2019 eTron -- ABS adaptation question
bluetomato
C?ID=407511
Below are my autoscan results. I am trying to disable the disk brake wiper function on this vehicle and it is asking me for a security code to make the adaptation change. Looking into this further, I was able to access erWin (at a cost to me) and download all factort repair manuals, however, I found no reference to a security access code to allow me to make this change. I would appreciate some guidance on how to proceed.
Thanks!
Friday,12,June,2020,16:03:26:20868
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WA1VAAGE5KB021406   License Plate:
Mileage: 9926km-6167mi   Repair Order: second_pass
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 51 52 5F 69
          6D 74 75 81 82 8C A5 BB BC C0 C5 C6 CA CE CF D6 D7 DB DC DE
          8104
VIN: WA1VAAGE5KB021406   Mileage: 9926km-6167miles
51-Electric Drive -- Status: Malfunction 0010
74-Chassis Control -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 E    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012007E000034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
   ROD: EV_VCU00XXX0204KE907558E.rod
   VCID: 4BC362BED3400813F69-801E
23078 - Control unit for information electronics 1
          U1055 00 [032] - Implausible signal
                    Mileage: 9321 km
                    Date: 2020.06.07
                    Time: 11:49:20
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 13.925 V
                    Unlearning counter according OBD: 30
                    LF_MVB_PDU_INTC_DIAG_8: 16384
                    LF_MVB_PDU_INTC_DIAG_9: 2
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 4096
                    LF_MVB_BUS_INTC_DIAG: 12544
37745 - Controls in Steering Wheel
          U108E 00 [032] - No Communications
                    Mileage: 8954 km
                    Date: 2020.06.04
                    Time: 17:56:59
                    Voltage terminal 30: 11.796 V
                    Unlearning counter according OBD: 22
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_13: 4097
23039 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:41:42
                    Voltage terminal 30: 12.460 V
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 2048
                    LF_MVB_PDU_INTC_DIAG_3: 2080
                    LF_MVB_PDU_INTC_DIAG_4: 32768
                    LF_MVB_PDU_INTC_DIAG_5: 32768
                    LF_MVB_PDU_INTC_DIAG_6: 32
   Part No SW: 4KE 909 059 AC    HW: 4KE 909 059 G
   Component: ESC           H09 0078
   Revision: 00000000    Serial number: 62189000006640
   Coding: 008800BA3D960B9A93540C71187D52E0253EA90000BCD0C930184A07A47C95
   Shop #: WSC 00023 444 00000
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 08499DB282B6230B1BB-805C
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000381490835
   Coding: 001CB2400001BEA14843010101010000810000070700878700000000000000
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VWE3.rod
   VCID: 3D273C669DF4B6A378D-8068
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ80013006194025819D
   Coding: BF2F00
   Valve Block 2 In Passenger Side Front Seat:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ800106071911470443
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000363C0291CDD070257889CFB9C28131B37510C06009709010A0019231601086309024010200000000303004B181808028000C4030000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7DA7FC66DD7476A338D-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001906140400216
   Coding: 7DC727
   Serial number: 23440089X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S24.07.1900692403
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z007G02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 A    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0001
   Serial number: GX1NR123071923310414
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0415
   Serial number: C00344470
   Coding: 0D0104
   Electrically Adjustable Steering Column:
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA138153000069862057
   Coding: 0A0700
   Seat Backrest Fan 1 Front Left:
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BJ21976303
   Seat Cushion Fan 1 Front Left:
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BJ18768195
   Seat Backrest Fan 1 Front Right:
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BJ21976310
   Seat Cushion Fan 1 Front Right:
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BJ21955356
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001920100726
   Coding: 040000
   Part No SW: 4KE 907 561 B    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: FE659F5C58082C00010380210000003E4A1246494401009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 42DD4F9AE40AC95B05F-8016
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Fault Frequency: 32
                    Reset counter: 209
                    Mileage: 8954 km
                    Date: 2020.06.05
                    Time: 17:13:24
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.2 V
                    Velocity_vehicle_reference: 5.31 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.26 m/s²
                    Steering_angle-Data: 120.400 °
                    Yaw_rate-Data: 3.960 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.242 °
                    Misalignment angle: horiz: fast algorithm: 0.271 °
                    Congestion pilot: status: OFF
                    Outside air temperature: 18.00 °C
                    Sensor blindness: radar: no blindness detected
2102 - Databus
          [FAULT_ESP_CONTROL_FAIL]
                    Fault Frequency: 32
                    Reset counter: 209
                    Mileage: 8954 km
                    Date: 2020.06.05
                    Time: 17:13:23
                    Velocity_vehicle_reference: 4.95 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.54 m/s²
                    Steering_angle-Data: 41.400 °
                    Yaw_rate-Data: 0.490 rad/s
   Part No SW: 4KE 959 655 A    HW: 4KE 959 655 A
   Component: AirbagVW32    H37 3122
   Serial number: 003XQM00E5DU
   Coding: BFCCFCC000200000A200003FFA0D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4CC161A2D64E0F2BFF3-8018
   Belt Pretensioner left:
   Serial number: 00AI2019208784000000
   Coding: 03F002
   Belt Pretensioner right:
   Serial number: 00AI2019207798600000
   Coding: 03F002
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000BZD7H0N
   Coding: 303138
   Subsystem 4 - Part No SW: -----------    HW: 480 000 808 19
   Serial number: 35700000000A5A48BE3.
