2016 vw GLI component protection
acr1975
C?ID=341829
hi, 2016 vw GLI with the component protection , replaced the cluster everything works except the radio, the problem is coding, i attach both bad instrument panel with no protection , and good cluster with component protection ....need to transfer the coding bad instrument to the new (used instrument)thank you.
 Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 55
          5F 62 72 75
VIN: 3VW5T7AJXGM401170   Mileage: 52660km-32721miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 AT    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 4876
   Revision: --H13---
   Coding: 00190012242400171000
   Shop #: WSC 00066 790 00014
   ASAM Dataset: EV_ECM20TFS02006K906071AT 001005
   ROD: EV_ECM20TFS02006K906071AT.rod
   VCID: 7DF11E1AEC0AE0A2B6-8028
19868 - No Communication with Instrument Cluster
          U0155 00 [038] - -
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 11.894 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 60.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 92 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    STATE_ERR_ABC_PRED: 7
22063 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [047] - -
                    Fault Frequency: 16
                    Mileage: 52667 km
                    Date: 2020.05.22
                    Time: 00:00:23
                    Engine speed: 1305.25 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 48 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 14.160 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 25.0 °C
                    Time since engine start: 10.7 s
                    T_ES: 0 min
Readiness: 0010 0101
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B600C492200FB850C06EB921900412118F02A
   Shop #: WSC 00066 123 12345
   VCID: 75E1063ADC3AB8E2FE-8020
                    Reset counter: 197
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
                    Count: 2
                    Count: 20480
                    Count: 8208
                    Count: 42240
                    Count: 8448
                    Count: 254
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0400168742
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 377DCC328EB60AF22C-8062
   Part No SW: 1K8 907 044 BS    HW: 1K8 907 044 BS
   Component: Climatronic   H07 0405
   Revision: 00001K04
   Coding: 0050019002
   Shop #: WSC 00066 790 00320
   VCID: 010962EA90F28442D2-8054
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0183
   Revision: BL122001
   Coding: EF200A1A902F06D40188008124000D4C0074000845A08DB2E4842000A040
   Shop #: WSC 00066 000 00000
   VCID: 7DF11E1AE40AE0A2B6-8028
   Component: RLS 130416 05  54  0403
   Coding: 02300A
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
                    Voltage: 11.75 V
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331610303361
   Coding: 0071155001
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 3663C13689BCF3FA37-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM05VJW0
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW32.rod
   VCID: 63C548626AAE3652A0-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH0000000000053HY7Q
   Coding: 30314C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 404 16
   Serial number: 35700000000F0C4C8A1Y
   Subsystem 3 - Part No SW: -----------    HW: 480 000 404 16
   Serial number: 35800000000554345A1A
   Subsystem 4 - Part No SW: -----------    HW: 480 022 303 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001AB2050EF4344$
   Subsystem 5 - Part No SW: -----------    HW: 480 022 303 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B12050EF6066Y
   Subsystem 6 - Part No SW: -----------    HW: 480 021 204 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001C91ECD9D1D36Y
   Subsystem 7 - Part No SW: -----------    HW: 480 021 204 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001C51ECD9D447E.
