Static maximum speed limit
MDMA
South Africa
C?ID=6095
I went to ENGINE, and then ADAPTATION.
From the drop down menu, I selected Static maximum speed limit.
It had the value of 250 km/h and I put in 100 km/h to see if it would accept it.
It did!
I drove around and sure enough it restricted speed to 100 km/h.
Now when I try to set a higher number it will not update the speed.
it does say that a new value is accepted but does not change/update the limit.
Please help?
Thank you.
LN-TAL
Norway
C?ID=13729
Ups, sorry, but afak it is NOT possible to increase this value, only decrease it. From the ross-tech faq:
http://www.ross-tech.com/vag-com/cars/tdi.html
On some EDC-15 ECUs, this channel has a non-zero value in it like 190.
Yes, that's the "speed limiter". Don't mess with it!
It can only be adjusted downward, and it's one-way! You cannot increase the value, and if you decrease it, you're stuck with it.
So unless you want to permanently decrease your car's top speed, Don't mess with it!
If you do mess with it and your car ends up with a lower top speed than it had before, don't call us, don't e-mail us, and don't complain that we didn't warn you!
MDMA
South Africa
C?ID=6095
Thank you. If only I had read this before.
Too late now...
LN-TAL
Norway
C?ID=13729
Maybe the guys at RT has a solution, we better wait until they wake up. But I am also sure that if you contact a shop who does chip tuning, they can fix this for you. But as said: I really doubt it is possible to fix with VCDS.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Let's start with an Auto-Scan so we actually know which engine type etc. we're talking about, in addition please attach a control module map (adaptation) from the ECM.
MDMA
South Africa
C?ID=6095
Monday,16,February,2015,07:41:55:04480
VCDS Version: 14.10.1.1
Data version: 20150130
VIN: WVWZZZ16ZEM042726   License Plate:
Mileage: 11140km-6922mi   Repair Order:
Chassis Type: 16 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ16ZEM042726   Mileage: 11140km-6922miles
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 JF    HW: 03F 907 309 R
   Component: SIMOS10.12AH10 5417
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001900D6230400080000
   Shop #: WSC 00066 790 00016
   ASAM Dataset: EV_ECM12TFS02103F906070JF 004005
   ROD: EV_ECM12TFS02103F906070FS_VW32.rod
   VCID: 6FE8BBAAB68C8C5987A-803A
Readiness: 0010 0101
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: A33B20F8092600FCC51204E6901F0080A1100010
   VCID: 7EF696EEE9E6F5D11CC-802B
   Part No SW: 5C6 920 873     HW: 5C6 920 873
   Coding: 171B00
   VCID: 6BD0AFBA82947079AB2-803E
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 26021403000051
   Coding: 351003
   Shop #: WSC 00066 000 00000
   VCID: 79FC85F2F0C8D2E929E-802C
MDMA
South Africa
C?ID=6095
from my coding log file in the debug folder:
Address 01:03F 906 070 JF recoded (ADP-Individually adjustable maximum speed limit) from 250.0 km/h to 200 km/h Sunday,15,February,2015,19:51:03:04480
Address 01:03F 906 070 JF recoded (ADP-Individually adjustable maximum speed limit) from 200.0 km/h to 100 km/h Sunday,15,February,2015,19:51:44:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 250.0 km/h to 100 km/h Sunday,15,February,2015,19:53:42:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 260 km/h Sunday,15,February,2015,20:01:37:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 255 km/h Sunday,15,February,2015,20:01:59:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Sunday,15,February,2015,20:02:11:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Sunday,15,February,2015,20:02:43:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Monday,16,February,2015,07:37:37:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Monday,16,February,2015,07:38:33:04480
Address 01:03F 906 070 JF recoded (ADP-Static maximum speed limit) from 100.0 km/h to 250 km/h Monday,16,February,2015,08:06:50:04480
MDMA
South Africa
C?ID=6095
Monday,16,February,2015,07:37:52:04480
UDS Adaptation Channel: Static maximum speed limit
Stored value 100.0 km/h
Monday,16,February,2015,08:07:02:04480
MDMA
South Africa
C?ID=6095
To get a dump of the Control Module Map, see the following wiki page. You need to do a dump for controller "01". If you select CSV as the output format you can then just copy and paste the contents of the CSV file into a post.
