AUDI A8 2009 (Acc/Start Auth controller issue - not responding/can't scan
dan0412
C?ID=127497
Hello:
Posting here to get some assistance as to what the issue could be. Earlier this afternoon, I noticed the MIL on (not blinking), so rushed back to scan the car. I did notice the P2189 error - Bank 2; System too Lean at Idle. However, what's more troubling is that VCDS can not access a number of modules - error is module "cannot be reached" , even though I confirm that the doors are unlocked. This was persistent even after I cleared the P2189 error. This is the very first time I am encountering this error. Another observation is that with these errors - I am unable to generate a complete scan; VCDS hangs/doesn't respond or is not able to connect to controllers - not sure what else to try; I'd like to do some more troubleshooting/diagnostics before taking the car in to the shop. Is this a VCDS version issue?
Thanks,
Sunday,21,June,2020,19:43:25:49820
VCDS Version: 20.4.1.0 (x64)
VIN: WAUMV94E19N001121   License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 38
          42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
38-Roof Electronics -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (   )       Labels:. 079-907-560-BVJ.clb
   Part No SW: 4E1 910 560 J    HW: 4E1 907 560
   Component: 4.2l V8/4V          0010
   Revision: 71H22---    Serial number: AUX3Z0H4750035
   Coding: 01060009190F0120
   Shop #: WSC 02313 785 00200
   VCID: 29530374803BBECE7C-807C
008585 - Bank 2; System too Lean at Idle
               P2189 - 004 -  - MIL ON
                    Fault Status: 11100100
                    Mileage: 150278 km
                    Date: 2020.06.17
                    Time: 13:38:23
                    RPM: 676 /min
                    Load: 38.0 %
                    Temperature: 108.0°C
                    Temperature: 60.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.335 V
   Part No SW: 4E1 910 156 C    HW: 09L 927 156 A
   Component: AG6 09L 4,2lFSI USA 0030
   Revision: --H01---    Serial number:        4455926
   Coding: 0000002
   VCID: 234F115CE217649E36-8076
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 J    HW: 4E0 614 517 BQ
   Component: ESP 5.7 allrad  H49 0540
   Coding: 0007597
   Shop #: WSC 02313 000 00000
   VCID: 2A51FC78853DB5D675-807E
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 C
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0H4750035
   VCID: 58B576B0EBD1F74613-FFFE
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 2040
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   VCID: 244D1240E71963A64F-FFFE
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 732 T    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 348EX087529325
   Coding: 0000003
   VCID: 336FE11C52F7F41EC6-8066
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000066329
   Subsystem 3 - Serial number: 0119.05.080000000100010026ÿ
   Subsystem 4 - Serial number: 010026ÿ
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 49
                    Mileage: 149749 km
                    Date: 2020.03.08
                    Time: 20:21:25
                    Bin. Bits:  0000010
   Part No: 4E0 910 043 B
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000149357
   Coding: 0102737
   VCID: 1C3D2AA0DF695B66F7-FFFE
Second scan...
Sunday,21,June,2020,21:41:25:49820
VIN: WAUMV94E19N001121   Mileage: 150340km-93416miles
Readiness: 0110 1101
   Coding: 0000002
   Coding: 0007597
   Component: ELV                 2040
Address 09: Cent. Elect.
Address 0E: Media Player 1
dan0412
C?ID=127497
I replaced the battery in the key fob but still cannot scan/connect to module 05.
I will like to rollback the VCDS update.....how can I get the prior version? I want to be sure this is unrelated to the interface (HEX+CAN) or version.
What do you mean you can't scan 05? It's plainly there in both scans you posted.
The inability to complete scans strikes me as more likely to be a PC problem; USB subsystem going to sleep? Make sure USB Selective Suspend is disabled as shown here.
If you wish to try an previous version, let me know which version you were using previously. However, we have no other reports like that, so I really doubt that this is the problem.'
dan0412
C?ID=127497
Hello Uwe, I should have elaborated. The scan stops (hangs) when it gets to module 05... I always have to hit the cancel button for the autoscan to proceed / abort. (If you notice, it doesnt say "no fault code found". I have a Windows 10 laptop; will try the USB Selective Suspend workaround to see if it works and report back.
Thanks.
