Skoda Superb MY09 and special fault code
V3lmu
Oulu, Finland
C?ID=229426
Hey! :)
I'm looking into a Skoda Superb MY09.
We looked at the car for fault codes when the indicator lights on the instrument panel were on.
First round:
Sunday,07,June,2020,19:34:23:00464
Dealer/Shop Name: J.P - V3lmu
VIN: TMBAF73T599021176   License Plate:
Mileage: 259370km-161165mi   Repair Order:
Chassis Type: 3T-SK46 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 36 42 44 46 47 52 55 56
          62 69 72 77
VIN: TMBAF73T599021176   Mileage: 259370km-161165miles
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 AP    HW: 03L 906 022 GA
   Component: R4 2.0l TDI G000AG  9979
   Revision: 13H01---    Serial number:
   Coding: 0000078
   Shop #: WSC 30432 002 1048576
   VCID: 73B3DFDBE7B535935E0-8026
005642 - Internal Control Module Memory
               P160A - 000 - Check Sum Error - MIL ON
                    Fault Status: 11100000
                    Mileage: 259336 km
                    Date: 2014.10.29
                    Time: 22:58:45
                    Voltage: 11.93 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00101100
                    Temperature: 32.4°C
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich)
                    Mileage: 259365 km
                    Date: 2014.10.29
                    Time: 19:13:43
                    RPM: 2070 /min
                    Speed: 105.0 km/h
                    Lambda: 22.1 %
                    Mass Air / Rev.: 535.0 mg/str
                    Voltage: 0.075 V
                    (no units): 16.0
                    Voltage: 0.975 V
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 051 T    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1980
   Revision: 04844002    Serial number: 00000810100265
   Shop #: WSC 35110 377 00999
   VCID: 2411EC8712DBE22B17A-8070
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 3T0 614 517 B    HW: 3T0 614 517 B
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H12001
   Coding: 0039554
   VCID: 313F15D35D294783ECC-8064
   Part No SW: 3T0 907 044 AJ    HW: 3T0 907 044 AJ
   Component: Climatronic   122 0204
   Revision: 00003001
   Coding: 0100000000
   Shop #: WSC 35703 895 00999
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 7AADF2FFCC5F44DB1D6-802E
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                    Fault Frequency: 21
                    Reset counter: 131
                    Mileage: 258364 km
                    Date: 2020.05.27
                    Time: 12:31:34
   Part No SW: 1K0 937 087 A    HW: 1K0 937 087 A
   Component: BCM PQ35  H+  020 0360
   Revision: 00020000
   Coding: 40990ABAD841F1C040080084110089A401711BAE6320A5605C4040000000
   Shop #: WSC 51273 443 76827
   VCID: 2F3B13AB471D5173FA8-807A
   Subsystem 1 - Part No: 3T1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 30100  22  0602
   Coding: 00D7B7
   Component: RLS 061108 05  54  0402
   Coding: 0730ED
   Subsystem 4 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HO  H08 9001
                    Fault Status: 00101010
                    Reset counter: 117
                    Mileage: 258049 km
                    Date: 2014.10.10
                    Time: 22:52:60
                    Voltage: 12.05 V
                        Term 50 Off
00984 - Left Tail Light (M4)
                    Fault Status: 00101110
                    Fault Frequency: 36
                    Reset counter: 131
                    Mileage: 258049 km
                    Date: 2014.10.14
                    Time: 16:45:17
                    Voltage: 14.00 V
                        Term 50 Off
                    Reset counter: 73
                    Mileage: 258134 km
                    Date: 2014.10.15
                    Time: 08:24:31
                    Voltage: 13.75 V
                        Term 50 Off
                    Reset counter: 75
                    Mileage: 258216 km
                    Date: 2014.10.17
                    Time: 07:23:52
                    Voltage: 13.80 V
                        Term 50 Off
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 3T0 919 475 B    HW: 3T0 919 475
   Component: PARKHILFE PLA H07 0003
   Revision: --------    Serial number: 66430829201646
   Coding: 010104
   VCID: 3C2134E7866BBAEB4FA-8068
   Part No SW: 3T0 959 655     HW: 3T0 959 655
   Component: J234__LA8 VW10 HI   1815
   Revision: 17013000    Serial number: 003CCPNC7SWP
   Coding: 0016696
   VCID: 7EA5FEEFDCF768FB21E-802A
   Subsystem 1 - Serial number: 6333FTS659552908
   Subsystem 2 - Serial number: 6343FTS673752958
   Subsystem 3 - Serial number: 6353ETS6Q2SPVVNR
   Subsystem 4 - Serial number: 6363ETS6594QVVNR
   Subsystem 5 - Serial number: 6373JTS6024QVVNJ
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001731
   VCID: 76B5E6CFF4C720BB79E-8022
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0011
   Coding: 00000130
   Part No SW: 3T1 920 841 D    HW: 3T1 920 841 D
   Component: KOMBI         H06 0106
   Coding: 110F00
   Shop #: WSC 35703 895 09999
   VCID: 34311CC7AEBB72AB87A-8060
