Hi, I have crashed car.
I replace left slave unit and now need recode it.
Right unit ( correct one ) have coding E01E00.
When trying recode left unit from E01800 to E01E00 I have error - rejected .... How to change coding on this unit??? ( number of importer etc is not 0000 )
Thanks guys for help!
Tuesday,09,June,2020,18:45:46:51262
VCDS Version: 20.4.1.0
Dealer/Shop Name: bekscrs
Workshop Code: 135 31518 016521
VIN: WAUZZZ4G1HN13xxxx License Plate: KKAUDI
Mileage: 45914km-28529mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 3B 42 44 46 52 53 55 5F 62
6C 72 8F AC
VIN: WAUZZZ4G1HN13xxxx Mileage: 45914km-28529miles
17-Instruments -- Status: Cannot be reached 0100
62-Door, Rear Left -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
Address 01: Engine (J623-DDDA) Labels: None
Part No SW: 04L 906 021 HC HW: 04L 907 309 AA
Component: R4 2.0l TDI H20 4164
Revision: 8DH20---
Coding: 0A254012232601080000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TDI01104L906021HC 004004
ROD: EV_ECM20TDI011_AU57.rod
VCID: 6DD5F96FBC59C0EED0-8038
Part No SW: 4G0 927 166 N HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H06 0004
Revision: --H06---
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 387B183B839BB546F3-806C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A69E41606579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 418D75DFD041F48E44-8014
217088 - System Function Test Activated
C101F 00 [047] - -
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:18
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 22
Bit Info 4: 1F
Uz: 8D
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0825
Coding: 01A8700E000000000000
VCID: 7CF3C42BFF23596657-8028
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 CB HW: 4G0 820 043 CB
Component: KLIMA 2 ZONEN H14 0113
Serial number: 27041700111467
Coding: 34010908210000
ASAM Dataset: EV_AirCondiBasisUDS 003009
ROD: EV_AirCondiBasisUDS_003.rod
VCID: 61CD955F7081948E64-8034
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:18
Compressor current: actual value: 0 mA
Outside air temperature: 16.5 °C
Temperature after evaporator: 20.43 °C
Engine speed: 0 /min
0318 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:18
Voltage terminal 30: 11.22 V
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001658636901
Coding: 0105001440349FE0C101408720001800CF9CC3082E08020100000494E101150200400034030000
Shop #: WSC 12345 123 12345
VCID: 74E3EC0BD77311261F-8020
Component: WWS57X 170218 H38 0080
Serial number: 170222171857
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20212664X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 03 05 2017 00001282
Subsystem 4 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H01 0006
Serial number: DA2806A880PAG0FSA002
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:20
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100DLDLB
Coding: 30333130313630323637554A304C34473053
VCID: 3B710737B2AD9E5E1E-806E
Serial number: 3575HRB401I596KS4P1O
Serial number: 3585HRB405V1G0QM8HTK
Serial number: 3515JRB400Q59OGAQ9F0
Serial number: 3525JRB400E59H1U9HMS
Serial number: 3554VRB40671EVLGB1O7
Serial number: 3564VRB400M59ISIL8V-
7 Faults Found:
9444885 - Driver's seat position sensor
B101E 15 [137] - Open or Short to Plus
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:21
9445141 - Passenger's seat position sensor
B101F 15 [137] - Open or Short to Plus
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:21
9447189 - Seat Occupied Sensor; Passenger's Side
B1027 15 [137] - Open or Short to Plus
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:21
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:23
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:23
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:23
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:23
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560QGQ000GH
Coding: 000035
VCID: 3B710737BAAD9E5E1E-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 02 03 2017 B0004652
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
Fault Status: 01101100
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
Part No SW: 4G8 920 934 R HW: 4G8 920 934 R
Component: TDieRdw H17 0225
Revision: 17001311 Serial number: 658070517596041
Coding: 13AF0D000B410008080B00
Shop #: WSC 09038 123 61029
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 408B70DBDB4BFD864B-8014
Part No SW: 4G8 907 468 K HW: 4G8 907 468
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002600874
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 002011
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 9202473804
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 170222000000000004C4
5074 - Door Control Module - Rear Left
U0201 00 [009] - No Communications
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:18
Voltage terminal 30: 11.1 V
Voltage terminal 15: 11.1 V
Control Module temperature: 22 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
U140B 00 [009] - -
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:41:03
Voltage terminal 30: 11.2 V
Voltage terminal 15: 0.0 V
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 1
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04018264747464545425363E00
VCID: 67D98B4796A5EABEAA-8032
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720WKUVU
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33612F179AFD561EC6-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F16015C00628002080002
VCID: 47996BC7F665CABE8A-8012
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000002 Serial number: 0000827893
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7F0233BD97A75605-806E
Revision: 00002001 Serial number: 0440911038
Coding: 011A062080B90080C320088408010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00033277796
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
00216 - Signal EC-mirror Fade Out
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:22
Component: TSG BF H03 0511
Coding: 011F16015E00628002080002
VCID: 468766C3F16FD3B671-8012
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:17
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002187371
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 326F2A1365E75F16CD-8066
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FA02102A600200
Shop #: WSC 31518 135 16521
VCID: 34632C0B9FF35126DF-8060
Coding: E01800
Coding: E01E00
U1014 00 [137] - -
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:20
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:20
5545201 - Output Stage for LED Headlamp; Left
B149C F1 [137] - Incorrectly Coded
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:20
5538066 - Temperature Sensor for Left High Beam
C116F 01 [009] - Electrical Failure
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:21
5538067 - Bulb for High Beam Headlamp; Left
B1219 F0 [137] - Current Coding Electrical Error
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:21
Part No SW: 4G1 035 044 G HW: 4G1 035 044 D
Component: MU-H-LN-EU 053 0910
Serial number: A734E0H7543435
Coding: 01750101FF0A000013110001000A00332F0006A5F1708100DF
VCID: 2341DF572A1DC69E36-8076
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807TCX
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349QDS000N0
Component: Gracenote2 --- 1015
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:43
Voltage terminal 30: 11.4 V
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:40
Address 62: Door, Rear Left
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78FBD83BC31B754633-802C
Component: TSG HR H03 0511
Coding: 010F14004000628002080002
VCID: 499D6DFFE0713CCE9C-801C
Component: RGS-VL H16 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 316D251F60E1640EB4-8064
12583695 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 62
Mileage: 45914 km
Date: 2020.06.09
Time: 17:40:18
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 170960053
ROD: EV_RDCMA00100.rod
VCID: 2F69236776D572FEA2-807A
End-------------------------(Elapsed Time: 04:48)--------------------------
