Passat B8 MY15 trailer hitch retrofit
symb
Finland
C?ID=354278
I retrofitted a westfalia hook with CFC trailer module TM005 to my MY15 passat.
My question is: does the ABS module 03 need coding for trailer stabilization and/or something else regarding the trailer hitch, or is it done with adaptation? There is an "vehicle and trailer stabilization" - adaptation there which I enabled already.
I've successfully coded the trailer module to all the other necessary modules. Everything is working fine, car recognizes when trailer is attached and the rear parking sensors are disabled. Infotainment shows trailer attached.
Here's the adaptation:
Address 03,3Q0 907 379 AF,channel IDE04774-Vehicle and trailer stabilization,adapted from,not activated ,to,activated ,Thursday,11,June,2020,20:57:43:29066
And here is the abs module coding, which is unchanged.
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 63464000002522
   Coding: 0FEC6A8F34230B75077B060641C649F0562CD0E0608292F13040F078C022
   VCID: 7EA5FCAE50706D5B217-802A
Here is also complete autoscan, note that this is taken before the trailer hitch codings in particular modules.
I had the battery disconnected, hence all the errors. It's all clear now.
Thursday,11,June,2020,19:13:27:29066
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZFE439463   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69 A5
VIN: WVWZZZ3CZFE439463   Mileage: 259750km-161401miles
Address 01: Engine (J623-DCXA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 GJ    HW: 04L 907 309 R
   Component: R4 1.6l TDI   H21 1991
   Revision: B5H21---
   Coding: 0119003A03241D093000
   Shop #: WSC 41930 002 1048576
   ASAM Dataset: EV_ECM16TDI01104L906026GJ 002002
   ROD: EV_ECM16TDI01104L906026GJ_VW48.rod
   VCID: 78A9EAB67254536B6BB-802C
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [036] - -
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:37
                    Engine speed: 0.00 /min
                    Coolant temperature: 26 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.920 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
          U0428 00 [036] - -
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:36
                    Voltage terminal 30: 11.940 V
                    Cruise Control System (CCS): status-Bits 0-7: 2
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:37
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 47
                    Mileage: 257483 km
                    Date: 2020.05.07
                    Time: 17:09:19
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:47
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:47
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0356001440
   Coding: 000F0F0603
   Shop #: WSC 05311 115 00309
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 77ABE98A7F4A5C13621-8022
   Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Revision: 00001K10
   Coding: 12020104204101012115504000101802
   Shop #: WSC 00015 115 00001
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 70B9D2961A240B2BA3B-8024
   Air quality sensor:
329988 - Motor for Defroster Flap
          B1090 71 [009] - Actuator stuck
                    Fault Frequency: 19
                    Reset counter: 37
                    Mileage: 255313 km
                    Date: 2020.03.03
                    Time: 07:46:14
                    Voltage terminal 30: 12.1 V
                    Outside air temperature: 0.5 °C
                    Interior temperature: 20.4 °C
                    Defroster flap: actual value: 0.0 %
                    Defroster flap: actual value: 24
                    Defroster flap: specified value: 52
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86581212141103
   Coding: 00010E46C24102FF4BE44004001C07081C80000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA7FBA25D76764338D-8028
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    141122  042 0607
   Serial number:         141128155550
   Component: RLHS  037 0059
   Serial number: S4Y14M12D18H09M48S35
   Coding: 05A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 27 10 2014  00000508
10506 - Bulb for Left Tail Light
          B12BE 15 [009] - Open or Short to Plus
                    Reset counter: 41
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 03:08:40
10762 - Bulb for Right Tail Light
          B12BF 15 [009] - Open or Short to Plus
                    Reset counter: 41
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 03:08:40
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 32
                    Mileage: 259326 km
                    Date: 2020.06.03
                    Time: 19:48:18
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00118.12.14
   Coding: 0051063041
   Shop #: WSC 05311 115 00083
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_008.rod
   VCID: 3FDB41AA17FAA4536A1-806A
13637426 - Databus
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:37
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 2A21604314FFC428949C8044
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 33331D9A2BB270339E9-8066
8 Faults Found:
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:38
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 11.9 V
                    Status_ACC_System: ACC_Init
0795 - Databus
          [FAULT_APS_RELEVANT_ERROR]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:37
                    Control Module temperature: 26 °C
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:37
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 41
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 23:02:13
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 11.8 V
0862 - Databus
          [FAULT_DIRECTION_OF_TRAVEL_INVALID_SIGNAL]
                    Fault Frequency: 17
                    Reset counter: 74
                    Mileage: 251009 km
