Hello Everyone,
My daughter is home from college but will hopefully be heading back and this problem turned up.
The car runs well under most circumstances, but during heavier acceleration, like getting on the freeway, it runs very rough, the check engine light blinks.
The first time it happened, the light went back off when I reached cruising speed. The second time the light stayed on.
The car has had a new PCV valve about 10K or 20K miles ago. I also did the timing belt, water pump, tensioner, drive belt, thermostat a few thousand miles back. The car has been running fine since the work though, so I don't think the repairs are involved.
I did look the codes up in the wiki. Hoping for a little help in ways to use my VCDS to further narrow down the possibilities.
Thanks,
Greg
Thanks,
Greg
Friday,05,June,2020,11:03:03:43616
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWAK93C26P0XXXXX License Plate: XXXXXXX
Mileage: 220900km-137260mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 53 56 62
65 72
VIN: WVWAK93C26P0XXXXX Mileage: 220900km-137260miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 G
Component: 2.0l R4/4V TFSI 0020
Revision: --H10--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 22595 444 53395
VCID: 2313EDC877DF5E136E0-8076
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Fault Frequency: 9
Mileage: 218187 km
RPM: 1391 /min
Load: 20.8 %
Temperature: 15.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.557 V
P0300 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 220867 km
Date: 2020.05.21
Time: 11:20:49
RPM: 3914 /min
Load: 85.1 %
Speed: 82.0 km/h
Temperature: 60.0°C
Temperature: 23.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.224 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Fault Status: 00100001
Mileage: 220867 km
Date: 2020.05.21
Time: 11:20:49
RPM: 3914 /min
Load: 85.1 %
Speed: 82.0 km/h
Temperature: 60.0°C
Temperature: 23.0°C
Voltage: 14.224 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected
Fault Status: 01100001
Mileage: 220891 km
Date: 2020.06.03
Time: 10:43:53
RPM: 2863 /min
Load: 71.0 %
Speed: 36.0 km/h
Temperature: 91.0°C
Temperature: 29.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.843 V
Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ
Component: AQ 250 6F 0736
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 7BA3F5A8AFEFC6D3060-802E
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 N HW: 3C0 614 095 N
Component: ESP 440 C2 H015 0001
Revision: H015 Serial number: 0657810824
Coding: 0013755
Shop #: WSC 22595 444 85712
VCID: 2D070BF0211B9863C84-8078
02840 - Wake-Up Line from Central Convenience Module
Reset counter: 108
Mileage: 219828 km
Date: 2020.03.03
Time: 23:11:12
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
VCID: 70B9D284F6A9B58BA32-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003366421
Coding: 148C0F0340041A00000A00000F00000000285D435C
VCID: 2B0305E81F0F9653D60-807E
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 00028
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 111
Mileage: 220846 km
Date: 2020.04.21
Time: 17:53:00
Voltage: 10.20 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E4026668
Fault Frequency: 63
Reset counter: 113
Mileage: 187340 km
Date: 2017.11.04
Time: 10:53:04
01304 - Radio
Fault Status: 01101000
Mileage: 192757 km
Date: 2018.06.14
Time: 00:01:06
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 G HW: 3C0 909 605 G
Component: 0B AIRBAG VW8R 029 2421
Revision: 09029000 Serial number: 0039VSDEQ1KG
Coding: 0012354
VCID: 2A0D00EC10F58F5B2D6-807E
Subsystem 1 - Part No: 3C0 959 339
Component: BF-Gewichtsens. 006 0001
Subsystem 2 - Serial number: 000000000333NT
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0B0A24716ÿ†63
Subsystem 5 - Serial number: A24716ÿ†6342MSME0B1217251ÿ†63
Subsystem 6 - Serial number: 217251ÿ†6351HTS604FIP2N2Cÿ†63
Subsystem 7 - Serial number: IP2N2Cÿ†6361HTS604FMA9M28ÿ†63
Subsystem 8 - Serial number: MA9M28ÿ†63727TS604F6S6P22ÿ†63
Subsystem 9 - Serial number: 6S6P22ÿ†63827TS604F6KOQ2Eÿ
Subsystem 10 - Serial number: 6KOQ2Eÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507R
Coding: 0002013
VCID: 313F17803D23FC83ECC-8064
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 H HW: 3C0 920 970 H
Component: KOMBIINSTRUMENT VD1 3938
Revision: X0032000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 22116 067 57207
VCID: 290FFFE015F3844324C-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C056170198
Coding: 3FFD0E14D31002
VCID: 211FE7C06DC34C037CC-8074
01304 - Radio
Reset counter: 143
Mileage: 192757 km
Date: 2018.06.14
Time: 00:00:05
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00002000 Serial number: 1166279TN62P04
VCID: 6D87CBF0E19B5863884-8038
Part No SW: 3C0 959 433 Q HW: 3C0 959 433 Q
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 27776 002 1048576
VCID: 38292AA4DE592DCBAB2-806C
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 109
Mileage: 219828 km
Date: 2020.03.03
Time: 23:10:47
02861 - Electronic Steering Column Lock Check Sum Error
Fault Frequency: 9
Reset counter: 103
Mileage: 218187 km
Date: 2019.12.22
Time: 21:14:53
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2359
Coding: 0001205
VCID: 3635249CD44DDBBBB9E-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 303912843629F58BE32-8064
00573 - Steering Torque Sensor (G269)
Component: KSG PQ46 RDK 051 0218
Coding: 1B910F8801862E521804151FF00A0F0E081800
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 A HW: 3C0 035 456 A
Component: DSP 10 Kanal 0008
Revision: 00008000 Serial number: 00000000003842
VCID: 1E65DC3C5CBD73FB41E-804A
Fault Frequency: 83
Reset counter: 109
Mileage: 216980 km
Date: 2019.11.27
Time: 10:26:35
Reset counter: 101
Mileage: 172582 km
Date: 2016.12.15
Time: 19:19:06
Reset counter: 75
Mileage: 173721 km
Date: 2017.01.07
Time: 20:08:58
00871 - Bass Speaker Front Right (R23)
Fault Frequency: 30
Reset counter: 104
Mileage: 216985 km
Date: 2019.11.28
Time: 00:00:01
Reset counter: 75
Mileage: 174402 km
Date: 2017.01.20
Time: 08:11:43
Fault Frequency: 222
Reset counter: 1
Mileage: 179414 km
Date: 2017.03.21
Time: 19:02:04
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
VCID: 372B2998D34722B3A28-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2417
Coding: 0000144
Component: RDK 0420
Coding: 0100100
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D188C3825C79B956-8066
End----(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
