2008 PASSAT VR6.New User. Need abs coding. Please Help
Vr6G33
Tacoma, WA, USA
C?ID=358316
nothing is broken. I replaced battery. abs,traction control, brake light, and steering angle light all on. please help
hopefully i did this right. i have tried a few codes, so i am aware it is not coded correctly. Can I please get the proper coding for ABS.
WVWCU73C08E009263 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 53 55
          56 62 72 76
VIN: WVWCU73C08E009263   Mileage: 242680km-150794miles
Address 01: Engine (BLV)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 BS    HW: 03H 906 032 AB
   Component: P3.6-FSI-LEV2   G   1409
   Revision: 5GH04---    Serial number: VWZCZ000000000
   Coding: 0000075
   Shop #: WSC 23303 444 69420
   VCID: 74B1DE7FD2B55DDB47A-8020
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 HK
   Component: AQ 250 6F           1091
   Revision: 00H69000    Serial number:
   Coding: 0000072
   Shop #: WSC 52483 003 104857
   VCID: 015F87AB9D0778735CC-8054
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000775488574
   Coding: 0002423
   Shop #: WSC 03808 003 104857
   VCID: 1F1BE1D30BB3AE834A8-804A
02543 - Vacuum Sensor for Brake Booster (G483)
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.05
                    Time: 23:38:20
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00011110
                    Count: 121
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.06
                    Time: 10:10:06
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011110
                    Count: 222
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.06
                    Time: 10:10:06
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011110
                    Count: 149
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.06
                    Time: 10:10:06
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 BP    HW: 3C0 907 044 BP
   Component: ClimatronicPQ46 122 0707
   Revision: 00122021    Serial number: 00000000000000
   VCID: 70B9D26FA6AD61FBA32-8024
                    Fault Status: 01110000
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.05
                    Time: 23:29:33
   Revision: 00H54000    Serial number: 01000007118198
   Coding: E7048A0140000000470000140A000000800900400000083C000000000000
   VCID: 71BFD76BADA768F3ACC-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 300407 003  0205
   Coding: 00048022
   Shop #: WSC 23303
   Component: RLS     120410 054  0403
   Coding: 01519656
   Shop #: WSC 23303
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0088843
   VCID: 2E050C177C19370BF1E-807A
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 18 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2PA7TEX5
   Coding: 0012600
   Shop #: WSC 05311 000 00000
   VCID: 313F176B6D2728F3ECC-8064
   Subsystem 1 - Part No: 3C0 959 339 B
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 0000000003LXPA
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME18170A121ÿ†63
   Subsystem 5 - Serial number: 70A121ÿ†6342MSME19004A01/ÿ†63
   Subsystem 6 - Serial number: 04A01/ÿ†6351HTS66HBK0KU6Xÿ†63
   Subsystem 7 - Serial number: K0KU6Xÿ†6361HTS65JH02MR6Mÿ†63
   Subsystem 8 - Serial number: 02MR6Mÿ†63727TS6LNFC69A6Iÿ†63
   Subsystem 9 - Serial number: C69A6Iÿ†63827TS6LNFK27E6Pÿ
   Subsystem 10 - Serial number: K27E6Pÿ
   Part No SW: 3C0 953 549 K    HW: 3C0 953 549 K
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C5953507BG
   Coding: 0102211
   VCID: 34311E7F92351DDB87A-8060
   Part No SW: 3C0 920 971 F    HW: 3C0 920 971 F
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0000205
   VCID: 2809FA0F5EFD693B3B2-807C
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P0753005FA
   Coding: FD81FF0E1013021002
   Shop #: WSC 05311 123 12345
   VCID: 2313ED2327DB8A636E0-8076
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1166279TRH1706
   VCID: 6D87CB1BB19F8C13884-8038
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 26031 444 84488
   VCID: 73B3DD63D7BB5AE35E0-8026
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D070B1B711F4C13C84-8078
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1131
   Revision: 31008001    Serial number: 00000575978427
   Coding: 0001527
   VCID: 3C21365FBA65D59B4FA-8068
00120 - Outside Warning Light/Door exit Light Driver Side
                    Fault Status: 01101100
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.05
                    Time: 23:39:56
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.136 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 3537237B994F04D3B04-8060
02546 - Steering Limit Stop
                    Mileage: 242670 km
                    Temperature: 36.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
   Component:    KSG PQ46 RDK 051 0221
   Coding: 1A910F800186C07F7F021515708E8F0E487840
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000002430
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.05
                    Time: 23:39:53
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.06
                    Time: 10:11:00
                    Reset counter: 210
                    Mileage: 242686 km
                    Date: 2020.06.06
                    Time: 10:11:00
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1131
   Revision: 31008001    Serial number: 00000548778514
   Coding: 0001462
   VCID: 3D273B5BA17FDC93784-8068
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
                    Fault Status: 00101100
                    Reset counter: 250
                    Mileage: 242686 km
                    Date: 2020.06.05
                    Time: 23:39:56
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000027427
   Coding: 0000057
   VCID: 290FFF0B45F7503324C-807C
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2306049
   VCID: 323D1867682113EB956-8066
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       018 0035
   Revision: 00018000    Serial number: VWZ5Z7G2153567
   Coding: 0022001
   Shop #: WSC 48689 003 104857
   Component: J388   TUER-SG HL   1118
   Revision: 12006001    Serial number: 00000001725972
   Coding: 0001168
   VCID: 3E253C57AC79C78B61E-806A
   Component: J389   TUER-SG HR   1118
   Revision: 12006001    Serial number: 00000001719153
   Coding: 0001168
   VCID: 3FDB4153AB73CE836A8-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90630714100885
   Coding: 0001114
End----(Elapsed Time: 01:45, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Hi and welcome.
Moving this to Car Repair Support.
Vr6G33
Tacoma, WA, USA
C?ID=358316
Can someone help please
United States
Excellent! I added your (FWD 3.6L Auto transmission) specific config to the label file so the next guy with this issue can build the coding using the Long Coding Helper. It was limited to one AWD option previously which is all you had to choose from for 2008 MY.
