Requesting suggested coding for a MK6 Jetta ABS module
NitrousOxide
Jamaica
C?ID=269481
Greetings,
A MK6 Jetta had a ECU failure that couldn't be repaired via traditional means. A donor ECU, instrument cluster and transponder were swapped from a scrapped car. I'm aware that the VIN is now different. The issue is that the coding in the ABS module has been zero'd out as expected. I used an ABS coding calculator that I had found online, but the suggested coding was rejected. Can someone please provide some suggested coding for this ABS module?
poet sumitra nandan pant
Sunday,07,June,2020,20:22:26:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ16ZCM012016   License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ16ZCM012016   Mileage: 54540km-33889miles
Address 01: Engine (J623-CAVD)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 BC    HW: 03C 907 309 J
   Component: 1.4l R4/4V TS H04 1683
   Revision: LGH04---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 06370 637 89632
   ASAM Dataset: EV_ECM14TSI01103C906027BC 001003
   ROD: EV_ECM14TSI01103C906027BD.rod
   VCID: 63EB56006AC9909E76-8036
4523 - Control Module 1 for Coolant Fan
          P1946 00 [047] - Defective
                    Fault Frequency: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 03:24:02
                    Engine speed: 0.00 /min
                    Coolant temperature: 33 ∞C
                    Intake air temperature: 33 ∞C
                    Voltage terminal 30: 11.379 V
                    Coolant temperature at engine start: 47.3 ∞C
                    Coolant temperature at radiator output: specified value: 90.0 ∞C
                    Coolant fan 1: activation: 10.00 %
                    Temperature before 2nd compressor: raw value: 33.8 ∞C
                    Time since ignition off: 311 s
                    Coolant recirculation pump-Bits 0-7: 00000000
                    Fuel temperature: 42.0 ∞C
4713 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:13
                    Engine speed: 764.50 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 111 ∞C
                    Intake air temperature: 51 ∞C
                    Voltage terminal 30: 13.193 V
                    CAN status - engine control module-Bits 0-7: 00000000
                    CAN TimeOut meter - transmission-Bits 0-7: 00000000
                    Generator power: 0 W
                    CAN TimeOut meter - gateway-Bits 0-7: 00000000
4649 - Brake Booster Pressure Sensor
          P0555 00 [175] - Electrical Malfunction
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:27:55
                    Coolant temperature: 47 ∞C
                    Voltage terminal 30: 11.449 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 82.66 %
                    Torque request: sum of auxiliary aggregate: 7.0 Nm
                    Engine torque: 0.0 Nm
Readiness: 1110 0101
   Part No SW: 0AM 300 042 Q    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6566
   Revision: 00043014    Serial number: CU501601226359
   Shop #: WSC 65300 002 1048576
   VCID: 3851D16C4BCFA346F3-806C
006225 - Powertrain Data Bus
               P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Reset counter: 10
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:14
   Revision: 00H31001
   Shop #: WSC 00066 790 00187
   VCID: 7DDF0078E46D466E60-8028
03306 - Coding Not Valid
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 04:07:10
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 4161
                    Count: 39936
                    Count: 256
                    Reset counter: 223
                    Date: 2020.06.06
                    Time: 00:27:57
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 40960
                    Count: 256
00150 - Plausibility Brake Booster System
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:27:57
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 398
                    Count: 40960
                    Count: 256
                    Fault Status: 01100101
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:27:56
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 279
                    Count: 40960
                    Count: 256
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:27:56
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 295
                    Count: 40960
                    Count: 256
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:27:56
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 270
                    Count: 40960
                    Count: 256
   Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004002
   Shop #: WSC 00066 000 00118
   VCID: 7AD50B64FD43715645-802E
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 224
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:28:04
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:14
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 08000A3A802DE1C0408800801000816403000088508089605C8000000040
   VCID: 3E5DC774A9EB9D7639-806A
   Subsystem 1 - Part No: 1K8 951 171
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 02:25:11
                        Term 15 Off
                    Voltage: 12.00 V
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:16
                    Voltage: 13.20 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:28:01
