Audi A6 3.0 TDI - DPF Procedure
AKL R36
Australia
C?ID=152211
Hi All,
I'm doing some research on which is correct procedure Diesel Particle Filter Emergency Regeneration, I've read through the common procedure on Diesel Particle Filter Emergency Regeneration, but I'm a little confused, hopes you guys can point me in right direction.
Auto scan of the vehicle in question is below,
Saturday,21,June,2014,12:08:17:50635
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ4F58N079564   License Plate:
Mileage: 122220km-75943mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 34 36 37 42 46 47 4F
          52 53 55 56 61 62 67 6C 6D 72 76 77
VIN: WAUZZZ4F58N079564   Mileage: 122220km/75943miles
0E-Media Player 1 -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
   Part No SW: 4F9 910 401 L    HW: 4F0 907 401 C
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H05---    Serial number:
   Coding: 0011372
   Shop #: WSC 02335 785 00200
   VCID: 2E5920EEB9D28E6E39B-807B
   Part No SW: 4F5 910 156 C    HW: 09L 927 156 C
   Component: AG6 09L 3,0 TDI RdW 0020
   Revision: --H04---    Serial number:        4394215
   Coding: 0000001
   Shop #: WSC 02325 758 00200
   VCID: 2855D6F69B36D05EF37-807D
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AB    HW: 4F0 614 517 R
   Component: ESP 8.0 quattro H05 0040
   Coding: 0016776
   VCID: 64CD82C6A79E743E1FF-8031
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
   Component: FBSAUDIC6 ELVSG H01 0040
   Revision: 09010701    Serial number: 10601600919958
   Coding: 0000147
   Shop #: WSC 02323 758 00200
   VCID: 244DC2C6E71E343EDFF-8071
   Subsystem 1 - Part No: 4F0 910 131 A
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H01 0040
00956 - Key 2
                    Fault Status: 00110010
                    Fault Frequency: 9
                    Reset counter: 194
                    Mileage: 121823 km
                    Date: 2007.05.18
                    Time: 08:26:45
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 K    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5140
   Revision: 00000000    Serial number: 351K$077554793
   Coding: 0003002
   VCID: 2B5F29FA8AC0FB461E5-807E
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000750976
   Subsystem 3 - Serial number: 0104.05.070000000100010466ˇ
   Subsystem 4 - Serial number: 010466ˇ
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 162
                    Mileage: 120733 km
                    Date: 2014.05.12
                    Time: 10:19:13
02244 - Button in Control Head is Stuck
                    Mileage: 116666 km
                    Date: 2014.02.15
                    Time: 10:31:43
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      100
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 157
                    Mileage: 120824 km
                    Date: 2007.05.16
                    Time: 12:56:33
                    Reset counter: 162
                    Time Indication: 15
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000465619
   Coding: 0001366
   VCID: 1C3DFA26DF6E0CFE67F-8049
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H18 0250
   Coding: 0112121
   VCID: 30653E96A3E6989E2B7-8065
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 02335
01498 - Bulb for Parking Lamps; Right (M3)
                    Reset counter: 164
                    Mileage: 120940 km
                    Date: 2007.05.16
                    Time: 13:19:00
Address 0E: Media Player 1 (R199)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 D    HW: 4E0 035 785
   Component: SG ext.Player H15 0830
   Revision: 00000000
   Shop #: WSC 02399 823 56573
   VCID: 2953D3F2403CE956EC9-807C
                    Reset counter: 162
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4F AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0V3EZ+
   Coding: 0013382
   VCID: 2953D3F2803CE956EC9-807C
   Subsystem 1 - Serial number: 6332CSME28355720-
   Subsystem 2 - Serial number: 6342CSME2835290C3
   Subsystem 3 - Serial number: 6352QSME4710173BB
   Subsystem 4 - Serial number: 6362QSME4423781DK
   Subsystem 5 - Serial number: 63734SME4474236D1
   Subsystem 6 - Serial number: 63834SME4618120BZ
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90054073100183
   Coding: 0112142
   VCID: 2757D5CA9628DF26FAD-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 933 J
   Component: KOMBIINSTR. M73 H21 0240
   Revision: 00700000    Serial number: 6XX7C45C7
   Coding: 7209758
   Shop #: WSC 00999 444 64523
   VCID: 234FC1DAE2103306A65-8076
Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B07B0881AF
   Coding: F5D1FE7F70720600
   VCID: 2D5B27E2B4D4F576001-8078
                    Reset counter: 164
                    Mileage: 120940 km
                    Date: 2007.05.16
                    Time: 13:24:37
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0390
   Revision: 00046002    Serial number: AUZ5ZBG4050129
   VCID: 1A31FC3ED55A72CE753-804F
                    Reset counter: 162
                    Mileage: 120733 km
                    Date: 2014.05.11
                    Time: 07:00:50
                    Reset counter: 162
Address 34: Level Control        Labels: None
   Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0060
   Serial number: 00619004160400
   Coding: 0000210
   VCID: 2241C4DEFD0A3A0EAD3-8077
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0091138
   VCID: E1C30BD2388CE116749-80B4
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H50 1050