   Subsystem 5 - Part No SW: -----------    HW: 480 000 808 19
   Serial number: 35800000000EC848BE34
   Subsystem 6 - Part No SW: -----------    HW: 480 031 908 19
   Serial number: 351001C24B9604806B85
   Subsystem 7 - Part No SW: -----------    HW: 480 031 908 19
   Serial number: 352001C24B9DCCB09FC4
   Subsystem 8 - Part No SW: -----------    HW: 480 022 808 19
   Component: FrontSensor_D  000 0149
   Serial number: 35500012C2CA45E3031$
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 022 808 19
   Component: FrontSensor_P  000 0149
   Serial number: 35600012C2CA45E1B417
   Sensor High Voltage System 1:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 208 19
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001122C9CA6685A7
   Side Sensor B-Pillar Driver Front:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 208 19
   Component: SideSens_B_Df  000 0149
   Serial number: 35200010C2C9CA26522%
   Side Sensor B-Pillar Passenger Front:
   Subsystem 12 - Part No SW: -----------    HW: 480 022 208 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 35500010C2C9CA257199
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Reset counter: 205
                    Mileage: 9012 km
                    Date: 2020.06.06
                    Time: 12:27:33
   Part No SW: 4N0 907 129 Q    HW: 4N0 907 129 Q
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 3FDB466E97F8A4B36A1-806A
7340544 - Heated Steering Wheel
          B1538 13 [009] - Open Circuit
                    Reset counter: 152
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:47:09
                    Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 10800 min
                    Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
                    Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 12206.25 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 0.00 V
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
4194304 - Databus
          [Receive timeout: gateway]
                    Reset counter: 192
                    Mileage: 8954 km
                    Date: 2020.06.04
                    Time: 17:57:00
   Part No SW: 4KE 920 795 A    HW: 4KE 920 795 A
   Component: FHybRDWACC--- H13 0105
   Coding: 8B4600C97C88D7050286E170BB846B0008000000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 45D75486F524FE6320D-8010
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Reset counter: 201
                    Mileage: 9425 km
                    Date: 2020.06.07
                    Time: 18:32:07
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Reset counter: 210
                    Mileage: 8954 km
                    Date: 2020.06.06
                    Time: 11:42:26
1246810 - Activatable Functions
          B18D3 F4 [008] - Authentication of Transmission Failed
                    Reset counter: 207
                    Mileage: 9605 km
                    Date: 2020.06.08
                    Time: 17:52:00
   Part No SW: 4K1 907 468 F    HW: 4K1 907 468 C
   Component: Gateway       H04 0358
   Serial number: 14F03075754601
   Coding: 02030005000100C000810000005B01329C8A0047180000000900009F00000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x.rod
   VCID: 38292D72B2D6938BABB-806C
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 76749602001908100588
   Control module for steering wheel touch recognition:
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H46 0040
   Serial number: 19184022308S00404601
131826 - Unknown Error Code
          U1645 00 [008] - -
          [Timeout_Node_0xF2_zr2_DiagAdress_005F]
                    Fault Frequency: 13
                    Reset counter: 210
                    Mileage: 8954 km
                    Date: 2020.06.04
                    Time: 15:39:04
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
          [Break_Down_LIN_Communication_Mfl]
                    Reset counter: 192
                    Mileage: 8954 km
                    Date: 2020.06.04
                    Time: 17:56:55
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [BAP_Timeout_BatteryControl]
                    Fault Frequency: 41
                    Reset counter: 170
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:43:43
8978692 - Unknown Error Code
          B18D3 F3 [008] - Unknown Error Elaboration
                    Reset counter: 207
                    Mileage: 9255 km
                    Date: 2020.06.07
                    Time: 09:31:15
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000189234010
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 34311942AEBE77EB873-8060
   Serial number: 00000381490855
   Coding: 001C9A400001BEA14803010101010000810000070700878700000000004000
   Valve Block 1 In Driver Side Front Seat:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ80013006194025817D
   Coding: BF2F00
   Valve Block 2 In Driver Side Front Seat:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ800107071911470324
   Part No SW: 4KE 907 566     HW: 4N0 907 566 A
   Component: MRR_HR H12 0426
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 05579486B5A43E6360D-8050
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0387
