2016 Tiguan 4MotionS Factory Trailer Hitch Needs Coding
rcrowell
C?ID=273550
Good afternoon all!
I installed the factory trailer hitch and wiring plug adapter, and attempted to have the system initialize but there is no drop-down menu for the 2016 Tiguan.
Can someone please assist (with long coding if needed)?
The only modification to the car is a factory 2017 Tiguan radio w/Apple Carplay that was "patched" to allow it to work with the 2016 electronics.
Thank you in advance very much!
Rich
Friday,19,June,2020,16:59:59:09951
VCDS Version: 20.4.1.0 (x64)
VIN: WVGBV7AX3GW576621   License Plate: 6BTX80MA
Mileage: 61140km-37990mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 42 44 46 4C 52 53 5F
          62 69 72
VIN: WVGBV7AX3GW576621   Mileage: 61140km-37990miles
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 JP    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 1335
   Revision: P3H08---    Serial number:
   Coding: 0423010A190F0160
   VCID: 022570AE5D29CE961D-8056
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2627
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 073361BA760BEBBE4A-8052
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VD6E 0021
   Revision: --H07---    Serial number: 00000009078976
   Coding: 0005161
   VCID: 78D112460BF5944633-802C
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Fault Frequency: 18
                    Reset counter: 110
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 17:49:06
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 303
                    Hex Value: 0x0000
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0389578479
   Coding: 030C0C
   VCID: 3753D17A8E6B5B3EFA-8062
   Part No SW: 561 907 426 G    HW: 561 907 426 G
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1F6319DA069B037E12-804A
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
   Component: BCM PQ35 B    122 0183
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11400044448510086566D8DF064800000A040
   VCID: 3D5FC352A457716E20-8068
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 011215  24  0664
   Coding: 009795
   Component: RLS 141215 05  54  0403
   Coding: 02304D
                    Reset counter: 104
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 17:49:08
                    Voltage: 11.85 V
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAPRJW86N
   Coding: 0012341
   VCID: 7DDF035224D7B16E60-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000PQE3
   Subsystem 3 - Serial number: 0019.10.150000300000650044ÿ†63
   Subsystem 4 - Serial number: 650044ÿ†6332MTS6864331252ÿ†63
   Subsystem 5 - Serial number: 331252ÿ†6342MTS6296731256ÿ†63
   Subsystem 6 - Serial number: 731256ÿ†6351HTS6J5ED4EKJVÿ†63
   Subsystem 7 - Serial number: D4EKJVÿ†6361HTS6VCM53EKJ7ÿ†63
   Subsystem 8 - Serial number: 53EKJ7ÿ†63727TS6JT9B3EKJ/ÿ†63
   Subsystem 9 - Serial number: B3EKJ/ÿ†63827TS6OCLA3EKR5ÿ
   Subsystem 10 - Serial number: A3EKR5ÿ
   Part No SW: 5K0 953 501 DM    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20151215200213
   Coding: 1102140000
   VCID: 78D11246C3F5944633-802C
   Serial number: 0933045
   Coding: 820000
   Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
   Component: KOMBI         H04 1008
   Coding: 211F010000
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3D5FC352AC57716E20-8068
13654560 - Databus
                    Reset counter: 104
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 17:49:01
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1663
   Revision:   H57       Serial number: 141115F1001566
   Coding: 356022
   VCID: 022570AE9D29CE961D-8056
                    Reset counter: 104
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 18:03:55
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00016.11.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 528580EE05C99E16ED-8006
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6AF5380E8D5936D6B5-803E
   Revision: 00000000    Serial number: 15000260702002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW31.rod
   VCID: 3041EA666B058C06BB-8064
   Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0601
   Revision: 13100010    Serial number: 0010185509
   Coding: 0004B4
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 3A55C84EBD79465605-806E
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009635858
   Coding: 000490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.285 1401
   Revision: 1BH04841    Serial number: 00153210176901
   Coding: 0000258
   VCID: 41A7BFA218AF158E44-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0010265949
   Coding: 0004B4
   VCID: 3957D742B87F4D4E0C-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009648063
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000993370
   Coding: 0026156
   VCID: 3851D2464B755446F3-806C
   Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
   Component: MU-S-S-US     H31 0359
   Serial number: VWZAZ2S0600954
   Coding: 02130600FF00000011220001001808009F0100D40020010002
   Shop #: WSC 00040 028 00056
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 140946F6FF5D5026BF-8040
8 Faults Found:
          B11CF 53 [009] - Deactivated
                    Reset counter: 94
                    Voltage terminal 30: 12.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
0513 - Rear Right Treble Speaker
          B1068 13 [008] - Open Circuit
                    Reset counter: 144
                    Voltage terminal 30: 11.5 V
0518 - Front Right Treble Speaker
          B1064 13 [008] - Open Circuit
                    Reset counter: 144
0521 - Connection to Front Right Loudspeakers
          B110A F0 [008] - Short Circuit Between Poles
                    Reset counter: 141
                    Mileage: 61003 km
                    Date: 2020.06.13
                    Time: 11:32:17
                    Voltage terminal 30: 12.5 V
0523 - Front Left Treble Speaker
          B1061 13 [008] - Open Circuit
                    Reset counter: 144
0528 - Rear Left Treble Speaker
          B1066 13 [008] - Open Circuit
                    Reset counter: 144
0009 - Antenna for Satellite Radio
          B10F4 13 [009] - Open Circuit
                    Reset counter: 95
6714 - Databus
                    Reset counter: 78
                    Network diagnosis-Status: Enabled
Address 69: Trailer
End-------------------------(Elapsed Time: 02:20)--------------------------
Since both the vehicle's Gateway and VCDS report that 69-Trailer "Cannot be reached", I think you have hardware (wiring or power supply) issues that need to be resolved before you worry about coding things. I mean it makes no sense trying to code in a module that the rest of the car can't talk to.