                    Date: 2020.01.13
                    Time: 07:42:18
                    Control Module temperature: 7 °C
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: -0.15 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.32 m/s²
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:37
1538 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_SENSOR_BLIND]
                    Reset counter: 46
                    Mileage: 257581 km
                    Date: 2020.05.11
                    Time: 07:18:46
                    Control Module temperature: 15 °C
                    Voltage terminal 15: 14.5 V
                    Velocity_vehicle_reference: 25.59 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
1542 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 46
                    Mileage: 257581 km
                    Date: 2020.05.11
                    Time: 07:18:46
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2PS7HWLX
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 025D885E248809BB45F-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 000 912 14
   Serial number: 3576U0000005C1C03211
   Subsystem 2 - Part No SW: -----------    HW: 454 000 912 14
   Serial number: 3586U000000A29D03216
   Subsystem 3 - Part No SW: -----------    HW: 454 801 812 14
   Serial number: 3516RDB4965050000009
   Subsystem 4 - Part No SW: -----------    HW: 454 800 912 14
   Serial number: 3526R54AE67050000008
   Subsystem 5 - Part No SW: -----------    HW: 454 801 011 14
   Serial number: 3556VC9D012050000006
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141212400693
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D273BA21DF6B64378D-8068
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4311
   Coding: 03A509106B84000801883A021001000000000000
   Shop #: WSC 58575 001 104857
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 619FA7D2C1CEB2A33C5-8034
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 3635248E38C0651BB97-8062
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001048974
   Revision: --------    Serial number: 06121410800841
   Coding: 030300044F015900EF00024A080F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BDD89E1428393B55F-8026
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140003054030124492
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 5488785203
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 14000312745010
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD792112E0223AC5-8024
   Serial number: 061214BL601949
   Coding: 00350B208000020000001000
   VCID: 42DD485E6408C9BB05F-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000564084
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000103862
   Coding: 01010011005000
   Shop #: WSC 00015 115 00315
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B2335BA03E2B873469-806E
5262656 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:35
                    Write only channel
   Serial number: 271114AKR02464
   Coding: 003501208C00020000001000
   VCID: 41DF4752610ED2A31C5-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000598768
   Coding: 090000
   Component: AFS-ECU       H01 0110
   Coding: 039A00004F200200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 5G0 035 869     HW: 5G0 035 869
   Component: MU-E--ER      820 6220
   Serial number: 10101400011002
   Coding: 02840200FF00000041110001000000001F0004840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW48.rod
   VCID: 6B83C5FA3302E8F3969-803E
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   VCID: 392F2FB209DE8A63545-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H06 0271
   Serial number: 08101612P11893
   Coding: 000408020000040100220044C046810094000E300040
   Shop #: WSC 48779 003 104857
   VCID: 3C2136A606ECBF4B4F3-8068
1135140 - Databus
          [APS_03_US_Fehler_HS]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:38
                    Control Module temperature: 37 °C
                    Outside air temperature: 22.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.6 s
                    mid: 02 65
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
          [APS_03_US_Fehler_VS]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:38
                    mid: 02 64
                    Software_Info_4: 1
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 81
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 00:01:38
                    System run time: 3.3 s
                    mid: 02 E0
                    Software_Info_4: 1
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123187 - Local Data Bus
          U116B 00 [009] - Received Malfunction Value
          [RDR1_Header_FGN_Status]
                    Reset counter: 41
                    Mileage: 259750 km
                    Date: 2020.06.10
                    Time: 23:02:13
                    Control Module temperature: 44 °C
                    Outside air temperature: 24.5 °C
                    System run time: 9.3 s
                    Voltage terminal 15: 11.7 V
                    mid: 02 C0
                    Software_Info_4: 1
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:13, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Thanks in advance for any help or confirmation.
downtime
Finland
C?ID=280813
There's one coding bit you need to enable in ABS. I'll update this post in a few minutes on what it is unless someone beats me to it :)
edit :
Byte 24 bit 7 is ARA Trailer assist in ABS
So if you want to try you could enable that. Not sure if it's necessary.
symb
Finland
C?ID=354278
edit :
I wonder if it's indeed necessary since I don't have the trailer assist function?
Thanks anyway!
NEtech
Denmark
C?ID=56995
I don't think so, it will probably set a DTC.
In my opinion that is only necessary, if the car has PR code:
8A9 Trailer Assist with park assist
This ABS is not coded for trailer.