   Serial number: 0000385546596
   Coding: 001DDB0152001482A009A032
   VCID: 48C95DB2C236E30BDBB-801C
   Coding: B4000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1F5A54AA79DB95F-8066
   Part No SW: 8W1 907 064 AH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0542
   Coding: 017400004FB100C1650FA0046C01C88200004000810426582F0400000F04823F001E0101010F13
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 03538A9EBB9000534E9-8056
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY19210356W
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047512768
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4KE 945 423 A    HW: 4KE 945 423 A
   Component: T1 LH SAE HD  H10 0403
   Serial number: A1WM00007YN
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11946279
   Rear Light Left 2:
   Subsystem 5 - Part No SW: 4KE 945 429 A    HW: 4KE 945 429 A
   Component: T2 LH SAE HD  H11 0403
   Serial number: A1WP00008DE
   Rear Light Right 1:
   Subsystem 6 - Part No SW: 4KE 945 424 A    HW: 4KE 945 424 A
   Component: T1 RH SAE HD  H10 0403
   Serial number: A1WS00007SZ
   Rear Light Right 2:
   Subsystem 7 - Part No SW: 4KE 945 430 A    HW: 4KE 945 430 A
   Component: T2 RH SAE HD  H11 0403
   Serial number: A1WQ00008DF
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D026BQ+
   Coding: 0115160000AAAA2FAA0000010002
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E9021E5EE76B173-8070
   Part No SW: 0EF 907 080 G    HW: 0EF 907 080 C
   Component: CUFZD683Q0AD2 H03 0010
   Revision: --------    Serial number: -00110.05.19000
   Coding: 01000000000000000000
   Shop #: WSC 07126 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3A2D377A8CDA819B5DF-806E
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:34:48
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0387
   Serial number: 0000386916302
   Coding: 001DDB015E001482A009A030
   VCID: 47CB5E8ECF28EC73D21-8012
   Part No SW: 4KE 035 084 B    HW: 4KE 035 084
   Component: MU-H-LNS-US   054 2658
   Coding: 0115760200000000C3220002061C02302F0001E403F008048E
   Subsystem 1 - Part No: V03 959 804 CG
   Component: MIB2P_NA_Q419  0416
   Subsystem 2 - Part No SW: 4KE 919 605 B    HW: 4KE 919 605
   Component: DU AU516 High  H71 0147
   Serial number: INX00110011900130283
   Compact Disc Database:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000085075051
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00102011900140010
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900449804001
          B11CF 53 [009] - Deactivated
                    Reset counter: 152
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:34:46
                    Voltage terminal 30: 13.1 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Audio Signal: Available
                    Satellite radio tuner status-Antenna current: 109 mA
                    Satellite radio tuner status-Reception quality: weak_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
          B2000 87 [008] - Missing message
                    Reset counter: 202
                    Mileage: 9425 km
                    Date: 2020.06.07
                    Time: 18:32:23
                    Voltage terminal 30: 14.3 V
                    Software module: status-SW_Status_Consistency: 00 00 01
                    Software module: status-SW_Status_Device: Eggnog
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0525539377
   Coding: 0210000200000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2
   Coding: 33B0
   VCID: 4ACD67BADC3A111BCDF-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 2008190725
   Coding: 98D86883DA4020
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45ABAAE0D27D3BD17-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130678150
   Coding: 303030
6598692 - Internal Fault
          B200F F3 [008] - Unknown Error Elaboration
          [Internal_communication_error_acceleration_longitudinal]
                    Reset counter: 192
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:41:42
                    Internal DTC: 217
6598693 - Latteral Acceleration 1
          C1022 29 [008] - Signal Implausible
                    Reset counter: 192
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:41:42
                    Internal DTC: 218
6598694 - Yaw Rate 1
          C1020 29 [008] - Signal Implausible
                    Reset counter: 192
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:41:42
                    Internal DTC: 219
15462408 - Unknown Error Code
          C137E 00 [008] - -
                    Reset counter: 192
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:41:42
                    Internal DTC: 399
                    quattro_torque_control: -15.00 rad
                    quattro_torque_control: 0
                    quattro_torque_control: 5
                    quattro_torque_control: -10000
                    quattro_torque_control: 0 m/s
                    Dynamic all wheel drive: overall system status-Status dynamic steering: Initializing
                    Dynamic all wheel drive: overall system status-Rear axle steering: status: Normal oper.
