R8 MK1 Telephone module issues.
K O Motorsport
C?ID=294244
Hi there, got a 2008 R8 Coupe where the Bluetooth hands-free will not work. On the RNS-E unit, it says telephone not available. When I try to connect to the module via VCDS, the program just freezes. I have verified terminal 30 power and 31 ground. and had tried swapping the part (8P0862335R), as I hear that it is not uncommon for these boxes to go awry. But swapping the module out had made no changes. Other infotainment units report that they do not see it available. See Below for the autoscan.
TIA
D
Tuesday,02,June,2020,15:32:04:20233
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WUAAU34238NXXXXXX   License Plate:
Mileage:           Repair Order:
Chassis Type: 42 (1K0)
Scan: 01 03 08 09 0F 11 31 14 15 16 17 19 25 37 42 46 47 52 56 65
          6C 76 77
VIN: WUAAU34238NXXXXXX   Mileage:
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 1010
Address 01: Engine (   )       Labels:. 079-910-560-BYH1.clb
   Part No SW: 420 910 560 A    HW: 420 907 560
   Component: 4.2L V8/4V FSI     ª0100
   Revision: 5DH09---    Serial number: AUX7Z0H2FNS0C3
   Coding: 01100009180F0120
   Shop #: WSC 22130 444 84966
   VCID: 8C5403CEEF04DEE6EE-80D8
001393 - Brake Switch (F)
               P0571 - 004 - Implausible Signal - Intermittent
                    Date: 2020.03.30
                    Time: 00:00:22
                    RPM: 124 /min
                    Load: 100.0 %
                    Temperature: 13.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 7.239 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Date: 2020.06.02
                    Time: 15:23:27
                    Temperature: 23.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
Address 03: ABS Brakes        Labels: 420-910-517.lbl
   Part No SW: 420 910 517 A    HW: 420 614 517
   Component: ESP8 quattro    H01 0260
   Coding: 0000258
   Shop #: WSC 02556 785 00200
   VCID: 8E5009C69918ECF600-80DA
                    Reset counter: 207
                    Mileage: 27546 km
                    Date: 2020.03.30
                    Time: 00:00:17
                    Hex Value: 0x0000
                    Hex Value: 0x0220
                    Hex Value: 0x0023
                    Hex Value: 0x017F
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 420-820-043.clb
   Part No SW: 420 820 043 C    HW: 420 820 043 C
   Component: J255  Klima 1 Zone  0070
   Revision: 00H04005    Serial number: 00000001082653
   Coding: 1572904
   VCID: 8A5805D6E570C0D6DC-80DE
00657 - Positioning Motor for Central Vents (V102)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 206
                    Mileage: 23530 km
                    Date: 2019.07.18
                    Time: 16:31:56
                    Voltage: 12.50 V
                    Temperature: 31.0°C
                    (no units): 110.0
                    (no units): 35.0
                    Temperature: 30.0°C
                    Reset counter: 220
                    Mileage: 28080 km
                    Date: 2020.04.05
                    Time: 23:30:47
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 L    HW: 8P0 907 279 L
   Component: Bordnetz-SG     H45 1901
   Revision: 00H45000    Serial number: 00000008164941
   Coding: F4041E83C01424000B0000000A800000000000005B06D282000000000000
   VCID: C6C0F1E6B1E864B6F8-8092
   Subsystem 1 - Part No: 423 955 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiR8  H22 0040
   Coding: 00022802
   Shop #: WSC 02556
   Coding: 00154418
   Shop #: WSC 02556
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0265577
   Coding: 0000100
   Shop #: WSC 02197 785 00200
   VCID: B326B832D27AE11E4F-80E6
01304 - Radio
                    Reset counter: 246
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 13:40:39
Address 11: Engine II        Labels:. 079-910-560-BYH2.clb
                    Date: 2020.03.30
                    Time: 00:00:22
                    RPM: 125 /min
                    Load: 100.0 %
                    Temperature: 13.0°C
                    Temperature: 15.0°C
                    Voltage: 7.239 V
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 420 910 376     HW: 420 907 376
   Component: J250 Raddaempfung   0080
   Revision: --H15---    Serial number: 190DPH 8053054
   Coding: 0000062
   VCID: D0ECD7BE43ACBA0652-8084
Address 15: Airbags        Labels: 420-959-655.lbl
   Part No SW: 420 959 655     HW: 420 959 655
   Component: SN Airbag 9.43  H01 0020
   Revision: 93H01002    Serial number: 003B800062VI
   Coding: 0021326
   VCID: DDF23E8A047E076EC9-8088
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 025P7
