Hi guys!
I'm new here and a fresh VCDS owner.
I got two questions about this Audi
1. I would like to disable engine shut down when i open driver's door(it's annoying)
2. I got bluetooth but only as a handsfree. Is it possible to activate media streaming via bluetooth?
Thanks for help!
Here is my autoscan:
Thanks for help!
Friday,12,June,2020,14:46:00:52611
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8K9DA080029 License Plate:
Mileage: 199500km-123963mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K9DA080029 Mileage: 199500km-123963miles
Address 01: Engine (J623-CJCA) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 HT HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9978
Revision: 45H25---
Coding: 12034012232401080000
Shop #: WSC 61027 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018HT 003009
ROD: EV_ECM20TDI01103L906018HT.rod
VCID: 035276E00B99C0234E9-8056
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K2 927 155 G HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H04 0008
Revision: --H04--- Serial number: 0000000137
Coding: 000002
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMVL381 A02432
ROD: EV_TCMVL381.rod
VCID: 392ED40839D54AF3545-806C
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Coding: 171544
VCID: 005879EC1A0FDB3B53B-8054
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H11 0621
Coding: 01824040000000000000
VCID: 79AE140879D58AF3145-802C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000034203015
Part No SW: 8K1 820 043 AC HW: 8K1 820 043 AC
Revision: C0000000 Serial number: 01020620120091
Coding: 342002E000
VCID: 698E444809753A73E45-803C
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000430891902
Coding: 260000108034AFC00081400000001D0D0F1C470826090201000008004401020100000020000000
VCID: 77AA12304FC19C83621-8022
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290512 H07 0070
Serial number: SWF12050295493
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20310969
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002205120715
Serial number: 4118CF26000000000001
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD93DAAA
Coding: 30514435363030303030554A304C384B3053
Shop #: WSC 58131 001 1048576
VCID: 48C8A1CC723F237BDBB-801C
Serial number: 6334MSME6D131871D
Serial number: 6344MSME694305326
Serial number: 6352QSME00151960%
Serial number: 6362QSME78174756N
Serial number: 63732SME63161A6E3
Serial number: 63832SME57155076-
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120604000255
Coding: 000017
VCID: 4FFA8AD097D1F4439A1-801A
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 931 J HW: 8K0 920 931 J
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBJ723Y5D
Coding: 0FC6100002010008010100
VCID: 3536D838154DAE93B0D-8060
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y1251103CF
Coding: 80CF07FF00
VCID: 44D0B5FC4E97071B373-8010
Serial number: 0640947401
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 12152001148011200181
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000030959802
Coding: 011C02205C00410001
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0005560604
Coding: 100000000001
Shop #: WSC 00995 264 95883
ROD: EV_RCEPSAU48X_008.rod
VCID: 3430E53C1EB7B79B873-8060
Revision: 00002001 Serial number: 0177658956
Coding: 013A062020B90080812002328000000F
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000031143329
VCID: 4EC497D490DBFD4B917-801A
Part No SW: 8K0 907 801 K HW: 8K0 907 801 J
Component: EPB-4 H01 0002
Revision: -------- Serial number: 30000000060344
ROD: EV_ParkiBrake_AU48.rod
VCID: 372AD2300FC15C83A21-8062
Part No SW: 4G1 035 053 H HW: 4G1 035 053
Component: Radio U Basic H41 0134
Revision: AB001007 Serial number: 226FY0C7558023
Coding: 010003020100000001
VCID: 2410157CAED7271B173-8070
Part No SW: 8R1 035 652 F HW: 8R1 035 652
Component: B-BN-EU H62 0191
Revision: -------- Serial number: 148F00C7534647
Coding: 01010001020681ED01804F4E000000030000
VCID: 3634DF34084BA58BB97-8062
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Serial number: 9465EX0C2543093
Subsystem 2 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Serial number: 00000001169325
Reset counter: 107
Mileage: 199500 km
Date: 2020.06.12
Time: 14:43:37
Voltage: 12.10 V
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000030798069
Coding: 010C02204000210001
VCID: 46D4AFF478AB350B297-8012
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000030796440
End----(Elapsed Time: 01:30, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