                    Dynamic all wheel drive: overall system status-Dynamic all wheel drive: regulator status: Initializing
                    Dynamic all wheel drive: overall system status-Rear axle steering: status of dynamic all wheel drive: Initializing
                    Dynamic all wheel drive: overall system status-Dynamic steering: status of dynamic all wheel drive: Initializing
                    Systemverbund - Diagnose-QSP Status: 0
                    Systemverbund - Diagnose-Elektroantrieb 1: Istmodus: 0
                    Systemverbund - Diagnose-Elektroantrieb 2: Istmodus: 0
                    Systemverbund - Diagnose-Elektroantrieb 3: Istmodus: 0
                    Systemverbund - Diagnose-Verlagerungsverbot: kein Verbot
                    Systemverbund - Diagnose-Drehmomentanforderung: Summe: -50000 Nm
                    Systemverbund - Diagnose-eAWS Status: 0
                    Systemverbund - Diagnose-Luftfederung: Status: 0
                    Systemverbund - Diagnose-Straight line running factor: -0.100
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120754
   Coding: 01C020FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809FD326276030B3BB-807C
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SHE00023
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C21316286EEBFAB4F3-8068
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4KL 919 617     HW: 4KL 919 617
   Component: HeadupDisplay H05 4910
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 0C41A1A296CE4F2B3F3-8058
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU58.rod
   VCID: 41DF4096E10CD2431C5-8014
   Battery Junction Box:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H13 0369
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AM    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0293
   Coding: 022184000000000000FBD60000F4470E139E5600000000000000000000969401019BA8000000000000000080000000000000000000000000F980400000000000000078D80000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 0A4DA7BA9CBA511B0DF-805E
2113949 - Databus
          [Bremse_EV_01_EBKV_Bremspedalweg]
                    Reset counter: 192
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:41:42
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [008] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 192
                    Mileage: 8964 km
                    Date: 2020.06.06
                    Time: 11:59:52
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 34 °C
                    Vehicle speed: 119.84 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: No
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
233479 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
                    Reset counter: 192
                    Mileage: 8954 km
                    Date: 2020.06.05
                    Time: 16:40:59
233523 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                    Reset counter: 192
                    Mileage: 8954 km
                    Date: 2020.06.05
                    Time: 16:39:34
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 32
                    Reset counter: 209
                    Mileage: 8954 km
                    Date: 2020.06.05
                    Time: 17:13:24
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0387
   Serial number: 0000386536769
   Coding: 000DDB0100001482E008A020
   ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
   Component: TSG HBFS      010 0387
   Serial number: 0000386536768
   ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4KE 035 335     HW: 3F0 035 335
   Component: E_SOUND_SGH05 0121
   Serial number: EN193407510000
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
   VCID: 77ABEE4EFF485CF3621-8022
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0061690
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.5W.4C20370105
   Air Conditioning Compressor Sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019062900505
   Geber für Kältemitteldruck/Kältemitteltemperatur 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Coolant heater:
   Subsystem 5 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.5W.2C20370085
   Refrigerant Expansion Valve 2:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150931759
   Refrigerant Shut Off Valve 2:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130842464
   Refrigerant Shut Off Valve 3:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130841940
   Refrigerant Shut Off Valve 4:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130843000
   Refrigerant Shut Off Valve 5:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130841652
   Radiator shutter:
   Subsystem 11 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20190729060404054137
   Radiator Shutter 2:
   Subsystem 12 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V550KJS2  H13 0110
   Serial number: 20190806060103051564
   Coolant valve 1:
   Subsystem 13 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000134065
   Coolant valve 2:
   Subsystem 14 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000096816
   Coolant valve 3:
   Subsystem 15 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000127747
   Coolant valve 4:
   Subsystem 16 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000139824
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: ---------------
   Coding: 2A49A44542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F583CA188245FB597-8002
   Coding: 228040051602
   VCID: 75B7E446E5442EE370D-8020
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 J    HW: 0EF 907 180 C
   Component: CUBZE683Q0AD2 H03 0010
   Revision: --------    Serial number: -00118.05.19000
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 3E253B6A90F2ADBB617-806A
                    Mileage: 8951 km
                    Date: 2020.06.04
                    Time: 13:34:48
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0426
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71BFD056912C02C3AC5-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4KE 907 669     HW: 4N0 907 669 A
   Component: MRR_VR H12 0426
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651_AU58.rod
   VCID: 094F98B699BC5A03045-805C
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0426
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 2313EA1E1B50E0536E9-8076
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
End----------(Elapsed Time: 03:09, VBatt start/end: 13.2V/13.2V)-----------
Since you are verified now, moving this to Tweaks.
