I tried activating coming and leaving home but it didnt work
this is second time happens with a skoda
could you please advice me about the issue
and the low beam is on once the ignition on
auto-scan
thanks
auto-scan
Monday,08,June,2020,14:57:36:04619
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBAG7NE3E0053702 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBAG7NE3E0053702 Mileage: 348973km-216841miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1.6l TDI H22 9213
Revision: 84H22---
Coding: 01250012030401090000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM16TDI01104L906021N 002014
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 303916FB1AA2733BE32-8064
Readiness: 0 0 0 0 X
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 044 S HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4530
Revision: 00043014 Serial number: CU501510265493
Shop #: WSC 04940 001 00001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 48C95E1B8232DBFBDB2-801C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 622830000004D6
Coding: 1A0762912425096F007E060041C5245846249000608224F0004100004002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4BC36117934430E3F60-801E
12 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[undervoltage]
Reset counter: 104
Mileage: 345846 km
Date: 2020.05.16
Time: 02:09:00
0294 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Fault Frequency: 13
Reset counter: 117
Mileage: 332518 km
Date: 2020.02.09
Time: 03:25:37
0297 - Steering angle sensor
Reset counter: 194
Mileage: 236622 km
Date: 2018.09.30
Time: 02:14:03
8222 - Databus
[FCAN : Getriebe_11 message is not received]
Fault Frequency: 96
Reset counter: 119
Mileage: 300416 km
Date: 2019.09.07
Time: 21:37:27
8226 - Databus
[FCAN : Getriebe_14 message is not received]
Fault Frequency: 137
Reset counter: 119
Mileage: 300416 km
Date: 2019.09.07
Time: 21:37:27
8250 - Databus
[FCAN: Motor_07 message is not received]
Fault Frequency: 193
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:47:54
8252 - Databus
[FCAN: Motor_11 message is not received]
Fault Frequency: 205
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:44:41
8254 - Databus
[FCAN: Motor_12 message is not received]
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:44:41
8256 - Databus
[FCAN: Motor_14 message is not received]
Fault Frequency: 238
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:47:51
8258 - Databus
[FCAN: Motor_20 message is not received]
Fault Frequency: 165
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:44:41
8291 - Databus
[FCAN: MO_QBit_Motormomente signal is invalid]
Fault Frequency: 113
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:44:41
8351 - Databus
[FCAN: Motor_17_alt veraltet bit is set]
Reset counter: 119
Mileage: 261945 km
Date: 2019.03.04
Time: 15:47:50
Part No SW: 5E0 907 044 HW: 5E0 907 044
Component: Climatronic H02 0604
Revision: 00001K06
Coding: 01010104002100011005000000100000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 629DACB304CE91AB256-8036
328196 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Reset counter: 105
Mileage: 347064 km
Date: 2020.05.27
Time: 22:06:26
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Reset counter: 119
Mileage: 342214 km
Date: 2020.04.22
Time: 20:28:28
262657 - High Pressure Sensor
B10AE 29 [008] - Signal Implausible
Reset counter: 90
Mileage: 345846 km
Date: 2020.05.16
Time: 03:36:31
393478 - Air Blower
B10BE 16 [008] - Voltage Too Low
[ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Unterspannung Abschaltung]
Reset counter: 104
Mileage: 347525 km
Date: 2018.07.01
Time: 00:00:37
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Fault Frequency: 8
Reset counter: 112
Mileage: 346498 km
Date: 2020.05.20
Time: 20:33:08
B10CD 00 [008] - -
Fault Frequency: 17
Reset counter: 104
Mileage: 345846 km
Date: 2020.05.15
Time: 22:20:42
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011322900031
Coding: 0C001842420700FF07A04082B10007080000000000000000000000000000
Shop #: WSC 73430 790 00134
ROD: EV_BCMBOSCH_011.rod
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 130804 041 0570
Serial number: 130814190952
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY131560K2T
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000057442791
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20463201
7 Faults Found:
0531 - Footwell Illumination
B11FF 01 [009] - Electrical Failure
Reset counter: 79
Mileage: 348973 km
Date: 2020.06.08
Time: 19:50:50
11786 - Bulb for Rear Left Fog Light
B12C7 15 [009] - Open or Short to Plus
Reset counter: 79
Mileage: 348973 km
Date: 2020.06.08
Time: 19:50:50
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Reset counter: 79
Mileage: 348973 km
Date: 2020.06.08
Time: 19:50:50
14858 - Bulb for Right Brake Lamp / Tail Lamp
