2012 A3 8P - No communication with Instrument Cluster
izack98
Canada
C?ID=364881
The other day I started up my A3 and received a bunch of lighting faults displayed (brake lights, signal lights, DRL, Fog light). One of them being the RF headlight. Through searching forums I determined the lighting faults were as a result of the 30 amp fuse which controls the right BCM melted and caused the faults. This has been replaced and the lights work now. New fuse box on order now as the connector is melted somewhat.
As soon as that began to work the instrument cluster display stopped displaying (it had been working fine until this point). Another scan revealed a bunch of faults.
The cars ability to start has now been blocked by the immobilizer.
Battery is fully charged now. The scan indicates 11.8 volts but I have since fully charged the battery and load tested it.
I cleaned the ground terminals on the battery, engine and the body ground connections. All fuses on both fuse panels tested and appear to be fine. There is power on both sides of the Instrument cluster fuse. I have not tested for power at the cluster. Still working on a wiring diagram of the connector to determine which to test.
The faults associated to the radio, and telephone are due to an aftermarket stereo being installed.
Sunday,14,June,2020,14:48:31:41341
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUMFCFM8CAXXXXXX   License Plate:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 62
          72 77
VIN: WAUMFCFM8CA069610
0F-Digital Radio -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 8P0 907 115 BB    HW: 8P0 907 115 Q
   Revision: AAH18---    Serial number: AUX7Z0K9FN60QC
   Coding: 0103010A1C0F0160
   Shop #: WSC 59635 001 1048576
   VCID: 73B3DE82E7BF3F435E9-8026
               U0155 - 000 -
                    Temperature: 16.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.684 V
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - MIL ON
                    Fault Status: 11100000
                    RPM: 1461 /min
                    Load: 17.2 %
                    Temperature: 15.0°C
                    Temperature: 16.0°C
                    Voltage: 11.049 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 12.0°C
                    Temperature: 15.0°C
                    Voltage: 11.303 V
Readiness: 1110 0101
   Part No SW: 02E 300 013 Q    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2733
   Revision: 05351113    Serial number: 00001109200929
   Shop #: WSC 06314 000 00000
   VCID: 1F1BE2323BB7CB234A1-804A
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 255
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
01196 - Engine-Transmission Data Bus
17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
            P0702 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Reset counter: 8
   Revision: 00H31001
   Coding: 1150600F49280003881106E592190041390000
   VCID: 7BA3F6A2C3EF7703069-802E
                    Reset counter: 62
                    Count: 2
                    Count: 12
                    Count: 28672
                    Count: 8194
                    Count: 42752
                    Reset counter: 62
                    Count: 12
                    Count: 28672
                    Count: 8208
                    Count: 42496
                    Count: 1
03391 - Coding Not Possible
                    Reset counter: 62
                    Count: 12
                    Count: 28672
                    Count: 8254
                    Count: 43008
                    Reset counter: 62
                    Count: 12
                    Count: 28672
                    Count: 8211
                    Count: 43008
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0180
   Revision: 000020      Serial number: 8P0820043BN
   VCID: 79AFECAAC5D34513145-802C
                    Reset counter: 62
01301 - Control Module for Voice Recognition (J507)
                    Reset counter: 62
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0653
   Revision: 00110 AF
   Coding: 6E000A0FA01336E4287241E101100D4D407E62AA106DD928E40200840040
   VCID: 42DD4B46E485C6CB05F-8016
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
15 Faults Found:
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Fault Frequency: 74
                    Reset counter: 102
                    Mileage: 170534 km
                    Date: 2020.06.10
                    Time: 05:01:56
                    Voltage: 11.95 V
                        Term 50 Off
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101010
                    Fault Frequency: 44
                    Reset counter: 102
                    Mileage: 170534 km
                    Date: 2020.06.10
                    Time: 05:01:59
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 102
                    Mileage: 170562 km
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Fault Status: 00101001
                    Reset counter: 102
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 102
                    Mileage: 170562 km
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Reset counter: 102
                    Mileage: 170562 km
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 102
                        Term 15 Off
                    Voltage: 12.25 V
                        Term 50 Off
02391 - Terminal 30 Reference
                    Reset counter: 102
                    Mileage: 170562 km
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 102
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 102
                    Mileage: 170562 km
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 62