rcrowell
C?ID=273550
Uwe, I inadvertently assumed that the 2016 Tiguan would have the trailer module pre-installed when I saw the trailer harness plugged into a dummy receptacle at the rear bumper.
I hooked up the harness to the 7 pin receptacle and figured that I was good to go.
Getting the trailer module and jumper on order today, then I should be in business.
I went through this very exercise a few years ago with a 2011 Tiguan...
Thank you very much!
rcrowell
C?ID=273550
Now it seems to be a coding issue?
UPDATE:
Purchased the trailer control module and jumper wire kit from VW; ran the Ross-Tech software; checked the "trailer" box in the software; and figured I'd be good to go.
Next day I hooked up my small boat trailer and all lights worked except brake lights.
Dash light indicator that there is a bulb failure is lit with trailer connected.
Disconnect trailer - bulb failure indicator is extinguished.
Went to Home Depot to borrow a small utility trailer - same exact symptoms.
I double checked continuity through the 3-way jumper - OK.
Purchased a 4-pin LED trailer light tester - shows that one side of car lights are inoperative (even though they were working with 2 actual trailers) and brake lighting inoperative.
I ran the Ross-Tech self-test with the 4-pin tester installed:
Monday,29,June,2020,17:09:08:09951
          62 69 72
VIN: WVGBV7AX3GW576621   Mileage: 61470km-38195miles
09-Cent. Elect. -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
   Coding: 0000840
   Component: J104   C6 450M VD80 0021
   Coding: 0005161
                    Fault Frequency: 53
                    Reset counter: 161
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 17:49:06
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 303
                    Hex Value: 0x0000
02214 - Tire Pressure Warning
                    Reset counter: 167
                    Mileage: 61440 km
                    Date: 2020.06.28
                    Time: 13:49:32
                    Speed: 97.0 km/h
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Coding: 030C0C
133124 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:31
   Revision: 00001K02
   Coding: 0010001002
   Revision: BG122001
   Coding: 009795
   Coding: 02304D
                    Reset counter: 167
                        Term 15 Off
                    Voltage: 12.85 V
                    Reset counter: 161
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 17:49:08
                    Voltage: 11.85 V
                    Fault Status: 00101010
                    Reset counter: 161
                    Mileage: 61209 km
                    Date: 2020.06.23
                    Time: 19:43:36
                    Voltage: 14.00 V
   Coding: 0012341
   Coding: 1102140000
   Coding: 820000
   Coding: 211F010000
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:31
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:33
13654560 - Databus
                    Reset counter: 161
                    Mileage: 61075 km
                    Date: 2020.06.16
                    Time: 17:49:01
   Coding: 356022
                    Fault Status: 00110100
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:31
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:31
   Coding: 0001
   Coding: 000007
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:31
                    ELV State: 0A
                    Information Clamps: 88 08
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 6F
12665089 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:32
                    ELV State: 0A
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 6E
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
68098 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:32
68100 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 167
                    Mileage: 61460 km
                    Date: 2020.06.28
                    Time: 16:25:32
   Coding: 0026156
8 Faults Found:
                    Reset counter: 94
                    Reset counter: 144
                    Reset counter: 144
                    Reset counter: 141
                    Mileage: 61003 km
                    Date: 2020.06.13
                    Time: 11:32:17
                    Reset counter: 144
                    Reset counter: 144
                    Reset counter: 127
6714 - Databus
                    Reset counter: 78
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000446146972
   Coding: 0100000100000000
   VCID: 3041EA6663058C06BB-8064
02564 - Trailer; Left Tail Lamps (M60)
                    Fault Status: 11101010
                    Reset counter: 128
02562 - Trailer; Brake Lamps
                    Reset counter: 128
End-------------------------(Elapsed Time: 02:14)--------------------------
Thanks again in advance for thoughts!
Looks like you haven't coded the trailer module itself yet?
I would try something like:
020D000100000000
PS: Please clear out the mess of Intermittent faults in all the other modules.
rcrowell
C?ID=273550
020D000100000000
That was it - Thank you very much Uwe!