B133C 15 [009] - Open or Short to Plus
Reset counter: 79
Mileage: 348973 km
Date: 2020.06.08
Time: 19:50:50
197384 - Lock Module for Central Locking; Rear Right
B12DC 29 [009] - Signal Implausible
Reset counter: 79
197388 - Lock Module for Central Locking; Rear Right
B12DC 01 [009] - Electrical Failure
Reset counter: 79
Mileage: 348973 km
Date: 2020.06.08
Time: 19:52:05
929796 - Light Switch
U110B 00 [009] - No Communcations
[Lichtschalter-E1->Kein Signal/Kommunikation]
Reset counter: 79
Mileage: 348973 km
Date: 2020.06.08
Time: 19:50:50
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PGSQRSA
Coding: 98CCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5B05C7977C5C432A8-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 808 13
Serial number: 3576U000000B77146D0E
Subsystem 2 - Part No SW: ----------- HW: 454 001 308 13
Serial number: 3586U0000004390D6D0E
Subsystem 3 - Part No SW: ----------- HW: 454 800 908 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RB764C201000000%
Subsystem 4 - Part No SW: ----------- HW: 454 800 908 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R5DF2BD01000000H
Subsystem 5 - Part No SW: ----------- HW: 454 801 307 13
Component: FrontSensor_D 114 0149
Serial number: 3556V34389701000000%
U1101 00 [008] - Active
[ATP Error Counter]
Reset counter: 104
Date: 2080.00.00
Part No SW: 5Q0 953 507 B HW: 5Q0 953 549 A
Revision: -------- Serial number: 23071304220581
Coding: 0200
VCID: 353727EFE5C05613B04-8060
Part No SW: 5E0 920 851 E HW: 5E0 920 851 E
Component: KOMBI 103 3390
Coding: 072502082000000801080800040000
Shop #: WSC 73430 031 00134
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 2809FE9B22723BFB3B2-807C
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
Reset counter: 90
Mileage: 345846 km
Date: 2020.05.16
Time: 02:09:05
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
9634288 - Transmission Control Module
B1301 F0 [008] - Not Authorized
9456433 - Key
B104B 31 [008] - No Signal
Reset counter: 90
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 228865 km
Date: 2018.08.26
Time: 00:47:53
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 D
Component: GW MQB Low 123 1144
Revision: -------- Serial number: 0000872891
Coding: 030000040B087300EF0002481C0F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 392F2BDFC9D8B27354C-806C
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 9924690903
9 Faults Found:
131603 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
[Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
Reset counter: 90
Mileage: 345846 km
Date: 2020.05.16
Time: 03:36:32
Supply voltage: Terminal 30: 6.0 V
Terminal 15: OFF
131658 - Door Control Module - Driver's Door
U0199 00 [008] - No Communications
[Timeout Knoten 0x4A / 42 - Türsteuergerät Fahrerseite]
Reset counter: 90
Mileage: 345846 km
Date: 2020.05.16
Time: 03:36:32
Terminal 15: OFF
131659 - Door Control Module - Passenger's Door
U0200 00 [008] - No Communications
[Timeout Knoten 0x4B / 52 - Türsteuergerät Beifahrerseite]
Reset counter: 90
Mileage: 345846 km
Date: 2020.05.16
Time: 03:36:32
Terminal 15: OFF
131699 - Control unit for information electronics 1
U1054 00 [009] - No Communication
[Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
Reset counter: 70
Mileage: 266654 km
Date: 2019.04.27
Time: 00:00:53
Supply voltage: Terminal 30: 12.5 V
Terminal 15: On
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [009] - Performance
[Globaler Timeout CAN-Infotainment]
Reset counter: 67
Mileage: 266219 km
Date: 2019.03.23
Time: 06:11:08
Supply voltage: Terminal 30: 12.6 V
Terminal 15: On
66564 - Infotainment CAN Bus (SAE Bus E)
U0064 00 [008] - Malfunction
[Bus defekt CAN-Infotainment]
Reset counter: 117
Supply voltage: Terminal 30: 11.2 V
Terminal 15: OFF
1282 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 90
Mileage: 345846 km
Date: 2020.05.16
Time: 02:09:01
Supply voltage: Terminal 30: 8.5 V
Terminal 15: On
8521278 - Battery terminal recognition
U1411 00 [008] - Open circuit
[Spannung Fahrbatterie mechanischer Fehler]
Reset counter: 104
Mileage: 347526 km
Date: 2020.06.01
Time: 19:33:08
Supply voltage: Terminal 30: 14.1 V
Terminal 15: On
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Reset counter: 117
Mileage: 265730 km
Date: 2019.03.18
Time: 09:58:23
Terminal 15: OFF
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000072068217
Coding: 001000208000020100001100
VCID: 55F7876F45807613504-8000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D273FCFDDF08E53784-8068
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000072287715
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Fault Frequency: 40
Reset counter: 79
Mileage: 339466 km
Date: 2020.03.15
Time: 20:02:28
End----------(Elapsed Time: 01:04, VBatt start/end: 12.2V/12.3V)-----------