                    Voltage: 11.50 V
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:28:01
                    Voltage: 11.50 V
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6M05R4FC
   Coding: 00003241
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3245E34465B34916CD-8066
   Serial number: 3572MSME7426406EZZZ-
   Serial number: 3582MSME0040106EZZZJ
   Serial number: 3516KSME5403631DZZZO
   Serial number: 3526KSME0314631DZZZL
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:14
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90422LGO000JJ
   Coding: 088A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 42A5B384D513F9965D-8016
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0437055
   Coding: 820000
267264 - Control Module Incorrectly Coded
          U1014 00 [008] - -
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 02:30:22
   Part No SW: 5C6 920 871     HW: 5C6 920 871
   Component: KOMBI         H04 0617
   Coding: 171A00
   Shop #: WSC 00066 000 00119
   VCID: 69F7442888E5CACEBC-803C
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 9
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:14
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 06091203270833
   Coding: 351003
   Shop #: WSC 00066 000 00000
   VCID: 3FA3BA70AEE1947E32-806A
                    Fault Status: 00110100
                    Reset counter: 8
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:14
   Component: IMMO          H04 0617
   VCID: 6AF53B248DE3C1D6B5-803E
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662618695
   Coding: 010100
   VCID: 2A75FB24456301D675-807E
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0005386449
   Coding: 0002B5
   Shop #: WSC 01383 790 50316
   VCID: 5B9B6EE052B9A85E3E-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1508
   Serial number: 00000007065843
   Coding: 000290
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753D25046D1AC3EFA-8062
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:13
                    Voltage: 13.25 V
                        DU
                    Temperature: 42.0∞C
                    RPM: 771 /min
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 02:29:29
                    Battery Volts: 12.0 V
                        PD
                    Temperature: 32.0∞C
                    Count: 2
                    Steering Angle: 0.00∞
                        SteerAng n.Init
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0005399177
   Coding: 0002B4
   VCID: 5C996DFC57B7AF6637-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000007073935
   Coding: 000290
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0234
   Revision: 00000001    Serial number: VWZ1Z3M7262834
   Coding: 01000410040006
   VCID: 2469151C2747D7A64F-8070
00625 - Vehicle Speed Signal
                    Reset counter: 9
                    Mileage: 54547 km
                    Date: 2020.06.07
                    Time: 05:23:19
00468 - CD-ROM Drive (R92)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 223
                    Mileage: 54547 km
                    Date: 2020.06.06
                    Time: 00:28:05
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663071470
   Coding: 0A00000000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A55CB64BDC3B15605-806E
End-------------------------(Elapsed Time: 02:22)--------------------------
Does the VIN in all the modules match?
Check (and post) Advanced ID from:
01-Engine
17-Instruments
25-Immobilizer
NitrousOxide
Jamaica
C?ID=269481
I can't believe I forgot to check that. I assumed since they all came from the same donor vehicle, they would match except for the ABS unit which remains installed in the vehicle in question. I'll check, confirm and post the Advanced ID from the 3 modules in the morning.
Control Module Part Number: 1K0 907 379 BL
  Component and/or Version: ESP MK60EC1   H31 0152
           Software Coding: 00000000000000000000000000000000000000
            Work Shop Code: WSC 00066
Advanced Identification
     Identification: 3QT-03A
     Revision: 00H31001
     Date: 09.08.12
     Manufacturer number: 0101
     Test stand number: 00F0
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Status: 00000000
     Flash Date: 2000.00.00
     Flash Tool Code: 00000 000 00000
Misc.
     Hardware number: 1K0 907 379 BL
     Workshop System Name: J104
VCDS Info:
       Labels: 1K0-907-379-60EC1F.clb
     Revision: 00H31001
     Date: 09.08.12
Flash Status
Misc.
VCDS Info:
NitrousOxide
Jamaica
C?ID=269481
01-Engine
17-Instruments
25-Immobilizer
Yes, I've confirmed that the VIN matches in the 3 modules you have listed
Tuesday,09,June,2020,19:32:37:39976VCDS Version: Release 20.4.0 (x64)
                Address 01: Engine
Control Module Part Number: 03C 906 027 BC
  Component and/or Version: 1.4l R4/4V TS H04 1683
           Software Coding: 00250012002400000000
            Work Shop Code: WSC 06370
                      VCID: 63EB56006AC9909E7F-8036
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: LGH04---
     Date: 04.04.11
     Manufacturer number: 1360
     Test stand number: 0408
Flash Status
     Programming Attempts(application): 1/1/1/1/1
     Successful Attempts(application): 1/1/1/1/1
     Flash Date: 12.09.03
Misc.
