I'm trying to adjust the levels of the inputs for my phone, bluetooth, etc. These levels used to be in the green screen on the MMI 3G, now it looks like they're in 5F adaptation.
How do you figure out the Security Code?
(I was able to login to enable the Green Screen through Development Mode and entered the Green screen by holding Back and Lower Right button, Engineering menu is Back and Upper Left button. )
...and 32K Miles and NO errors? I really don't believe that Audi finally did it.
Autoscan
Autoscan
Friday,05,June,2020,17:49:04:52815
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Andy
VIN: WAUFFAFC7HN000000 License Plate:
Mileage: 51540km-32025mi Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 1B 22 28 34 36 3B 3C 42 44 46
52 53 55 5F 62 6C 72 8F 90 A9 BA
VIN: WAUFFAFC7HN000000 Mileage: 51540km-32025miles
Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 0A2500326526010E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 2310E7ECEB591CE36E9-8076
Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H03 0006
Revision: --H03---
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 303A18A0AAAFB77BE3B-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 65BED441A67D2B821B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DC4D6411052EF31C5-8014
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0824
Coding: 0DA86F4E000000000000
VCID: 005A88605A0FE7FB53B-8054
Serial number: 3216000043437016
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 11051600041072
Coding: 688130B8490000
VCID: 6A8ECAC84CF30DABEDF-803E
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 21020001 Serial number: 00001355220801
Coding: 01050011043C9FF0B90048C780003800CF9CD208A608022180000814F110170200600034030000
VCID: 79ACE58439D5B633145-802C
Component: WWS57X 160330 H38 0080
Serial number: 160415024538
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61790445
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 13 05 2016 00001339
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0244B951
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA123402000020181586
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: A909862800PAG0MUFU01
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G00035THU
Coding: 303331343135303334394A55304C34473053
VCID: 343214B05EB78B5B873-8060
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y160001GYEU0Q
Serial number: 3575HRB405L436HUC8Q$
Serial number: 3585HRB405J436HU29DG
Serial number: 3515JRB404P3VEM82P93
Serial number: 3525JRB405N3VEM8BORT
Serial number: 3554VRB400C570C0R91Y
Serial number: 3564VRB401I5726KD966
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372PDL0006G
Coding: 000434
VCID: 382A2080425F6F3BABB-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 30 03 2016 C0090592
Part No SW: 4G0 920 982 Q HW: 4G0 920 982 Q
Component: TBenUsa Nv H14 0225
Revision: 11001108 Serial number: 658170516596031
Coding: 03E70905BB41D705020200
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 3A2E3A887CD37D2B5DF-806E
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Revision: -------- Serial number: 00000002252742
Coding: C0ED074814
VCID: 3D2431946DFD4A1378D-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 5913940104
Voltage stabilizer:
Serial number: 1603010000000000078F
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0E0100
VCID: 3A2E3A887C537D2B5DF-806E
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 000305160001019
VCID: 280AF0C0927FFFBB3BB-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 10051600041411
Coding: 20
VCID: 3E26369860FB510B617-806A
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008004
ROD: EV_AirSuspe_VW51.rod
VCID: 2F381BDCB791A883FA1-807A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000199073143
VCID: 77A8E3BC0FC1A043621-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E0268B%
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372823BC4FC16043A21-8062
Component: SWA Master H08 0070
Serial number: 0403610009
Coding: 040211
VCID: 392C258479D57633545-806C
Lane Change Assistant 2:
Component: SWA Slave H08 0070
Serial number: 0404579479
Coding: 040211
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F17015E00628002000012
VCID: 47C8537C3FA110C3D21-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000895841
Coding: 011000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0404425256
Coding: 0106063A00FA418580B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000348622
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000YXNQ800000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00020407468
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93820004
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 46D65E7838AB09CB297-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001848136
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313C1DA4A1A5BE73EC5-8064
Component: MxB-ECU 001 0100
Coding: 04FA0A1122200400
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 C HW: 4G1 035 025 C
Component: MU-H-LNS-US 052 0671
Serial number: A741E0G7500035
Coding: 017551020000000013220002041A00102F0007E5F17001047E
VCID: 1E66D618C03B310B417-804A
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY8050M9
Multimedia Operating Unit:
Serial number: 90349PED000LB
Compact Disc Database:
Component: Gracenote2--- --- 3009
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 49CC554429B5E6B3C45-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 027500010A002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78AAE080025FAF3B6BB-802C
Component: TSG HR H03 0511
Component: RGS-VL H16 0080
Coding: 0006E008031F0300070308014244C8010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 323E12A8A4A3856B95F-8066
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 160225200382
VCID: 2C020CD08687D39BDF3-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813006773401
ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 13.1V/13.1V)-----------
