omagnetun
- Jun 15, 2020
- 6
- 0
- Norway
- C?ID=271919 (NRRT)
Hello
I've made a SRI reset, and some modifications/codings on my A6.
After that, ACC/emergency brakes are disabled.
I've tried to find out what I've messed up, but after hours of searching, I realse that external help is needed.
Can anyone help me, please..?
Full autoscan typed below:
Monday,15,June,2020,19:42:48:00895
VCDS Version: 20.4.1.0 (x64)
Dealer/Shop Name: Bilkomponenter.no
VIN: WAUZZZ4G0GN112669 License Plate: KJ19920
Mileage: 23431km-14559mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 28 34 36 3B 3C 42 44 46
52 53 55 5F 62 65 69 6C 6D 72 82 84 85 8B 8E 8F 90 AC C0
VIN: WAUZZZ4G0GN112669 Mileage: 23431km-14559miles
17-Instruments -- Status: Cannot be reached 0100
65-Tire Pressure -- Status: Cannot be reached 0100
Address 01: Engine (J623-CZVC) Labels: Redir Fail!
Part No SW: 4G2 907 311 B HW: 4G2 907 311 A
Component: 3.0TDI MD1 H22 0002
Revision: C4H22---
Coding: 1225401A057601030000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G2907311B 001006
ROD: EV_ECM30TDI0114G2907311B.rod
VCID: 244781C22FD880A64F-8070
Part No SW: 4G0 927 166 K HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0005
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 35614C869442092EE8-8060
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 17A6DF49E865FB92BB00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41892856D08AB58E44-8014
36352 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Mileage: 21703 km
Date: 2019.11.21
Time: 22:53:23
VzRef: 00
Bit Info 1: C0
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
Uz: 6C
Unlearning counter according OBD: 28
161024 - Tire Pressure Warning
C102D 00 [040] - -
Mileage: 21734 km
Date: 2019.11.22
Time: 17:10:35
VzRef: 51
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: BB
161536 - Tire Pressure Warning
C102D 00 [040] - -
Mileage: 22398 km
Date: 2020.05.28
Time: 17:43:56
VzRef: 56
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: A9
Unlearning counter according OBD: 30
Part No SW: 4H0 907 064 GP HW: 4H0 907 064 GP
Component: BCM2 2.0 H37 0572
Coding: 05A96F0E000000000000
VCID: 7DF194A6E4F2116E60-8028
00956 - Key 2
Reset counter: 15
Mileage: 13262 km
Date: 2017.12.29
Time: 21:02:09
00955 - Key 1
Reset counter: 243
Mileage: 14619 km
Date: 2018.05.03
Time: 08:22:30
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 09111500041368
Coding: 369211783D0000
VCID: 63C5C2DE6A56C79E76-8036
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001208743302
Coding: 0105C01440349FE2C9014040A0001800CF9CE7082E08020100000894E10117020040002D0B0000
VCID: 71E9B896A8AA650EF4-8024
Component: WWS57X 150926 H38 0080
Serial number: 151017085907
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 60903638
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BH HW: 4G0 941 531 BH
Component: E1 - LDS H07 0044
Serial number: 09 11 2015 00000595
Serial number: 509809D7000000000001
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 243
Mileage: 20230 km
Date: 2019.01.28
Time: 20:50:45
04082 - Supply Voltage for Parking Aid
Reset counter: 13
Mileage: 22280 km
Date: 2020.04.13
Time: 16:43:59
Component: ACC3 H21 0055
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
VCID: 295990F648FA5DCE7C-807C
11264 - Sensor for Automatic Distance Regulation
C110B 49 [008] - Internal electronic failure
Reset counter: 236
Mileage: 23210 km
Date: 2020.06.13
Time: 20:32:52
Control Module temperature: 48 °C
Voltage terminal 15: 12.394 V
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 236
Mileage: 23210 km
Date: 2020.06.13
Time: 19:48:13
Control Module temperature: 37 °C
Voltage terminal 15: 12.164 V
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 15
Reset counter: 238
Mileage: 23210 km
Date: 2020.06.13
Time: 20:28:36
Control Module temperature: 45 °C
Voltage terminal 15: 11.981 V
87552 - Control Module Incorrectly Coded
U1014 00 [008] - -
Reset counter: 21
Mileage: 23210 km
Date: 2020.06.13
Time: 20:27:00
Voltage terminal 15: 12.005 V
89600 - Control Module Incorrectly Coded
U1014 00 [008] - -
Reset counter: 21
Mileage: 23210 km
Date: 2020.06.13
Time: 19:48:13
Revision: -------- Serial number: 003P1007944A
Coding: 30333130313730323630554A304C34473053
VCID: 3B755ABEB266DF5E1E-806E
Serial number: 3575HRB401I551R0C24P
Serial number: 3585HRB40693LHKE51HL
Serial number: 3515JRB405H3KDM62HBJ
Serial number: 3525JRB405H3KDM621D6
Serial number: 3554VRB401E52SHKK990
Serial number: 3564VRB401C52SHKK9UK
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372OK6000HY
Coding: 0004FD
VCID: 387F45B28B50F446F3-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 19 08 2015 D0049298
Part No SW: 4G8 920 934 J HW: 4G8 920 934 J
Component: TDieRdwAccNv H11 0106
Revision: 08001098 Serial number: 658051115596032
Coding: 538711001F550008010000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 387F45B28350F446F3-806C
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 J HW: 4H0 265 105 J
Component: Standheizung H26 0270
Revision: 77007007 Serial number: 20151024120057
Coding: 5D3F01
VCID: 295990F640FA5DCE7C-807C
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002045911
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001028
Serial number: 7736028303
Voltage stabilizer:
Serial number: 1507310000000000040F
5707 - Tire Pressure Monitoring Module
U0127 00 [009] - No Communications
Reset counter: 212
Mileage: 20852 km
Date: 2019.07.26
Time: 11:00:42
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.7 V
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 10111500041453
Coding: 21
VCID: 3D7154A6AC72D16E20-8068
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 2
