2018 Seat Arona ACC Coding error
PDL
C?ID=142189
Hi, I am trying to code a 2018 Seat Arona ACC module 13: Auto Dist. Reg which has been replaced due to an accident.
After removing the comp prot, left with a coding fault.
3 faults in Airbag too, but no airbag light.
Any help grateful.
regards PDL
Friday,19,June,2020,09:30:27:41343
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: VSSZZZKJZKR077867   License Plate: NATHAN
                Address 13: Auto Dist. Reg       Labels: 2Q0-907-572.clb
Control Module Part Number: 2Q0 907 572 M    HW: 2Q0 907 572 B
  Component and/or Version: ACCCONTIMQB   H02 0233
           Software Coding: 3200000340FF8728749C8144004087
            Work Shop Code: WSC 00049 770 00100
              ASAM Dataset: EV_ACCMRRCONTIVW376 002012 (SE27)
                      VCID: 3E2539AD40FDA20B617-806A
201217 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING2SWAP_GRP_ACC_TYPE]
                    Reset counter: 103
                    Mileage: 6488 km
                    Date: 2020.06.13
                    Time: 11:09:43
                    Voltage terminal 15: 14.8 V
                    Control Module temperature: 65 °C
                    Longitudinal_acceleration_vehicle_reference: 0.13 m/s²
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF8728749C8144004087,to,3200008340FF8728749C8144004087,(00049/770/00100),
Address 13: DTCs cleared
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200008340FF8728749C8144004087,to,3200000300FF8728749C8144004087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000300FF8728749C8144004087,to,3200000340FF8328749C8144004087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF8328749C8144004087,to,3200000340FFC728749C8144004087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FFC728749C8144004087,to,3200000340FF8700749C8144004087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF8700749C8144004087,to,3200000340FF87000303818C000087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3200000340FF87000303818C000087,to,2100600140FF8728749C8145004087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,2100600140FF8728749C8145004087,to,3100600340FF8728749C8145004087,(00049/770/00100),
Address 19,3Q0 907 530 AA,recoded (Long Coding-exp),from,030100046F085700E90002581C0F00010001070000000000000000000000,to,030100046F085700E90002481C0F00010001070000000000000000000000,(131071/1023/2097151),
Address 19,3Q0 907 530 AA,recoded (Installation List),from,01543C0000000600404090000000C80000,to,01547C0000000600404090000000C80000,,
Address 19: DTCs cleared
Address 19,3Q0 907 530 AA,recoded (Installation List),from,01547C0000000600404090000000C80000,to,01543C0000000600404090000000C80000,,
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3100600340FF8728749C8145004087,to,3304600340FF8728749C8145004087,(00049/770/00100),
Address 13,2Q0 907 572 M,recoded (Long Coding-exp),from,3304600340FF8728749C8145004087,to,3304E08340FF8728749C8145004087,(00049/770/00100),
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 44 55 5F D6 D7
VIN: VSSZZZKJZKR077867   Mileage: 6725km-4178miles
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 K    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6203
   Revision: D7H20000
   Coding: 0125003223641D081000
   Shop #: WSC 00049 770 00136
   ASAM Dataset: EV_ECM10TFS01104C906025K 002002
   ROD: EV_ECM10TFS011_AU27.rod
   VCID: 2809FFF5B2790CBB3BB-807C
   Part No SW: 0CW 300 043     HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501811188790
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 74B1DB853E31385B473-8020
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AF    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H34 0342
   Serial number: 08507977180929
   Coding: 8A0D4C573D4851B43204BC1C12E111A649344DE6226A24484454625445488865922CB26744562412222A462AA271D64FFD8E6BF2BF
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: 72BDDD9D4425366B55F-8026
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0501389811
   Coding: 112E0E0703
   Shop #: WSC 00049 770 00024
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D348592B1FCFE30E9-8016
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6F0 907 044 B    HW: 6F0 907 044 B
   Component: Climatronic   H03 0502
   Coding: 8101000008000100110008000240010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_004_SE27.rod
   VCID: 2615F1CDB86D1ACB097-8072
   Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0926
   Serial number: 00001833800047
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 303917958AA9447BE3B-8064
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S7Y18M11D30H19M28S26
   Coding: 00194D
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q2 959 881 D    HW: 2Q2 959 881 D
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000024569620
   Coding: 1F000F
   Subsystem 3 - Part No SW: 2Q2 959 882 D    HW: 2Q2 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000024262959
   Coding: 05000F
   Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY182880Q2Y
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000271532
   Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000025802748
   Coding: 1D0000
   Subsystem 7 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000025751589