   Revision: 00000000    Serial number: 364K.077733824
   Shop #: WSC 21000 822 83252
                    Reset counter: 162
                    Mileage: 120733 km
                    Date: 2014.05.11
                    Time: 06:57:12
                    Hex Value: 0x5387
                    Hex Value: 0x5252
                    Hex Value: 0x0054
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 P    HW: 4F0 959 793 P
   Component: TSG FA          H12 0230
   Revision: 00000000    Serial number: b7$
   Coding: 0001722
   Shop #: WSC 02327 758 00200
   VCID: 3777058A46884FA66AD-8062
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 189
                    Mileage: 121831 km
                    Date: 2007.05.18
                    Time: 13:49:14
                    Fault Status: 01101000
                    Fault Frequency: 37
                    Reset counter: 155
                    Mileage: 121996 km
                    Date: 2014.06.15
                    Time: 14:53:30
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
   Component: Komfortgeraet   H26 0210
   Revision: 02100026    Serial number: 01078318590000
   Coding: 3547789
   VCID: 3261349EADEAAA8E5D3-8067
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
   Component: Amp.-ASK-RD   H07 0270
   Revision: S1300000
   Coding: 030101
   VCID: 2855D6F65B36D05EF37-807D
                    Reset counter: 166
                    Mileage: 120733 km
                    Date: 2014.05.10
                    Time: 17:21:55
                    Voltage: 12.00 V
                    Temperature: 41.0∞C
                    Bin. Bits: 00000011
                    Fault Frequency: 26
                    Reset counter: 194
                    Mileage: 120733 km
                    Date: 2014.05.11
                    Time: 06:48:04
                    Voltage: 9.20 V
                    Temperature: 36.0∞C
                    Bin. Bits: 00000011
                    Reset counter: 194
                    Mileage: 120733 km
                    Date: 2014.05.11
                    Time: 07:11:43
                    Voltage: 6.30 V
                    Temperature: 34.0∞C
                    Bin. Bits: 00000111
                    Bin. Bits: 00000101
                    Bin. Bits: 00000000
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000105475
   Coding: 0001013
   VCID: DEB9302E09F2DEEE49B-808B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 P    HW: 4F0 959 792 P
   Component: TSG BF          H12 0230
   Revision: 00000000    Serial number: 7í#
   Coding: 0001722
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000321
   Shop #: WSC 02145 785 00200
   VCID: 2045CED6F306281EBB7-8075
Address 55: Xenon Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 H
   Coding: 0000004
   VCID: 3F876DAA6EB877E6A2D-806A
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394KZ077832270
   Coding: 0000001
   Shop #: WSC 02323 785 00200
                    Reset counter: 195
                    Mileage: 120733 km
                    Date: 2014.05.11
                    Time: 18:22:12
                    Fault Frequency: 44
                    Reset counter: 195
                    Mileage: 120733 km
                    Date: 2014.05.11
                    Time: 06:38:14
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000038001
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2711101305
   Coding: 344630393135313035442056413032373131313031333035
   Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
                    Mileage: 122221 km
                    Date: 2014.06.21
                    Time: 11:53:25
02273 - Quiescent Current Stage 2
                    Mileage: 122221 km
                    Date: 2014.06.21
                    Time: 11:57:24
02276 - Quiescent Current Stage 5
                    Mileage: 122221 km
                    Date: 2014.06.21
                    Time: 11:57:34
02274 - Quiescent Current Stage 3
                    Mileage: 122221 km
                    Date: 2014.06.21
                    Time: 11:57:44
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0210
   Coding: 0001066
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H46 0630
   Revision: 00000000    Serial number: 00000710250021
   Shop #: WSC 12336 024 394758
   VCID: 3669088E4182B6AE71B-8063
                    Reset counter: 162
                    Mileage: 120779 km
                    Date: 2014.05.29
                    Time: 16:08:19
   Part No SW: 4F0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7Y3031
   Coding: 1020305
   Shop #: WSC 02145 758 00200
   VCID: 1E39F02EC9721EEE89B-804B
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 F
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: ECDD6AE6CF4EBC7ED7F-80B9
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD11.11.07--H25001001C0142ˇ
   Subsystem 4 - Serial number: 1C0142ˇ
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0001066
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06320731105979
   Coding: 0221416
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005053388
   Coding: 0010900
   VCID: 2A512CFE853AE24EE53-807F
                    Reset counter: 162
                    Reset counter: 162
Address 61-01:4F0 915 105 D recoded (Long Coding) from 344630393135313035442056413032373131313031333035 to 344630393135313035442056413032373131313031333036  (00000/384/00290)
Address 42: DTCs cleared
Address 77: DTCs cleared