Thank you GaryM and Sebastian,
;SW:03F-906-070-JF   HW:03F-907-309-R ---  Engine
;Component:SIMOS10.12AH10 5417	 Coding:001900D6230400080000
;EV_ECM12TFS02103F906070JF	4005	EV_ECM12TFS02103F906070FS_VW32.rod
;Monday	16	February
;VCDS Version: Release 14.10.1  Data version: 20150130
;VCID: 6FE8BBAAB68C8C5987A-803A
Activating and deactivating all development messages	not active
Activation of start-stop function	not active
Activation of static maximum speed limit	OFF
Chain elongation; initial values valid; exhaust bank 1	not active
Chain elongation; initial values valid; intake bank 1	active
Chain elongation; no. of valid initial values; exhaust bank 1	0
Chain elongation; no. of valid initial values; intake bank 1	5
Deactivate production mode	00 00 00
Deactivation of static maximum speed limit	00 00
Idle RPM correction	80
Individually adjustable maximum speed limit	100.0 km/h
Production mode	00 00 00
Protective function	Enabled
Static maximum speed limit	100.0 km/h
Timing deviation after chain replacement; exhaust bank 1	0.00 °
Timing deviation after chain replacement; intake bank 1	-0.75 °
Timing deviation after other repairs; exhaust bank 1	0.00 °
Timing deviation after other repairs; intake bank 1	0.00 °
Timing deviation; current value exhaust bank 1	0.00 °
Timing deviation; current value intake bank 1	-0.43 °
;Monday	16	February
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Well, guess it sucks being you now. If you had sticked to the "Individually adjustable maximum speed limit" you'd be able to reset/change that at any given time, yet with the "Static maximum speed limit" it is just that - static. Your best chance is finding a decent tuner who can fix that for you, other than that the official VW statement would be "purchase a new ECM".
MDMA
South Africa
C?ID=6095
Thank you.
For clarity, if i can find a tuner who can flash the ECU with a stock map, will that work?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Depends on where the setting is stored specifically, I would however advocate against a full reset since you don't want to loose all general settings and learned values if you could avoid it.
Zenerdiode
Newcastle, England
C?ID=24330
MDMA, I really feel for you. Imagine if you'd been in a parking lot and set it to 10km/h :eek::facepalm:
At least 100km/h (62mph) is reasonably useable.
What about that 'Deactivation of static maximum speed limit 00 00' channel? Anything you can put in there to, well, deactivate the static maximum speed limit?
MDMA
South Africa
C?ID=6095
That would not have been fun - Thank you Z.
I don't have much too loose so I can take a look at that channel.
RT, can you share any insight into this channel?
Andy
Sector 7G
HC424490
I don't think any of us have any experience with trying that channel but as you said you don't have much to lose.
MDMA
South Africa
C?ID=6095
Thank you Andy
K__dub
C?ID=238429
Any luck with raising your speed limiter? I'm presently limited to approximately 165 and would like to raise it.
MDMA
South Africa
C?ID=6095
Could not be done with VCDS - I approached a leading tuner and at that stage even the base maps were not avail in the tuning databases.
So I returned the courtesy car ashamedly without taking responsibility for my deed.
If the ECU has been around for while, a tuner will be able to easily change your Vmax.
LN-TAL
Norway
C?ID=13729
How did this turn out in the end ? I MIGHT have found a solution to raise the static speed limiter again with VCDS, but no, I am not sure it will work so I wont try it with my own car :) If no one has a car with a speed limiter set to a unbelivable low setting, then I will have to buy another ecu for my A3 and try it out.
