Golf_Rider
Pirate
Hi everyone,
I have a golf mk6 and the ABS and ESP lights came when I was slowly passing through a speed bump.
I first checked the suspension and I found that the rear right shock was leaking badly, so I replaced both rear shocks and I cleaned the rear right ABS sensor with pressurized air (i didnt remove the piece of the sensor that is bolted to the wheel bearing). Then I used the VCDS to read the faults (see below). Then I cleared the faults and the ABS and ESP lights were gone for that day. But on the next morning they were back again.
Could you please help me find out what do I need to do to solve the problem?
Regards
Regards
[b]Removed. Data from a clone/pirate copy of VCDS is not acceptable here.[/b]