     Hardware number: 03C 907 309 J
     Workshop System Name: J623
     ASAM Dataset Revision: 001003
Car Info
     Chassis Number: WVWZZZ16ZCM012016
     Engine code: CAVD
VCDS Info:
       Labels: 03C-907-309-V1.clb
       Readiness: No script available
Tuesday,09,June,2020,19:34:15:39976VCDS Version: Release 20.4.0 (x64)
Control Module Part Number: 5C6 920 871
  Component and/or Version: KOMBI         H04 0617
           Software Coding: 171A00
                      VCID: 69F7442888E5CACEB5-803C
     Identification: ZYS-000
     Date: 15.07.11
     Manufacturer number: 4131
     Test stand number: 0574
Flash Status
     Programming Attempts(application): 1/1/1/0/0/0/0/0/0/0
     Successful Attempts(application): 1/1/1/0/0/0/0/0/0/0
     Flash Date: 11.07.19
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5C6 920 871
     Workshop System Name: J285
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A04114
Car Info
VCDS Info:
       Labels: 5K0-920-xxx-17.clb-SRI1
Tuesday,09,June,2020,19:35:05:39976VCDS Version: Release 20.4.0 (x64)
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H04 0617
            Work Shop Code: WSC 00000
                      VCID: 6AF53B248DE3C1D6BC-803E
     Date: 15.07.11
Flash Status
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     ASAM Dataset Revision: A03009
Car Info
Immobilizer
     Transponder ID (Current val.): 0ECCC047
     Transponder ID 1: 0ECCC047
     Transponder ID 2: 0ECD59F7
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
Good. Hopefully someone will be able to build a coding for you.
Gone But Not Forgotten
ModelJetta
JE
Date of production22.07.2011
Model year2012
Sales type1623Q5
Engine CodeCAVD
Transmission CodeNAU
Part No SW: 03C 906 027 BC HW: 03C 907 309 J <<<<<<<<<<<<<<<<<<< FOD PASS!
Part No SW: 0AM 300 042 Q HW: 0AM 927 769 D <<<<<<<<<<<<<<<< FOD FAIL!
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL <<<<<<<<<<<<<<<<<<< FOD FAIL!
Revision: 00H31001
Please post the cars old cluster and ABS module data before it lost coding as a result with prior VIN number?
Pictures of data plate too please.....
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation powertrains/platform parts7KKVehicle class differentiation -160-
Hill start assistUG1Hill start assist
Emission standard0GVEmission standard EU2 (critical vapor pressure)
Trailer hitch1D0Without trailer hitch
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Activated carbon canister/gasoline particulate filter1E1Activated carbon canister
Overhead storage compartment7N2Sunglass holder
Aerials8L6"diversity" window antenna
Exterior mirror adjustment6XNExterior mirrors, power-adjustable/ separately heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Alternative drive system0K0Without alternative drive system
Drive type1X0Front-wheel drive
Multimedia/video/DVD/notebook connection9WLJack for external audio source
Equipment linesA8CComfort equipment
Rear brakes1KSDisc brakes in rear (Geomet D)
batteriesJ1LBattery 280 A (60 Ah)
Front brakes1ZADisc brakes in front
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Beverage holders4M2Beverage holder in center console in front and in storage compartment in rear
Battery/alternator capacitiesNY0Standard battery/alternator capacity
Component sets for country-specific prescriptive standardsB0Abuild parts set without county specific documentatio
floor covering3MHDilours floor covering without scuff guard
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ASElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD-ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ1Chrome package
General operating license additionsC04Operating permit, alteration
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Shock absorption in rear1JARear shock absorption, basic version 1
Shock absorption in frontG57Shock absorption in front
Tank filler neck for unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for vehicle parts0EGInstallation differentiation for twin-clutch gearbox DQ 200 Vehicle components
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5MBDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X2Park distance control in front and rear
Electric interface for external useUF8Electric interface for external use
Differentiation for manufacturing process0FLMexico manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
Fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K1Separate daytime running light
Fresh air intake for vehicle interior (with particle filter)2V5Fresh air intake system with combination filter
Antifreeze agent1C2Antifreeze up to -35 degree Celsius tolerance up to -40 degree C
Vehicle tracking system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Sound insulation measures for interior noises3W0Without additional noise suppression measures for passenger compartment
Alternators8GUAlternator 140 A
Weight category for rear axle0YEWeight range 5 installation control only, no requirement forecast
Weight category for front axleL07Suspension range 07 installation control only, no requirement forecast
Base engineTF04-cylinder SI engine 1.4 l unit 03C.H (aluminum)
Luggage net/bag on backrest(s)4U5Luggage pockets on backrest
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Sound insulation measures for outside noises2B0without additional exterior noise insulation
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationG1C7-speed automatic transmission
glove box4Z3Lockable glove compartment door, with light
Brackets3P1Bracket for first aid kit and warning triangle
Hand brake lever6PCHand brake lever handle in leather
Rear spoiler5J0Without rear spoiler
Rear axle0N44-link rear suspension
Rear seats3KBUnsplit rear seat bench, split folding backrest, with center armrest
Heating system/air conditioning system9AKClimatronic with impact pressure control, CFC-free
