    Time: 08:28:00
   Coding: 000003
   Coding: 000012
   Coding: 000303
   Coding: 0203010301
   Component: Display
End----------(Elapsed Time: 01:23, VBatt start/end: 13.3V/13.3V)-----------
I know the 2 previous owners who had the car going back 5 years or more, they are very particular about cars and would be on the button with the service schedule and looked after the car very well.
Any suggestions on what to check first or advice would be helpful.
All the best.
Ford5030
Ireland
C?ID=329762
Thanks for spotting that, I completely missed checking to see if it was giving a good signal, got a fuel rail low pressure code and was concentrating on finding the cause, Gonna get a sensor tomorrow and try it out, fits all the cars symptoms.
I let you's know how I get on.
Thanks, Michael
I'm not sure I'd read to much into the "Crankshaft speed (RPM): 0.0 /min" since it's associated with Glow Plug faults, but of course it doesn't hurt to check that the ECU can see the engine being cranked, because if it doesn't, it sure won't do the the things it needs to do to start the engine.
Ford5030
Ireland
C?ID=329762
Used Measuring blocks to check engine RPM sensor, both are showing the car engine turning over when trying to start so I'm doubtful it's the cause of it, had a good look at the wiring harness, no obvious signs of it being worn or chaffing at any points.
Was looking at the values for fuel pressure but I wouldn't have a great understanding of what it should be showing. Got a quick log of the car, I can get more detailed information if I knew what I should look for. What I noticed was specified pressure vs. actual, I know this could be very different when the cars running but I thought it was noteworthy.
I didn't get much time with the laptop but I'll be able to get more detailed logs tomorrow.
