Audi a4 2013 - 01319 - Control Module for Distance Control (J428) plus more
vagcodinguk
C?ID=403194
hi everyone,
got my vcds cable not long ago and a friend came over today with his audi a4 13 plate to do some tweaks, I won't post the first scan as I have managed to code a lot of those errors out, however I couldn't code a few (I know the 00862 - Antenna for GPS Navigation means he needs to look into his antenna connections and etc so ignore that) so could any of you more experienced people out there help with the rest?
would like to mention that I spent a good amount of time on trying to figure out what could be wrong coded in the Instruments and what would request the Control Module for distance from Central Electronics but no luck.
Also if you look at Address 56: Radio (R) Labels: Redir Fail! - I have send a map to Rosstech and waiting a reply from them regarding that
thank you in advance
Last scan of his car here:
Sunday,14,June,2020,13:18:20:43136
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8K6DA248709   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K6DA248709   Mileage: 122010km-75813miles
Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 HT    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9977
   Revision: 45H25---
   Coding: 12034012242401080000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TDI01103L906018HT 003008
   ROD: EV_ECM20TDI01103L906018HT.rod
   VCID: 03538A2ACB9F90134E9-8056
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K9 927 155 A    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000000219
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: 3A2D37CEFCD511DB5DF-806E
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 171544
   VCID: 00598526DA098B0B53B-8054
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H12 0633
   Coding: 01B24040000000000000
   VCID: 79AFE8C2B9D3DAC3145-802C
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0513000030951021
   Serial number: 2313000070039001
   Part No SW: 8K2 820 043 AH    HW: 8K2 820 043 AH
   Revision: D0000000    Serial number: 01260420131899
   Coding: 342402E000
   VCID: 6FBBD69AF7978473BA1-803A
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000599900301
   Coding: 2700C0398720AFE2948142800000010D43DD470827090241000008004400020100000024000000
   VCID: 77ABEEFA8FC7CCB3621-8022
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 260413  H06 0080
   Serial number: SWF13040260063
   Coding: 00FD11
   Serial number: 21243658
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002004134648
   Serial number: 9E08C4A6000000000001
                    Reset counter: 171
                    Mileage: 122011 km
                    Date: 2020.06.14
                    Time: 13:12:57
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000008
   VCID: 2D070C923D1BB663C8D-8078
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD99WT56
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 33830 001 1048576
   VCID: 48C95D06B239734BDBB-801C
   Serial number: 6334MSME7B156671H
   Serial number: 6344MSME7B1624308
   Serial number: 6352QSME20300F5CE
   Serial number: 6362QSME2E3051429
   Serial number: 63732SME13302F54W
   Serial number: 63832SME0F300966$
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130502000221
   Coding: 000037
   VCID: 4FFB761A57D7A4739A1-801A
   Part No SW: 8K0 920 982 E    HW: 8K0 920 982 E
   Component: KOMBIINSTR.   H35 0556
   Revision: 00400000    Serial number: UVR34YK4E
   Coding: AFDD10000A20A700010403
   VCID: 363523FEC84DF5BBB97-8062
                    Reset counter: 171
                    Mileage: 122011 km
                    Date: 2020.06.14
                    Time: 13:12:57
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y13417009F
   Coding: 80CF07FF00
   VCID: 4ACD670EACB5815BCDF-801E
   Serial number: 9621140403
   Serial number: 13114000840011200181
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000058498377
   Coding: 011702004C01410001
   VCID: 50F975664AE9BB8B83B-8004
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0026432783
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 343119F6DEB1E7AB873-8060
   Revision: 00002001    Serial number: 0305974411
   Coding: 013F162220B900808320023280000000
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000059278804
   Coding: 011702205C01410001
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 30000000045206
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38292DC6C2D903CBABB-806C
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230DY0D2759562
   Coding: 010003020100000001
   VCID: 2809FD8612F9934B3BB-807C
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
   Component: H-BN-EU       H45 1036
   Revision: --------    Serial number: 206DS0D7526142
   Coding: 0F0101010106C1FD07008F3E1E200403000200000200000200
   VCID: 42DD4F2E9485591B05F-8016
   Subsystem 1 - Part No: 8R0 060 884 GS
   Component: EUR 2020  3001
   Component: DU7 High  H42 0104
   Serial number: A130DK0D2714432
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001488130
   Component: CD-Database  4949
                    Reset counter: 171
                    Mileage: 122011 km
                    Date: 2020.06.14
                    Time: 13:14:49
                    Voltage: 11.30 V
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000059339418
   Coding: 011402204001210001
   VCID: 46D5533EB8AD653B297-8012
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000059339639
End----(Elapsed Time: 01:41, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Mr. M
Leicestershire, UK
C?ID=256600
Hi,
With the info posted it is a little difficult to say what is wrong here. Can you post the first scan of the car before you did anything and list what tweaks you did? This may help answer some questions although I am no expert at tweaks/coding mods. If I can't help hopefully someone else may be able to give some info then :)
I would say it is a bad idea to adjust coding to remove errors as this usually causes bigger problems than you started with. If errors are current the cause has to be fixed to allow them to clear using the "Clear Fault Codes" command.
vagcodinguk
C?ID=403194
Hi,
I've actually asked for help to adjust coding to remove the errors specified above, as I'm aware they're triggered from incorrect coding. Thanks :)
vagcodinguk
C?ID=403194
Test this:
AFDD10000A20A700010401
Thank you for that, will try it and let u know if it worked.
Any clue about the Central elect - 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication?!? I know something needs to be unticked but haven't got a clue what
United States
I don't see anything obviously wrong with 09's coding in regards to Byte 35 but the original (to you) condition scan and CodingLog.CSV may shed light on the changes that were made that caused the initial conflicts.
I can move this to the Car Repair Support Sub-forum.
United States
Andrei sent the original (to him) condition scan via e-mail (in regards to the 56 lbl) and it wasn't a disaster. No doubt, it appears as if J519 (AW09), J285 (AW17) and J794 (AW5F) at the least were tinkered with previously but it wasn't wall-of-shame worthy DTC wise :)
He's going to test the new 17 coding suggestion above.
In the meanwhile I think I spotted the major discrepancy in 09.
Older condition scan:
   Coding: 2700C0398720AF[B]F2[/B]948142800000010D43DD470827090241000008004400020100000024000000
03110 - Active Steering Control Module (J792)
Current:
   Coding: 2700C0398720AF[B]E2[/B]948142800000010D43DD470827090241000008004400020100000024000000
The Active Steering config lives in Byte 7 and I have this commented out (unconfirmed) in that label:
;LC,07,1,Distance Regulation/Adaptive Cruise Control installed with Drive Select/Charisma active [PR-8T4] ??
Some of this documentation is a carry-over from the newer MLB based cars using 4G and 4H BCMs at which point ACC was nearly standard equipment but there wasn't much info available on the early B8/8K models. Although I believe something is goofy with the Headlight config in Byte 0 I'm pretty sure this will resolve the ACC DTC:
2700C0398720AFE0948142800000010D43DD470827090241000008004400020100000024000000
Feedback would be highly appreciated so I can unmask that Byte in the label if it applies to J428/ACC in this BCM1.
vagcodinguk
C?ID=403194
Current:
Hi Dana, Central Elec doesn't show any errors after trying your code, so it worked!
Thank you
United States
Excellent! I'm not sure if the PR-Codes are correct but I'll slip that into the label file so the Bit isn't missing documentation entirely.