   Coding: 050000
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318346
   Coding: 0371165851
   Shop #: WSC 43902 003 1048576
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_VW27.rod
   VCID: 51FF7211E1632D738C5-8004
   Component: ACCCONTIMQB   H02 0233
   Coding: 3304E08340FF8728749C8145004087
   Shop #: WSC 00049 770 00100
          U1014 00 [009] - -
                    Reset counter: 119
                    Mileage: 6725 km
                    Date: 2020.06.19
                    Time: 10:02:12
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 52 °C
                    Longitudinal_acceleration_vehicle_reference: 0.06 m/s²
   Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
   Component: Airbag VW22   006 0520
   Revision: --------    Serial number: 003XNPPQ2J1S
   Coding: 88CCC0C000000000585400CF008C00000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 5F9BA429A7B78B030A1-800A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 011 18
   Serial number: 35700000000038584538
   Subsystem 2 - Part No SW: -----------    HW: 454 002 011 18
   Serial number: 35800000000268314535
   Subsystem 3 - Part No SW: -----------    HW: 454 801 711 18
   Serial number: 351001CEAE716000000V
   Subsystem 4 - Part No SW: -----------    HW: 454 802 711 18
   Serial number: 3520000B3DA16000000B
   Subsystem 5 - Part No SW: -----------    HW: 454 802 608 17
   Component: FrontSensor_D  307 0189
   Serial number: 355008324B8100000007
1060614 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Fault Frequency: 9
                    Reset counter: 119
                    Mileage: 6488 km
                    Date: 2020.06.13
                    Time: 11:13:42
1060615 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_v_rel]
                    Fault Frequency: 9
                    Reset counter: 119
                    Mileage: 6488 km
                    Date: 2020.06.13
                    Time: 11:13:42
1060617 - Databus
          [NWD: 0x2AC SDF_PSF_01 error value SDF_PSF_CW]
                    Fault Frequency: 9
                    Reset counter: 119
                    Mileage: 6488 km
                    Date: 2020.06.13
                    Time: 11:13:42
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20181126400604
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BA3F0B9136F7723069-802E
   Part No SW: 6F0 920 790     HW: 6F0 920 790
   Component: KOMBI         615 1701
   Coding: 24A4091D2D880600018862091001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_SK25.rod
   VCID: 678BBCC97FE7C3C3F21-8032
   Component: GW MQB High   442 4366
   Revision: --------    Serial number: 0008873823
   Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
   ROD: EV_GatewNF_SK25.rod
   VCID: 6E85C9ED501D128BB17-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5F0 959 537 E    HW: 5F0 959 537 E
   Serial number: 000000000H0972191118
   Coding: 002000
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 100BD2EF
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000394272011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 313F129181A34D73EC5-8064
   Serial number: 0500742825
   Coding: 02011203
   ROD: EV_HREntryHella_SE27.rod
   VCID: 3D273EA14DFBB91378D-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0500665492
   Coding: 020112
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 M    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 621 6041
   Serial number: 0879188CB4J3383
   Coding: 010001010000000101010201010001010000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 078E000009200003
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DF42513103DDF31C5-8014
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5F0 035 874 A    HW: 5F0 035 874 A
   Component: MU-S-ND-ER    H50 0514
   Serial number: SEZAZ2U0878848
   Coding: 04120601960A000011110101008808212F0100F601200400C6
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE27.rod
   VCID: 270BFCC9BF6703C3321-8072
   Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
   Component: ABT_Std-2_Nav  H53 8130
   Serial number: SEZ6ZHV3360428
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 7EA5F9AD007D620B217-802A
   ROD: EV_LEDPLUSRightKEBODVW416_VW27.rod
End----(Elapsed Time: 01:28, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
golfi_vend
Tartu, Estonia
C?ID=195131
I don't get it....If You had Online Link with car, why didn't You use SWC function to recode car?
You may also need parameters that can be obtained via Online link.
PDL
C?ID=142189
I didn't remove comp protection. ODIS wouldn't code ACC module. That's why Im asking for help.
downtime
Finland
C?ID=280813
And FeC was returned as well? To me it looks like it’s complaining about missing or incorrect FeC in radar.
If the radar is exactly as the original one, like golfi_vend wrote, online swc works if the radar type is what is expected for your car.
PDL
C?ID=142189
Sorry. What is FeC?
Westbury, UK
Sorry. What is FeC?
See how FeC is bold, green and underlined? Hover your mouse over it and a popup will appear with an explanation.
TBAx
C?ID=287144
Doesn't work on mobile though
PDL
C?ID=142189
All sorted, owner had fitted incorrect ACC radar module.
