I have followed the common procedures that tells me when fitting LED lights to the footwell, in the central electronics coding there are 2 options at location 0x?xxxx with 0 being halogen globes and 1 being LED globes. Mine is already coded 2 which I don't know what that tells me, and when I change it to 1 I get a R/H and L/H high beam fault - although both physically work.
With LED globes in the footwell, I get the self diagnosing blink at night which is annoying.
Can anyone tell me on this spec car what the options mean or what option I need to select for LED globes to fix this?
Monday,08,June,2020,17:43:01:15263
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ4L8ED035825 License Plate:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 42 46 47 4F 52 55 56
5F 62 69 6C 6D 6F 72
VIN: WAUZZZ4L8ED035825 Mileage: 109980km-68338miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 B HW: 4L0 907 401 C
Component: 3.0TDI EDC17 X41 0003
Revision: 53X41--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 23451C742AEE679E36-8076
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AL HW: 0C8 927 750 AL
Component: AL1000 AISIN 002 2447
Coding: 001578
Shop #: WSC 07763 002 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 76E31520C9FCA23621-8022
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2196577
Shop #: WSC 60575 001 1048576
VCID: 3467EF285700F026DF-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702127564
Coding: 0000151
VCID: 2541026CECDA99AE58-8070
Subsystem 1 - Part No: 4F0 910 132 C
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AN
Revision: 00---031 Serial number: 00000000423985
Coding: 01029456
VCID: 2541026C2CDA99AE58-8070
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Coding: 0023121
VCID: 6FED20447EA693FEE2-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961409700521
Coding: 29031F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3467EF289F00F026DF-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 70 AIRBAG AUDI8RH45 0230
Revision: 06H45000 Serial number: 00399D6066R-
Coding: 0014128
VCID: 2E53FD40B92CDAF6A9-807A
Subsystem 1 - Serial number: 6332QSME743D4F46V
Subsystem 2 - Serial number: 6342QSME773D0C4CY
Subsystem 3 - Serial number: 6352QSME743D4E44U
Subsystem 4 - Serial number: 6362QSME4D404946M
Subsystem 5 - Serial number: 63734SME093D3F4AF
Subsystem 6 - Serial number: 63834SME093D325E8
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026140790135
Coding: 0102142
VCID: 285F0B589BC884C663-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 933 H HW: 4L0 920 933 H
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2M50GA4F
Coding: B356630400000008010704
VCID: 326BE9306D14FE16CD-8066
Address 18: Aux. Heat Labels: 4L0-910-105.lbl
Part No SW: 4L0 910 105 HW: 4L0 815 071 H
Component: Heizgeraet H10 0140
Revision: 0000000A Serial number: 00000009024928
Coding: 0000101
VCID: 60CF5378B3783C866B-8034
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0058
Revision: LB700037 Serial number: 3700L144050AB8
Coding: 00CF07
VCID: 3E73CD00A94C2A7639-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 31078N18284121930888
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 14099000795021200181
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AD
Revision: 00---011 Serial number: 00000030331375
Coding: 0000006
VCID: 68DF4B585B4844C6A3-803C
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000098720514
Coding: 011C52204041440004
VCID: 489FABD8FB8864C683-801C
Fault Status: 01101000
Reset counter: 144
Mileage: 109982 km
Date: 2020.06.08
Time: 17:29:33
01705 - Selection Switch for Mirror-Adjust (E48)
Reset counter: 144
Mileage: 109982 km
Date: 2020.06.08
Time: 17:29:44
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01945611960000
Coding: 3277197
VCID: 387FDB184B681446F3-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000038977
Coding: 030000
VCID: 29590E5C40C2BDCE7C-807C
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000741415
Coding: 0011001
VCID: 5EB36D80890C0A7659-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000098728995
VCID: 479DA8E4F6966BBE8A-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 140414-0002-061
Coding: 1147A71010000500
ROD: EV_HeadlRegulBasic.rod
VCID: 428BB9F0D5B44E965D-8016
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227D60E7991279
Coding: 040003010000000000
VCID: 2643056051DC92B651-8072
Part No SW: 4L2 035 764 G HW: 4L2 035 764 G
Component: H-BNT-RW H48 0793
Revision: -------- Serial number: 222DS0E7516117
Coding: 180A0106000483EF010023456F6320035C0000000000000000
Subsystem 1 - Part No: 8R0 060 884 BN
Component: ROW 2014 0605
Component: DU7 High H42 0104
Serial number: A130DA0E3001143
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002177647
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000099877752
Coding: 010850204041230004
VCID: 4683A5E0F19C72B671-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000193421681
Coding: 0300000000000000
VCID: 3169E63C6812C50EB4-8064
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0142720
Coding: 020C010001000100000102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED33D40B1AC9AF6E9-803A
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD737484FB068E6C7-8038
Subsystem 2 - Serial number: 6ó
Subsystem 3 - Serial number: RD12.04.14--H58001002F0398ÿ
Subsystem 4 - Serial number: 2F0398ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0096855861----
Coding: 0000001
VCID: 65C1426CAC5A59AE98-8030
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000099875827
End-------------------------(Elapsed Time: 03:33)--------------------------