                    Mileage: 170562 km
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 62
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 102
                    Voltage: 11.80 V
                        Term 50 Off
                    Reset counter: 102
                        Term 15 Off
                    Voltage: 12.10 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 102
                        Term 15 Off
                    Voltage: 12.10 V
                        Term 50 Off
Address 0F: Digital Radio
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003FC001JYZX
   Coding: 30314239304130303033554A304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50F9710E3A69245B83B-8004
   Serial number: 3572DRB40000E154830L
   Serial number: 3582DRB40000E154A8F1
   Serial number: 35128RB40000663052B8
   Serial number: 35228RB4000066027232
   Serial number: 35547RB4000066691F5S
   Serial number: 35647RB400006669225H
12670208 - No Communication with Instrument Cluster
          U0155 00 [009] - -
                    Reset counter: 62
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014142
   VCID: 46D55756C4ADFAEB297-8012
   Component: E0221           H02 0100
01304 - Radio
Address 17: Instruments
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 210911F1001810
   Coding: 352102
   VCID: 3537209AA54B6173B0D-8060
7 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 102
                    Fault Frequency: 91
                    Reset counter: 62
                    Reset counter: 62
                    Reset counter: 102
01304 - Radio
                    Reset counter: 61
                    Mileage: 170534 km
                    Date: 2020.06.10
                    Time: 05:02:01
                    Reset counter: 62
02649 - Digital Radio Tuner
                    Reset counter: 62
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45D7505AF9ABF1F320D-8010
                    Fault Status: 00100101
                    Fault Frequency: 34
                    Reset counter: 36
                    Mileage: 3618101 km
                    Time Indication: 4
                    Work Shop Code: 00768
                    Raw, Form. N/A: 000 000 000
                    Fault Frequency: 34
                    Reset counter: 36
                    Mileage: 3618101 km
                    Time Indication: 4
Address 25: Immobilizer
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001213
   VCID: 49CF5C6AD5B31593C45-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 233    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 34311D9EA231787B873-8060
                    Reset counter: 62
                    Voltage: 11.88 V
                        DD
                    Temperature: 14.0°C
            000 - - - MIL ON
                    Battery Volts: 11.8 V
                        PD
                    Temperature: 17.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
                    Reset counter: 102
                    Voltage: 11.88 V
                        DU
                    Temperature: 21.0°C
                    RPM: 1498 /min
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158126908401
   VCID: 36352796B44D6A6BB97-8062
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001213
   VCID: 4ACD6366D0B51E8BCDF-801E
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0011
   Serial number: 111010-0002-058
   Coding: 1163A51010022000
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DD4B46E405C6CB05F-8016
0068 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Timeout CAN-Message mMotor_1 (0x280)]
                    Reset counter: 102
0082 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Timeout CAN-Message mKombi_2 (0x420)]
                    Reset counter: 62
0084 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
          [Timeout CAN-Message mKombi_3 (0x520)]
                    Reset counter: 62
0092 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
          [Botschaft mDiagnose_1 veraltet]
                    Reset counter: 62
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 42DD4B46E885C6CB05F-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   VCID: 43D34E42F79FCFC30E9-8016
Address 77: Telephone
End----(Elapsed Time: 01:32, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
What caused the 30A fuse to fail?
Looking at that scan, I think you still have missing +12V power to some things in this car.
izack98
Canada
C?ID=364881
Apparently the fuse issue is a very common fault with the A3 and some models of VW (Jetta etc) which use the same fuse panel. VW has a TSB and a recall for it. They replace the panel and use a different type of 30 A fuse. Audi does not cover it even though the part # and the issue is exactly the same. I have been reading lots about it and no one has come to a definite conclusion as to what actually causes it.
I will do some more digging and testing and see if I can determine the reason for no power to some things. Any suggestions as to where to begin?
izack98
Canada
C?ID=364881
I did neglect to post a follow up to this. It turned out to be the fuse in the engine bay which provides power to the interior fuse for the instrument cluster. Once I replaced the engine bay fuse box and replaced the 30 amp fuse which powers the cluster (and a couple of other things) everything works now. I narrowed it down by jumping power from the power wire to the engine bay fuse box to the interior fuses which power the cluster. Everything came to life. I narrowed it down to the fuse being intermittent.
Hope this helps someone with any similar issues.