Main headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without customized installation
Dashboard insertsU5AInstrument cluster, km/h speedometer
Instrument panel4N3Comfort dashboard
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Body formsK8BNotchback
Luggage compartment floor covering6SFStandard luggage compartment floor covering
Cool box1W2Glove compartment cooling system
Characteristic map cooling systemQS0Without electronic map cooling system
Climate zones0Y2Tropical zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Head restraints in rear3T2Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank material treatment2LDFuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Fuel filling volume1Z2Increase in initial standard fuel filling
Fuel systems1A5Fuel system for fuel-injected SI engine
Body measures5C0Without special body measures
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Radiator grille6KERadiator grille
License plate lightingKL0Standard license plate lighting
License plate carrier in rear6P1Rear license plate carrier (ECE)
License plate carrier in front6W1Front license plate carrier (large)
Paint preservation/transport protection5K5Transport protection film with additional transport protection measures
Steering system setupL0RRight-hand drive
Reading lamp8S1Reading light in front
Steering system1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Light assist systems8G0Without Light Assist
Lumbar support in backrests7P4Manually adjustable lumbar support in front seats
steering wheels2PPLeather-wrapped multi-function steering wheel
Loudspeaker installation8RM8 speakers (passive)
Steering column systems2C5Axial and vertical adjustable steering column
Headlight range control8Q1Headlight range control
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z4moderately hot country
Engine specificationD4L4-cylinder SI engine 1.4 l/118 kW 16V TSI TC base engine is TF0/TU1
Market-specific vehicle typeAW1Version (high)
Vanity mirror on the left4SDVanity mirror, left, illuminated
Vanity mirror on the right4TDVanity mirror, right, illuminated
Navigation system7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamps/additional headlamps8WDIntegrated front fog lamps
Rear floor panel platform module4P1Rear floor panel module, type 2
Platform group class7PAPlatform group class 1
Panic switchKP2With additional switch
Wheel trims1NLTrims for alloy wheels
WheelsCC3Alloy wheels 7J x 17
Radios8DDRadio "RCD510 World Variant"
Smoker's/non-smoker's version9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K0Without tyre pressure monitor
tireH6LTires 225/45 R17 91W
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems in front3QT3-point seat belts in front, with pretensioner and height adjustment
PH2Climatronic air conditioning system withautomatic air recirculation mode activation via air quality sensor
PJ6"Queensland" - 4 alloy wheels 7J x 17 - tires 225/45 R17
PS5Electric tilt/slide glass sunroof
PU2Multi-function leather steering wheel
RK5
WD2Anti-theft alarm system "Plus" incl. single door opening
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/gearshift handle6Q2Gearshift knob/handle in leather
Special labels0SSLabels in English and French
Tail lamp assemblies8SARear combination lamp, standard design
Closing/opening mechanism tailgate/trunk lid/rear gate4E2Tailgate/trunk lid release from inside (electrically)
Seat in front, left3TFComfort seat in front, left
Seat in front, right3SFComfort seat, front right
Nameplate for sales nameQD3Nameplate for sales name
Seat belt reminder9P3Seat belt reminder, electric contact in buckle
Outer seat belts in rear3ZU3-point seat belts, outer rear with ECE label
Center seat belts in rear3C73-point seat belt for center rear seat
seat coversN3LSeat trim covers in circular-knit velour
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Side lamps7R3Side turn signals (white)
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
Outlet7B512-volt outlet(s)
Bumper2JGbumper in color of vehicle
Rear stabilizer bar0BGRear stabilizer bar
Front stabilizer bar0AGFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Intermittent windshield wiper control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Nameplate set0NWNameplate set "TSI"
Door storage compartments in front3YRDoor pockets with insert mats
Counterweights for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and tailgate/trunk lid locking mechanism4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type-approval testing countries/ countries with specific requirementsB63Special requirements for the Caribbean (Jamaica, Haiti, Cuba, Trinidad and Tobago, Dominican Republic)
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Front-end underbody cladding1SAWithout additional front underbody guard
Identification labels1EJSpecial identification plate
First aid kit/warning triangle1T2warning triangle
Telephone/telematics9W7Mobile phone interface (NAR)
Additional warning lamps9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG2LongLife Service Regime cannot be activated
Thermal energy storage system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZAStandard decorative trims
Additional child seat anchorage3B4Child seat anchors for child seat system ISOFIX
Ignition locking system/electronic steering column lock0RBIgnition/starter switch locking system
Auxiliary heater9M0Without auxiliary heater/parking heater
VINCheck® Results
VINCheck® Theft Record
VIN: WVWZZZ16ZCM012016 has not been identified as a vehicle listed in the VINCheck® Theft Records.
VINCheck® is updated regularly as additional information is reported.
VINCheck® Total Loss Record
VIN: WVWZZZ16ZCM012016 has not been identified as a vehicle listed in the VINCheck® Salvage Records.
