Drive system malfunction
Moxnix
C?ID=212386
Need some advice here, drove upstate NY all highway, car driving perfectly 37+ MPG smooth as silk. Stopped at a toll, accelerated out and shortly after and dashboard lit up with a "Drive System Malfunction", "call service". I was in the middle of nowhere. Drove a couple of miles with reduced speed, 50mph and lower gear (6 speed manual so down to 3rd maybe) to look for a decent safe place to pull over. Lotta of bumping and missing of course. Stopped car, turned off ignition and opened driver door to fully complete ignition off. Restarted car, code still there for a second or so then disappeared and car drove fine since then. Is this a one off or do I need further investigation i.e. dealer? Car has been meticulously maintained. Also TPMS codes in scan were suspect as they happened earlier than this latest event and when i checked them they were within 1 lb of specifications and corrected and stored and haven't appeared since?
Sunday,14,June,2020,14:36:53:30397
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAURNAF48HN070849   License Plate:
Mileage: 32284km-20060mi   6-12-20
Chassis Type: F4-AU49 (8W6)
Scan: 01 03 08 09 15 16 17 19 22 29 2B 36 39 3C 42 44 46 52 5F 6C
          82 A5 BB BC CA CF D6 D7
VIN: WAURNAF48HN070849   Mileage: 32284km-20060miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---
   Coding: 0A5900320326010E34280000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS0208W0906259J.rod
   VCID: 48DC83CAF3C546C683-801C
15074 - Cylinder Disabling
          P130A 00 [096] - -
                    Mileage: 31689 km
                    Date: 2020.06.12
                    Time: 06:53:35
                    Engine speed: 2904.00 /min
                    Normed load value: 9.8 %
                    Vehicle speed: 48 km/h
                    Coolant temperature: 104 ∞C
                    Intake air temperature: 32 ∞C
                    Voltage terminal 30: 12.949 V
                    Unlearning counter according OBD: 35
                    FAC_TPS_1_SAE: 17.187500 %
                    FUP_H_SAE: 8510.0 kPa
                    MAP_MES_SAE: 51 kPa
                    Engine: operating status: PL
                    TAA: 15.000 ∞C
                    T_AST_SAE: 6137 s
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.134 V
15131 - Cylinder 3
          P0303 00 [096] - Misfire Detected
                    Mileage: 31689 km
                    Date: 2020.06.12
                    Time: 06:53:35
                    Engine speed: 2915.00 /min
                    Normed load value: 11.8 %
                    Voltage terminal 30: 12.890 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 7390.0 kPa
                    MAP_MES_SAE: 45 kPa
                    TAA: 15.000 ∞C
                    T_AST_SAE: 6137 s
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
15128 - Cylinder 2
          P0302 00 [096] - Misfire Detected
                    Mileage: 31689 km
                    Date: 2020.06.12
                    Time: 06:53:35
                    MAP_MES_SAE: 45 kPa
                    TAA: 15.000 ∞C
                    T_AST_SAE: 6137 s
15137 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 31689 km
                    Date: 2020.06.12
                    Time: 06:53:35
                    MAP_MES_SAE: 45 kPa
                    TAA: 15.000 ∞C
                    T_AST_SAE: 6137 s
23126 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 G    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0719
   Coding: 18AA409920A90A9611A6409520865292E6419E180204508802044A49678279
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 49DA86CEE8CFBFCE9C-801C
415488 - TPMS Warning; Front Left Tire
          C1055 00 [040] - Flat
                    Mileage: 31147 km
                    Date: 2020.06.02
                    Time: 04:41:21
                    7C 00 80 2D 89 24 00 00 D0 60
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [040] - Flat
                    Mileage: 31147 km
                    Date: 2020.06.02
                    Time: 04:41:21
419840 - TPMS Warning; Rear Right Tire
          C105B 00 [040] - Flat
                    Mileage: 31147 km
                    Date: 2020.06.02
                    Time: 04:41:21
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H55 0205
   Coding: 140805085544010D10000100880000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44C497FACFED62A66F-8010
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001485181
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 5C58C1A880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
131078 - Reference Voltage
          B10AD 16 [009] - Voltage Too Low
                    Reset counter: 195
                    Mileage: 27077 km
                    Date: 2020.03.15
                    Time: 10:16:34
                    Voltage terminal 30: 14.23 V
                    Outside air temperature: 12.50 ∞C
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500363E0081CCD05155119188C98BB110B3D08000000000000000020001A010A690122025709
   VCID: 024851E29579AC961D-8056
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 170310  043 0813
   Serial number: 89435300301706909208
   Coding: 5BC7F7
   Serial number: 20386410X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 04 07 2016  00701226
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z02GE02
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170405153619 00893
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE110021723311081
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CJ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00337720
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000017453006
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0104
   Serial number: 003UQ000V9FS
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005015
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 4DD2B2DE1CA7A3EEB0-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705G0116R00996