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB403A467ADVÿ†63
   Subsystem 5 - Serial number: 467ADVÿ†63428RB403A46A8DXÿ†63
   Subsystem 6 - Serial number: 46A8DXÿ†63747RB4036C4FFA5ÿ†63
   Subsystem 7 - Serial number: C4FFA5ÿ†63847RB4036C5063Jÿ
   Subsystem 8 - Serial number: C5063Jÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0004041
   VCID: C1CAE2FA98C6438ECD-8094
   Component: E0221           H06 0030
01301 - Control Module for Voice Recognition (J507)
01304 - Radio
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 980 E    HW: 420 920 980 E
   Component: KOMBIINSTR. VDO H35 0160
   Revision: D0H35002    Serial number: 2242H002100370
   Coding: 0085288
   Shop #: WSC 20211 444 84457
   VCID: 977E6CA2A6C22D3E53-80C2
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K08316860A
   Coding: AB881F0F5047024100
   VCID: B424BB2ED774E62656-80E0
                    Reset counter: 246
                    Mileage: 28426 km
                    Date: 2020.05.04
                    Time: 13:09:20
01304 - Radio
                    Reset counter: 246
                    Mileage: 28426 km
                    Date: 2020.05.04
                    Time: 13:09:20
                    Reset counter: 206
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 15:23:32
   Revision: D0H35002    Serial number: AUX7Z0H2FNS0C3
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 423 035 192 F    HW: 423 035 192 F
   Component: RNS-E US        H15 0260
   Revision:      08S    Serial number: AUZBZ7H3900374
   Coding: 0710677
   VCID: 936618B2B23A011E2F-80C6
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 246
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 12:18:05
                    Mileage: 29030 km
                    Count: 206
                    Clock: 14:32
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                    Reset counter: 246
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 12:18:05
                    Mileage: 29030 km
                    Count: 206
                    Clock: 14:32
                    Reset counter: 206
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 15:23:48
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 420 959 801
   Component: Tuer-SG         H02 0060
   Coding: 0001141
   VCID: D6E021A66148D43688-8082
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433 C
   Component:    KSG          H11 0080
   Coding: 1B90228201382D090F0FC88A0473
   VCID: B6208126C108F43668-80E2
Address 47: Sound System        Labels: 420-035-223.lbl
   Part No SW: 420 035 223 D    HW: 420 035 223 A
   Component: J525 Amp High   H14 0230
   Revision: 00H14001    Serial number: 34842000787105
   Coding: 0246111
   Shop #: WSC 22133 444 16733
   VCID: 895A3ADAE076CBCED5-80DC
                    Reset counter: 206
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 15:23:32
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 420 959 802
   Coding: 0001141
   VCID: D7FE2CA26642ED3E93-8082
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0710677
                    Reset counter: 246
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 12:18:05
                    Mileage: 29030 km
                    Count: 206
                    Clock: 14:32
                    Reset counter: 246
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 12:18:05
                    Mileage: 29030 km
                    Count: 206
                    Clock: 14:32
                    Reset counter: 206
                    Mileage: 29031 km
                    Date: 2020.06.02
                    Time: 15:23:48
Address 65: Tire Pressure        Labels: None
   Part No SW: 420 910 273     HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0030
   Revision: 00050030    Serial number: 00000700003408
   Coding: 0462426
   Shop #: WSC 64727 003 1048576
   VCID: CCD4C3CEAF849EE62E-8098
Address 6C: Back-up Cam.        Labels: 420-910-441.clb
   Part No SW: 420 910 441     HW: 7L6 907 441 C
   Revision: --H13---    Serial number: 525PA8-J83602L
   Coding: 1000412
   Shop #: WSC 00477 128 50186
   VCID: C9DAFADAA0F68BCE15-809C
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283 B    HW: 8P0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: 00H12000    Serial number: 00067767830808
   Coding: 0000251
   VCID: BA389516F51010568C-80EE
Address 77: Telephone
End----------(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V)-----------
Wednesday,10,June,2020,14:23:23:20233
MartinsX
Riga, Latvia
C?ID=268515
Constant power (30) and ground (31) is ok, but You need CAN and probably switched power (15), too, to get module to communicate. Have You checked those, too?