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
                    Mileage: 52667 km
                    Date: 2020.05.22
                    Time: 00:00:15
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
12674816 - Immobilizer Control Module
          U0167 00 [008] - No Communications
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20160419201595
   Coding: 0002440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F0DE412E606F2B2A4-802A
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160000564710056114
   Coding: B0FFFF
   Part No SW: 5C6 920 985 C    HW: 5C6 920 985 C
   Component: KOMBI         H04 1009
   Coding: 0100000100
   VCID: 326BFD2665D4EFDA1B-8066
9453073 - Fuel Level Sensor 1
          B103E 1A [009] - Resistance Too Low
                    Reset counter: 187
                    Mileage: 52667 km
                    Date: 2020.05.18
                    Time: 00:00:26
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 227
10485824 - Internal Control Module Memory Check Sum Error
          B2000 41 [137] - General checksum failure
13636608 - Internal Control Module Memory Check Sum Error
          B2000 05 [009] - System Programming Failure
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
                    Reset counter: 227
13635840 - Supply voltage
                    Reset counter: 226
                    Mileage: 52666 km
                    Date: 2020.05.18
                    Time: 22:31:45
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1673
   Revision:   H56       Serial number: 19051603010498
   Coding: 351032
   Shop #: WSC 00000 960 360006
   VCID: 76E30136C13CB3FAF7-8022
                    Reset counter: 237
                    Reset counter: 237
                    Mileage: 52918 km
                    Date: 2018.08.15
                    Time: 21:58:19
   Component: IMMO          H04 1009
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB25468D84671A63-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 52667 km
                    Date: 2020.05.18
                    Time: 00:02:58
10490880 - ROD - Unknown Error Code
          - 00 [008]
13762816 - Databus
          U1201 00 [008] - No Communications
                    Reset counter: 227
10493440 - Function Limitation due to Missing Enable from OCU/VTS
          B201E 00 [009] -  -
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000067381006
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3169F22A60D2D4C262-8064
12670208 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 67
   Serial number: 0398560436
   Coding: 02011102
   Shop #: WSC 01383 790 50316
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C77D31EB79029AAC1-8068
   Lane Change Assistant 2:
   Serial number: 0397669924
   Coding: 020111
337232 - Databus
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0631
   Revision: 13100010    Serial number: 0010473042
   Coding: 0404BD
   Shop #: WSC 00066 790 00083
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 1D313E9A0C4A40A2D6-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14202745160510162322
68102 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3979CA0A70A21C82DA-806C
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
                    Voltage: 11.88 V
                        DD
                    Temperature: 35.0°C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0089455
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 285F1F4E5308950AB5-807C
9463827 - Rear Right Treble Speaker
          B1068 13 [008] - Open Circuit
                    Reset counter: 237
                    Mileage: 52667 km
                    Date: 2020.05.22
                    Time: 01:42:09
9637138 - Loudspeaker 2 in Double-Subwoofer
          B130D 12 [009] - Short to Plus
                    Reset counter: 195
                    Mileage: 52907 km
                    Date: 2018.08.10
                    Time: 03:47:44
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1673
   Coding: 01030100
   VCID: 6FED3452BE66823234-803A
   Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST000WAC3L00000
   Coding: 180000
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0631
   Revision: 15100010    Serial number: 0010499644
   Coding: 0404BC
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 1E333996014C5BBACF-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744160509004957
          U1111 00 [008] - -
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
   Component: AFS-ECU       H05 0111
   Coding: 081200010B000200
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
13705477 - Databus
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 01:25:58
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0247
   Serial number: VWZAZ2S0178521
   Coding: 02630102AA00000051220003001808001F0100D400200105C6
   Shop #: WSC 29962 004 1048576
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 62CB4D6675B43F5AAB-8036
          U1101 00 [008] - Active
                    Reset counter: 237
                    Mileage: 52919 km
                    Date: 2018.08.15
                    Time: 00:00:09
                    Voltage terminal 30: 13.2 V
15360768 - Component Protection
                    Reset counter: 236
                    Mileage: 52907 km
                    Date: 2018.08.10
                    Time: 03:47:49
                    Voltage terminal 30: 11.9 V
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140549
   Coding: 02630102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 14275BBEFF8001EA69-8040
End-------------------------(Elapsed Time: 03:33)--------------------------
   Revision: --H13---
          U0423 00 [046] - -
                    Fault Frequency: 15
                    Mileage: 52667 km
                    Date: 2022.03.02
                    Time: 00:00:23
                    T_ES: 0 min
   Revision: 00H46001
   Coding: 030C0C
   Revision: 00001K04
   Coding: 0050019002
   Revision: BL122001
   Coding: 02300A
   Coding: 0071155001
   Coding: 30314C
                    Mileage: 52667 km
                    Date: 2022.03.02
                    Time: 00:00:15
   Coding: 0002440008
   Coding: B0FFFF
   Coding: 271E010000
   Shop #: WSC 00200 935 01530
          U1101 00 [009] - Active
                    Reset counter: 195
                    Mileage: 52907 km
                    Date: 2020.05.20
                    Time: 03:47:49
   Coding: 351032
                    Fault Status: 00110100
                    Reset counter: 237
                    Mileage: 52918 km
                    Date: 2020.05.25
                    Time: 21:58:19
   Coding: 000007
   Coding: 02011102
   Coding: 020111
   Coding: 0404BD
   Slave Driver:
   Revision: 00H22000
                    Reset counter: 237
                    Mileage: 52667 km
                    Date: 2022.03.02
                    Time: 01:42:09
                    Reset counter: 195
                    Mileage: 52907 km
                    Date: 2020.05.20
                    Time: 03:47:44
   Coding: 01030100
   Coding: 180000
   Coding: 0404BC
   Slave Passenger:
                    Reset counter: 197
                    Mileage: 52919 km
                    Date: 2020.05.25
                    Time: 00:00:09
                    Reset counter: 236
                    Mileage: 52907 km
                    Date: 2020.05.20
                    Time: 03:47:49
End-------------------------(Elapsed Time: 03:31)--------------------------
Component Protection is something that has to be dealt with on-line to VW's corporate servers. That means dealer, or independent shop that has jumped through all the hoops to have access to the servers.