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706J0116R00253
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J1700071VUH0U
   Subsystem 4 - Part No SW: -----------    HW: 442 060 604 17
   Serial number: 3577Y00AD21781A3020R
   Subsystem 5 - Part No SW: -----------    HW: 442 060 604 17
   Serial number: 3587Y00B921303C5338V
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 903 17
   Serial number: 3517700C52220D22706X
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 903 17
   Serial number: 3527700C52220D2180F0
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 904 17
   Serial number: 3557500A722BF490E2ET
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 904 17
   Serial number: 3567500A722BF492329G
   Part No SW: 4M0 907 129 GB    HW: 4M0 907 129 GB
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76A03D32C9B1803621-8022
   Part No SW: 8W5 920 890 C    HW: 8W5 920 890 C
   Component: FBenUSA       H17 0313
   Coding: 08E65191A888CF050223E9601800000008000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 43C694E6CAE3659E56-8016
16777024 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
          [BCME_0x23 communication error bap_error_timeout heartbeat]
                    Reset counter: 8
                    Mileage: 31140 km
                    Date: 2020.05.31
                    Time: 12:27:58
   Part No SW: 8W6 907 468 D    HW: 8W6 907 468 D
   Component: Gateway       H30 0308
   Revision: 5B010004    Serial number: 0485B004317427
   Coding: 03010001000006402907000000590010CC280007000000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4BD6BCC6E2B3ADDEAE-801E
   Subsystem 1 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
   Component: J453 MFL  H04 0002
   Serial number: 20170418202617 01335
   Serial number: 8524973604
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8W0 927 755     HW: 0CJ 927 749
   Component: B9_ML4_N_SD4  H01 0004
   Serial number: 1626517574
   Coding: 31000000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78BC330AC3A5F64633-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000065359013
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 3228C1226559DC16CD-8066
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000252271452
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 3620FD328931C036E1-8062
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0057
   Serial number: 0000253581510
   Coding: 005D1B205E001080000100B2
   VCID: 40CC9BEADBF57E864B-8014
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 41CA9EEED0FF778E44-8014
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0344
   Coding: 012C00004F900080650FA0002E01000233024000010027500F0400000B04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7F4ED816E68BC17E72-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1708233GE
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000069306346
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1082556
65907 - Alarm Horn / Siren for Anti-Theft System
          B131D 29 [008] - Signal Implausible
                    Reset counter: 1
                    Mileage: 24413 km
                    Date: 2019.11.04
                    Time: 08:23:56
                    Supply voltages-Supply voltage: Terminal 30: 12.894 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.976 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.881 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 ∞C
                    general_additional_freeze_frame-interior_temperature: -50.0 ∞C
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 4A 1A 02 98
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0057
   Serial number: 0000252390411
   Coding: 005D1B205E001080000100B0
   VCID: 3FCE9816A60B017E32-806A
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880     HW: 8W5 035 880
   Component: MU-P-LNS-US   033 0918
   Serial number: A798D0HB026733
   Coding: 019401020000000053220002041A00102F0002E501700904FE
   VCID: 7CB42F1AF79DDA6657-8028
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0160
   Serial number: TPO00117031700820148
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 R    HW: 8W0 919 614 R
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK115021700040317
   Compact Disc Database:
   Component: Gracenote2  --- 3011
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG015644
   Coding: 029401029A0FA10008404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3424C73A9F4DD226DF-8060
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 8W5 919 617 B    HW: 8W5 919 617 B
   Component: HeadUpDisplay H18 1640
   Coding: 2A01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 47DE80F6FEDB49BE8A-8012
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H16 0050
   Coding: 0404090100000203022023A2A40000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3C34EF1AB71D1A6617-8068
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0057
   Serial number: 0000252233424
   Coding: 000D1B2000001080400000A0
   VCID: 42C891E2D5F96C965D-8016
   Component: TSG HBFS      009 0057
   Serial number: 0000252894430
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 4M0 907 594 A    HW: 4M0 907 594
   Component: SAD_STG_1     012 0003
   Coding: 208000049100
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 3326C4269A43D51EC6-8066
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 16601DB2E9F12036C1-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 01:59, VBatt start/end: 12.4V/12.4V)-----------
I had an incident like that in a 2005 A6 when it was only a few years old. It started running horribly out of the blue, for no apparent reason on I80 headed to Grandma's house for Thanksgiving; flashing MIL and all. Pulled off at the first exit. Shut it down. Scanned it. It had a bunch of misfire codes. I cleared them, re-started it, and it ran fine. The problem never recurred. Perhaps a a few drops of water in the fuel?
Speaking of which: What was your fuel level like? I see that Fuel Level Sensor Circuit fault.