I don't know what the security code required to change that channel in this ABS module might be.
Hopefully, someone else will have some codes you can try.
You'll want to watch the following measuring value when trying unverified codes:
IDE00323 -- Security Access: Number of invalid keys
If it's not zero when you try one, wait for it to revert to zero before trying a different one.
BTW, is it safe to assume you have the hood of the vehicle open when trying to make changes? That's probably essential on this vehicle.
bluetomato
C?ID=407511
Thanks for validating my account.
So where would I be able to obtain this code if not in the service manual?
Yes, I did have the hood open when I attempted to make the change.
Sadly, those are rarely published in any official way by VW/Audi, and people who get a hold of them are usually no willing to talk about the methods they've used to obtain them.
Give it some time, I'm confident the members here will provide suggestions.
NEtech
Denmark
C?ID=56995
Copy this file to:
C:\Ross-Tech\VCDS\Labels\User
Hood open as Uwe described.
Ignition On
Ignition Off 15 sec.
Ignition On
Then first test the showed 40168
Is it accepted ?
If so can Adaptation channel be changed ?
What channel are you trying to change, IDExxx ?
Have you checked all MMI/Infotainment settings and car user manual ?
bluetomato
C?ID=407511
Copy this file to:
Ignition On
Ignition On
Is it accepted ?
That security code worked! I logged into the ABS control module and was able to set the disk brake wiper function to off. To make sure the changes stayed, I turned off the car, closed VCDS, disconnected the HEX V2, restarted the car and launched VCDS. The change is still there. I will perform some real world testing to ensure this function is off. What other information would you like from me to log this?
Thanks!
EDIT: After driving in some rain, I have not felt the wiping function operate which is the desired behavior. I will keep testing.
I'd love to understand how NWtech came up with the code.
40168 is a very common security access code for ABS modules. In fact, it's so common that I'm quite surprised it worked for this purpose; it offers no real "security" at all.
bluetomato
C?ID=407511
I guess I am glad that Audi didn't decide to be too different and not care that much about being secure. So do all of the modules require a security code to access or is it just specific ones like the ABS module? Is there a place where other codes for other modules are listed I can reference?
Thanks!
There is no pat answer to this question. Some modules may require security access codes to change certain channels, and/or to change coding, while some channels may not require it, and many modules will accept coding changes without a security access code.
No, not really. When a code is known to be applicable to a particular module, we generally try to include it in the balloon hint that VCDS will give you if you pause for a bit on the Security Access screen.
bluetomato
C?ID=407511
Just a follow-up question related to this thread. Through a series of unfortunate events, I am being given an option to replace my 2019 eTron with a 2021 model when they become available in a few months. I also have the option to walk away entirely. While I like many things about this vehicle, I absolutely hated the brake disc wiper feature and am very glad I was able to turn that off in my 2019 eTron. I hated the feature so much that I would actually pass on the 2021 eTron if I knew it wasn't able to be turned off on the 2021 eTron. The question now becomes: can it be turned off on a 2021? As far as I am aware, no major hardware changes are scheduled for the 2021MY, though I did read somewhere that Audi may look to improve the performance of the infotainment system. Is it possible to reasonably assume VCDS will be able to still connect to the ABS model on a 2021 vehicle? Or would Audi completely redesign things such that VCDS might not work? I suppose it is possible VCDS will continues to work fine on the 2021 vehicle, but the ABS module no longer exposes the option to disable the brake disc wiper. I realize this is a nearly impossible question to know the answer to until a 2021 is actually tested, but are there any early indications from those more connected with the industry that might know if there are going to be major changes to Audi modules in the eTron or other models? Any input will help me make a more informed decision.
This.
We get no advance info from them.
bluetomato
C?ID=407511
Succinct and to the point. Thank you for the quick response. I have a hard time believing Audi would make major changes to the modules in the middle of a product life-cycle -- or any manufacturer for that matter -- but I also don't know VAG very well. VCDS has worked with VAG vehicles for a very long time and I would assume it would going forward, but you know assumptions are a bad thing to make sometimes. :)
I'm not too worried that VCDS won't work, but I can't promise that any particular tweak will still be available. Removing a tweak is not a major change, and it's happened before, without any other obvious changes. That said, brake disk wiping options have been around for a while, and I don't anticipate them going away.