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 1K0 815 007 BT
   Component: Standheizer     022 3907
   Revision: 00022000    Serial number: 09020188000000
   Coding: 0021012
   Shop #: WSC 11310 000 1048576
   VCID: 77ABEBCBF3CD59B3628-8022
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K08A080889
   Coding: EDA1FF46100E023302
   VCID: 353721C3A9416BA3B04-8060
   Component: IMMO          H06 0106
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72BDDADF98AF3C9B556-8026
   Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
   Component: TSG FA        H03 0190
   Revision:             Serial number: 0000100396037
   Coding: 011D0220DE00121002
   VCID: 40D94017EA83DE0B132-8014
                    Fault Frequency: 30
                    Reset counter: 93
                    Mileage: 258455 km
                    Date: 2014.10.20
                    Time: 15:16:08
                    Fault Status: 01100010
                    Fault Frequency: 26
                    Reset counter: 93
                    Mileage: 258455 km
                    Date: 2014.10.20
                    Time: 15:39:45
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 196    2301
   Revision: 00H15000
   VCID: 2A0D02BF70FF345B2D6-807E
   Part No SW: 3T0 035 456     HW: 3T0 035 456
   Component: KonzernAmp10K H06 0320
   Revision: --------    Serial number: BP218289495691
   ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
   ROD: EV_AudioVerst10KanalBNO1_VW32.rod
   VCID: 6E85CEAF8017187BB1E-803A
   Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
   Component: TSG BF        H03 0190
   Revision:             Serial number: 0000100445693
   VCID: 3FDB43EB977DA1F36A8-806A
   Component: AFS-Steuergeraet    0136
   Coding: 1376839
   VCID: 34311CC7A23B72AB87A-8060
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000021
   Part No SW: 3T0 035 156 B    HW: 3T0 035 156 B
   Component: BOLERO        006 0053
   Revision: 0A001001    Serial number: SKZ1Z3I9876138
   Coding: 0D0200000000
   Shop #: WSC 51273 443 86019
   VCID: 2D0709A34D112363C84-8078
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0190
   Revision:             Serial number: 0000100385620
   Coding: 010C00200000221002
   VCID: 015F8513A10917035CC-8054
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0050
   Revision: 3A002002    Serial number: 00000115581569
   Coding: 4100000100000000
   Part No SW: 7N0 959 794     HW: 7N0 959 795
   Component: TSG HR        H02 0190
   Revision:             Serial number: 0000100453614
   VCID: 55F7814305014BA3504-8000
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 A    HW: 5N0 035 730 A
   Component: J412                4100
   Revision: 00015000    Serial number: 0000B7A014875
   Coding: 0020121
   VCID: 2615F68F64E7103B09E-8072
End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.2V)-----------
DTC reset and second round
Sunday,07,June,2020,19:40:43:00464
VIN: TMBAF73T599021176   License Plate: 2. KIERROS
          62 69 72 77
   Coding: 0000078
                    Mileage: 259336 km
                    Date: 2014.10.29
                    Time: 22:58:45
                    Voltage: 11.93 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00101100
                    Temperature: 32.4°C
                    Mileage: 259365 km
                    Date: 2014.10.29
                    Time: 19:13:43
                    RPM: 2070 /min
                    Speed: 105.0 km/h
                    Lambda: 22.1 %
                    Voltage: 0.075 V
                    (no units): 16.0
                    Voltage: 0.975 V
   Revision: 00H12001
   Coding: 0039554
   Revision: 00003001
   Coding: 0100000000
   Revision: 00020000
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 010104
   Coding: 0016696
   Coding: 0001731
   Coding: 00000130
   Coding: 110F00
   Coding: 0021012
   Coding: 0000003
                    Reset counter: 93
                    Mileage: 259377 km
                    Date: 2014.10.29
                    Time: 19:38:22
                    Reset counter: 93
                    Mileage: 259377 km
                    Date: 2014.10.29
                    Time: 19:38:22
   Revision: 00H15000
   Coding: 1376839
   Coding: 00000021
   Coding: 00000021
   Coding: 0020121
End----(Elapsed Time: 01:31, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
This DTC did not reset. What this code mean? ECU broken? :confused:
Regards: V3lmu
I think the fault code description is pretty self-explanatory. There is a region of memory in this ECU that does not match the checksum stored for that region of memory.
Is the ECU "tuned"?
V3lmu
Oulu, Finland
C?ID=229426
The owner has owned the car for a couple of days. We not have information on whether the car is tuned.
Well, I think there are only two ways to fix that.
1) I believe a Skoda dealer would simply tell you that the car needs a new ECU.
2) It's possible (but not certain) that someone who does do ECU tuning could correct this error for you.
AE Vlade
Serbia
C?ID=385301
car tuner will help you for sure if car goes OK
Regards