What do your fuel trims look like?
Moxnix
C?ID=212386
Hi Use,
3/4 tank when that happened, always buy from the same station and 93 octane. I didn't clear anything just scanned it. Should I clear them and carry on. I will scan it again for fuel trims. The car is running like a clock again after restarted it, not so much as a hiccup and it is getting ridiculous gas mileage if that's any indication
Moxnix
C?ID=212386
Hi Uwe,
Went out to look for fuel trims in measuring blocks but had to bail out for an urgent thing. After unplugging and starting car all normal went to get gas for a trip. After fueling a message I have never seen popped up on my steering wheel dash about licensing and sources codes from audi? Never saw this before. I only cleared the dtcs from the last post? Didn't change or make any changes in anything. I have an image of it if you need it unless you're familiar with this but I've never seen it after using the software? Thoughts?
I have never heard of such a thing. If you see it again, please take a picture.
Moxnix
C?ID=212386
I have an image, hoe do I upload it?
Moxnix
C?ID=212386
I accessed nothing that would cause this to pop up?
dA1iy6q
Moxnix
C?ID=212386
dA1iy6q
Looks like an open-source notice. Many open source licenses require anyone who distributes products that incorporates such code to offer to provide source for any modifications to the original code. But I have no idea what would prompt it popping up.
Moxnix
C?ID=212386
If I'm being honest stuff like this just follows me around. I have used my cable on 3 audi's and the kids GTI and never had a message like this come up. Also, it didn't come up right away. Did an autoscan, saved it, cleared the codes, closed it exited and unplugged it. Car sat off for maybe 5 minutes, restarted it all normal, went to get gas and that message appeared after fillup when I started the car to come back home? Now it's telling me my oil level is good without me asking. Also wants me to "turn ignition back on" to save my driving mode after it's been selected and driven? Something weird going on for sure. I modified nothing.
Moxnix
C?ID=212386
Hi Uwe,
Just out of curiosity, is there any scan I could do that would show what, if any of the audi source code might have modified on my car? Just to be on the safe side so to speak.
G
No, there's nothing that you can do to identify what Audi has modified, short of making the request specified in that notice and comparing the their source code to the stuff that's published by whatever group maintains the "trunk" for that source.
The real question here is: What triggered the message to come up? Did you by chance do a "Reset" on your MMI? (The MMI is where I would expect to find the open-source software that requires such a notice, but it's possible there's also some of that in the virtual cockpit instrument cluster).
Gone But Not Forgotten
Sounds like battery or charging voltage was possibly interrupted and the car rebooted?
Moxnix
C?ID=212386
Hi Uwe, no I didn't reset anything via the car's interface at at all. Stored the tire pressures and changed the driving mode but nothing else. As I said in the previous I scanned the car, saved it, selected the clear codes option, codes erased box came up, I selected done, finished the session, exited the program and unplugged the cable. No resets of any kind really. The virtual cockpit did do some funky things when I restarted the car after fueling, it changed sizes and views maybe twice before it settled on the view seen in the image. I need to do another long distance drive with a bunch of tools and it's been running fine around town so I'm just going to go with the flow unless you think it's iffy?
G
Moxnix
C?ID=212386
Hi Jack,
That could be since I do keep it on a tender. But it wasn't on anything when I did the scan? If it did do a reboot wouldn't it show a few messages or unusual behavior when I started it up or maybe that's what the changing views was all about in my post to Uwe?
G
Moxnix
C?ID=212386
Guys, now here's something that i forgot that is most likely important (lot going on but no excuses). Before i use the cable I make sure its using the latest version as I have screwed that up in the past (Uwe asked me once to do a scan with the latest version). I did that this time as well, updated laptop in the house and all went fine but when I plugged it into the car and launched it a message came up saying there was an additional update and asked if I wanted to install it? I told it to go ahead with it still plugged into the OBD port and everything went fine and it launched as usual and I did the scan. Is it possible that updating the software while it was connected to the car caused this? Sorry I forgot this but i'm guessing it might be relevant. There was no message telling me not to.
Loose dirty or corroded connection affected by moisture or relative humidity?
Moxnix
C?ID=212386
Thanks Jack, car is always garaged and the engine compartment is basically pristine. Basically the whole car is pristine and basically always been kept in a climate controlled space. Only time it gets weather is winter or summer rain during trips. After any major trip it's washed driven to clean rotors and right back in the garage. Battery terminals and everything visible looks like the day I got it? Just checked under spare tire and it's all whistle clean. The software update thing doesn't set anything off for you?
When connections heat up from current flowing through them and things loosen up, it can appear tight when cold since contracts, and relative humidity in air changes a factor during operation, huh?
Consider cleaning, applying contact enhancements, additional ground straps + a verified re-torque yet?