Mileage: 21263 km
Date: 2019.07.31
Time: 18:55:06
Outside air temperature: 15.5 °C
Left rear vent temperature: 17.2 °C
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008003
ROD: EV_AirSuspe_VW51.rod
VCID: 2F6D7EEE761E33FEA2-807A
C10C8 00 [008] - -
Reset counter: 13
Mileage: 21703 km
Date: 2019.11.21
Time: 23:01:43
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000171843789
VCID: 77FD868EC6CE3B3E3A-8022
03324 - Switch for Backrest Angle Adjustment: Forward
Fault Status: 00100011
Reset counter: 12
Mileage: 21986 km
Date: 2019.11.24
Time: 14:09:21
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820AHEUW
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 36634B8A89440236E1-8062
Component: SWA Master H07 0060
Serial number: 0385620445
Coding: 040321
VCID: 397940B6B85AED4E0C-806C
Lane Change Assistant 2:
Component: SWA Slave H07 0060
Serial number: 0385497368
Coding: 040321
4192014 - Control Module 2 for Lane Change Assistance
C1115 04 [009] - Internal System Fault
Reset counter: 235
Mileage: 23181 km
Date: 2020.06.13
Time: 17:24:46
Component: TSG FA H04 0511
Coding: 011F1E015E00628002080013
VCID: 45813C46CCA299AE78-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000002 Serial number: 0000343156
Coding: 101001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7B5FBABD5CE65605-806E
Revision: 00002001 Serial number: 0382768603
Coding: 013A0E20B0B93095C32009802E030F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J245 PS20.403 H03 0004
Serial number: 0000FST000MZLU000000
Coding: 901F00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Serial number: 0000000AP00016042673
Subsystem 5 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J394 PS20.403 H03 0004
Serial number: 0000FST000MZLSY00000
Coding: 801F00
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93669723
03128 - Switch 1 for Sunroof
Fault Status: 00101100
Fault Frequency: 9
Reset counter: 15
Mileage: 20567 km
Date: 2019.07.07
Time: 19:54:35
00204 - Sunroof Button (E325)
Fault Frequency: 9
Reset counter: 15
Mileage: 20567 km
Date: 2019.07.07
Time: 19:54:35
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0511
Coding: 011F1E015E00628002080002
VCID: 44872142C798A0A66F-8010
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001653868
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D5164E67C1241EE90-8078
Component: MxB-ECU 001 0100
Coding: 04FA02202A1F0200
VCID: 346771829F381026DF-8060
Coding: E01F00
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
5353456 - Fog mode active
C118E 00 [008] - -
Reset counter: 13
Mileage: 22236 km
Date: 2019.11.24
Time: 18:20:56
Part No SW: 4G1 035 020 D HW: 4G1 035 020 D
Component: MU-H-ND-EU 051 0389
Serial number: A735J0FB000838
Coding: 017502010000000013111102000A00002F0006E5F17001009F
VCID: 1A3BBF3A1D9CC656E5-804E
Subsystem 1 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY803F6L
Multimedia Operating Unit:
Serial number: 90349OJU000LW
Compact Disc Database:
Component: Gracenote2 --- 1012
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0511
Coding: 010F1C004000628002080002
VCID: 479D364EF6AE8BBE8A-8012
Address 65: Tire Pressure
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001002 Serial number: 0386436424
Coding: 0100000202000000
VCID: 3365729E9A36171EC6-8066
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0361
Revision: 11001001 Serial number: 82330JG0125829
Coding: 0213000001010000010102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 297500706
Coding: 093205C031
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0511
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H08 0306
Coding: D70000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853) Labels:* None
Part No SW: 4G0 907 547 A HW: 4G0 907 547
Component: NV-ECU-Gen3 H08 0107
Serial number: 622352400201541
Coding: 300100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2C5769E2470848E687-8078
Camera For Night Vision System:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1530300241
Component: DPC-SG H27 0081
Coding: FA160000
ROD: EV_OnBoardCamerDPC.rod
Coding: 7704010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 275D96CE5EEE6BBE6A-8072
U1113 00 [009] - -
Reset counter: 238
Mileage: 23431 km
Date: 2020.06.15
Time: 19:26:49
Control Module temperature: 25 °C
Voltage terminal 15: 12.168 V
Velocity_vehicle_reference: -0.00 m/s
U1014 00 [009] - -
Reset counter: 238
Mileage: 23431 km
Date: 2020.06.15
Time: 19:26:49
Voltage terminal 15: 12.171 V
Component: BV-SG H33 0090
Serial number: 005000621211157
Coding: 04C0BB1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 13
Mileage: 21703 km
Date: 2019.11.21
Time: 22:53:25
Outside air temperature: -1.0 °C
Voltage terminal 15: 10.8 V
Control Module temperature: -2.0 °C
0063 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 235
Mileage: 23181 km
Date: 2020.06.13
Time: 17:24:47
Outside air temperature: 25.5 °C
Voltage terminal 15: 14.2 V
Control Module temperature: 31.0 °C
0173 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 13
Mileage: 22280 km
Date: 2020.04.13
Time: 16:43:59
Outside air temperature: 12.5 °C
Control Module temperature: 10.0 °C
Component: RGS-VL H14 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 31697896602A250EB4-8064
Component: RGS-VR H14 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 326B779A652C1E16CD-8066
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152860451
ROD: EV_RDCMA00100.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0007
Serial number: 151209200750
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
End-------------------------(Elapsed Time: 07:28)--------------------------