DrPeter
16.4905° S, 151.7375° W
You may want to verify the infotainment CAN bus (High/Low) at the R36-Telephone transmitter and receiver unit. The CAN bus signal is a square wave 0V to 5V signal that when checked with a DVOM you should see the 'average' voltage of each CAN bus wire.
Typically the average of these two voltages will add up to about 5.0V. Typically there is about 1.5V to 3.5V on each, CAN H/L
Based on a little digging in the wiring diagram, the R36 is part of the Infotainment CAN bus and these CAN bus wires have a common connector (T17) a "17-pin connector, in right center console coupling station, red" according to the Official Factory Repair Information/Wiring Diagrams. Maybe there is a concern there???
That part number you have, 8P0-862-335-R, actually has been superseded five (5) times!.. So maybe it has also failed? The newest part number I can see is [8P1-862-336-A]. I would verify this with the local parts department with the VIN to be sure... because there are several VIN spits for these R36 controllers.
Hope this helps and let us know what happens,
drpeter
MartinsX
Riga, Latvia
C?ID=268515
DrPeter, can You check also, do this module has a separate 15 wire or it wakes-up from CAN signal? I don't have WD available at the moment.
DrPeter
Hi, there is only (30-Power) and the (31-Ground), CAN bus, antennas, 'telephone bracket' and connections to the Radio and Navigation controllers.
I would suspect there is a wake-up signal from the CAN bus, based on what I see.
Were you able to check for signals at the CAN bus wiring? Also for the small amount erWin charges for repair manual, it is 100% worth it ;)
Keeps informed and post up what you find!
drpeter
K O Motorsport
C?ID=294244
I have verified there is 0.58v between CAN High infotainment and 4.46v on CAN Low infotainment, measured between terminal 31 on connector T54, the connector for the telephone module. I believe I removed the offending module from the car in the first autoscan. I reconnected the telephone module and modified the autoscan.txt file to do an auto-scan with the address 77 removed from it.
Monday,15,June,2020,09:23:49:20233
Mileage: -   Repair Order:
Chassis Type: 42 (42 - Audi R8 (2007 > 2015))
Scan: 01 03 04 08 09 0F 11 31 14 15 16 17 19 25 37 42 46 47 52 56
          65 6C 76
VIN: WUAAU34238Nxxxxxx   Mileage: -
Readiness: 0110 0101
   Coding: 0000258
   Coding: 1572904
                    Reset counter: 207
                    Mileage: 29032 km
                    Date: 2020.06.14
                    Time: 20:04:31
                    Voltage: 12.00 V
                    Temperature: 19.0°C
                    (no units): 247.0
                    (no units): 35.0
                    Temperature: 18.0°C
   Coding: 00022802
   Shop #: WSC 02556
   Coding: 00154418
   Shop #: WSC 02556
   Coding: 0000100
   Coding: 0000062
   Coding: 0021326
   Coding: 0004041
   Coding: 0085288
   Coding: 0710677
   Coding: 0001141
   Coding: 0246111
   Coding: 0001141
   Coding: 0710677
   Coding: 0462426
   Coding: 1000412
   Coding: 0000251
End----------(Elapsed Time: 01:31, VBatt start/end: 12.1V/12.1V)-----------
D
DrPeter
D
Hi, so does this mean there is no more "telephone not available" message? and that you are going to leave the vehicle the way it is?
drpeter
K O Motorsport
C?ID=294244
Yes, the 'Telephone not available' is still present. Thinking of sourcing an updated unit and trying that. Am planning on adding A2DP audio steaming capability to the car probably by hijacking the CD Changer. Don't want to use some silly aftermarket microphone to do phone calls though.
K O Motorsport
C?ID=294244
Resolution
Sorry it has been a while, managed to get an updated unit for the car. plugged it in and worked like a charm. wasn't too much to do as far as making it work, just turned up the microphone gain a tad after testing it.
D