Jef
HQ
http://wiki.ross-tech.com/wiki/index.php/U1101
This isn't a coding issue... hardware was swapped out (cluster) and by design, Component Protection has been triggered.
A trip to the dealer is required.
acr1975
C?ID=341829
i sent it to dealer, they couldn't figured out, first they said radio has been changed and then they estimate $1600 to fix, and then i told them what happened and they said no software can solve this, it should be electrical issue $750 to start, i know the problem , the configuration on the second instrument cluster is not matching the car, if you see it , the radio has different coding.
acr1975
C?ID=341829
also, when i install the original cluster the radio works ....
IMO: Your dealer is either incompetent or wants to take you for a ride.
Jef
HQ
To be fair to the dealer, they are forced to use ODIS for this. :banghead:
acr1975: Hi. I'm more familiar with CP on MQB platform cars, but the structure of the CP DTC s on your GLI is intriguing!
In principle, the CP facility happens after every ignition switch-on and the process starts by the CP "master" module initiating an interrogation of the identity of a number of key modules on the CAN network. The responses from each of these modules are then compared to the module identity that the CP "master" module recorded at the previously successful CP interrogation (which was originally sanctioned by VW's FAZIT servers).
If you have changed one or more of these key modules and after ignition switch-on, a CP error will be initiated in both the new module(s) AND in the CP master module - because the identity of the new nodule has not been recognized as being FAZIT endorsed for the VIN.
On MQB platform vehicles, the CP master is the CAN Gateway module @ address hex19. But in your auto-scan, CP errors appear in the hex17 module (understandable - because this is the new module) and in the hex5F module, or what you call the "radio". This suggests (to me at least) that on build platform vehicles for the GLI, the CP master module is the "radio" and this is why you are losing sound (I think)!
Of course, it's possible that the hex17 module is the CP master on the GLI - but since there is only one other module with CP errors, this can't be the case; if the CP master module was changed, CP errors would appear on every module in the CP constellation!
So, in respect of the observation in your quote above - yes, the CP error will be inactive if you replace the old dash, because the identity of the hex17 module will be the same as the identity recorded by the CP master at the previously successful CP interrogation process
As others have indicated, the key factor in clearing CP errors is a FAZIT connection back to what Uwe calls "the mothership". This is only possible (officially) through a registered VW agent - alas. I'm not sure if your set-up can be hacked as an alternative approach?
PS: A way of tricking CP (temporarily) is to hot-swap the new module while the ignition is turned-on. This obviates the initiation of the CP interrogation process which only happens with the generation of a T15 Voltage (i.e. @ ignition switch-on). Of course, this trick is only useful until the ignition is cycled again - when the CP process will be re-initialized
I'm not sure how practical this trick is with the dashboard module - perhaps not!!
PPS: the other interesting observation in your auto-scan (for me, at least) is the duplicate CPs error in the hex5F module. Clearly, the CP master has recognized 2 x separate instances of FAZIT violations - 5 x days apart. I've not seen this before, but I wonder whether replacing the old dash somehow closed-off the previous CP error and then re-installing the same new dash module generated a separate DTC - maybe? The alignment of the date/time stamps for the DTC on the hex17 module and the second DTC in the hex5F modules suggests that there might be such a cause-and-effect link
PPPS: why the speaker DTCs on the hex47 module? Did you pull the connectors trying to fix the sound problem?
rhinopower
C?ID=58979
I can solve this issue for you without a trip to the dealer, drop me a message
acr1975
C?ID=341829
hi, thanks for excellent information from DV52, I enjoyed....sorry for late reply, because i was tired of the car, and i took it to the second dealer, and they charged me $235 to tell me they can't do that , and they need to replace the new cluster...
acr1975
C?ID=341829
let me know how we can solve this .....thank you
