Sunday,07,June,2020,12:24:38:51200
VCDS Version: 20.4.0.1
Dealer/Shop Name: Haarsma
VIN: WVWZZZ3CZ8E231165 License Plate: 3TGD35
Mileage: 405540km-251990mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 25 36 42 44 46 47 4F 52
53 5F 62 69 72
VIN: WVWZZZ3CZ8E231165 Mileage: 405540km-251990miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 CN HW: 03L 907 309
Component: R4 2,0L EDC F001AG 6220
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 73EFF525127D281E0F-8026
050197 - Implausible Data Received from ABS Control Module
U0415 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 405540 km
Date: 2020.06.07
Time: 12:15:14
RPM: 782 /min
Speed: 4.0 km/h
Voltage: 14.21 V
Bin. Bits: 00010100
Bin. Bits: 00000000
(no units): 33.0
Readiness: 1 1 0 0 0
Part No SW: 02E 300 050 D HW: 02E 927 770 AL
Component: GSG DSG AG6 511 1464
Revision: 51112 Serial number: 00000902190468
VCID: 132F95A532BD881EAF-8046
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Fault Frequency: 255
Reset counter: 1
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
18250 - Please check DTC Memory of Instrument Cluster
P1842 - 000 -
Reset counter: 1
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:28
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 698 109 E HW: 3C0 614 109 AF
Component: J104 C4 440 V3 0017
Revision: --025--- Serial number: 00000104023403
Coding: 0024854
VCID: 2C5D2E598FC337E68E-8078
8 Faults Found:
Reset counter: 45
Mileage: 405458 km
Date: 2020.06.02
Time: 16:16:18
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011111
Count: 152
Hex Value: 0x0000
16353 - Control Module - Internal Malfunction
014 - Defective
Fault Status: 00001110
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:14:18
Speed: 6.0 km/h
Hex Value: 0x0000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 39
Hex Value: 0x0000
00003 - Control Module
014 - Defective
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:14:18
Speed: 6.0 km/h
Hex Value: 0x0000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 110
Hex Value: 0x0000
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:14:30
Speed: 6.0 km/h
Hex Value: 0x0001
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 31
Hex Value: 0x0000
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:14:30
Speed: 6.0 km/h
Hex Value: 0x0001
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 30
Hex Value: 0x0000
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:17:44
Speed: 7.0 km/h
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 16
Hex Value: 0x0000
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:17:44
Speed: 7.0 km/h
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 17
Hex Value: 0x0000
Reset counter: 7
Mileage: 405539 km
Date: 2020.06.06
Time: 17:17:44
Part No SW: 5ND 907 044 G HW: 5ND 907 044 G
Component: Climatronic H07 0404
Revision: 00001K03
Coding: 0610004002
VCID: 46897CF1F96FEDB678-8012
13701904 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:24
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:24
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008249495
Coding: F5888F3510041A1147000F000F00000080195D436400010C000000000000
VCID: 71E3FF2D68611A0EFD-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 070308 003 0205
Coding: 00049077
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 150408 046 0204
Coding: 00995365
Shop #: WSC 12345
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391608303549
Coding: 0071157111
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 377701358E85843EF3-8062
13639168 - Databus
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb
Part No SW: 3C0 907 567 M HW: 3AA 907 567
Component: AC201 RDW A 036 0243
Revision: 00036000 Serial number: 00000000507894
Coding: 0010000
VCID: 356B0B3D5C89762EE1-8060
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:26
Count: 4
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:26
Count: 1
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 24011201770002
Coding: 030180
VCID: 2757D175562514BE63-8072
03263 - Functional Restriction
000 - - - MIL ON
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
Error Code: 6
Bin. Bits: 00000000
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
Bin. Bits: 00000000 00000001
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP7DDMR3
Coding: 0012341
Shop #: WSC 05311 000 00000
VCID: 3B7F1D057AADA05E17-806E
Subsystem 1 - Serial number: 6333FTS679040708
Subsystem 2 - Serial number: 6343FTS643870708
Subsystem 3 - Serial number: 6353ETS6T8U1TVNP
Subsystem 4 - Serial number: 6363ETS6VSJ1TVNP
Fault Status: 01101000
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0201822
VCID: 72E1F0216D67211604-8026
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Part No SW: 3C8 920 880 T HW: 3C8 920 880 T
Component: KOMBI H04 1008
Coding: 160D000000
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3D7B131DACB9AE6E29-8068
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [009] - -
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:24
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 110914F1002091
Coding: 462036
VCID: 7BFFDD05FA2D605E57-802E
Part No SW: 3AA 959 433 F HW: 3AA 959 433 E
Component: IMMO 042 0429
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 43138 001 1048576
VCID: 3C7D1E197FA3A7661E-8068
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000001
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0321
Revision: 12101005 Serial number: 0000886354
Coding: 0011F7
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2649DC71592F0DB658-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0307
Serial number: 00000000331050
Coding: 0000D0
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.299 1002
Revision: 1AH03734 Serial number: 00112710386901
Coding: 0000258
00566 - Steering Assistance Operation
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
Hex Value: 0x7301
Hex Value: 0x7601
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Fault Status: 11100101
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
(no units): 7.0
Steering Angle: 0.00°
Not OK
(no units): 8
Fault Status: 11101101
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
RPM: 777 /min
Speed: 50.0 km/h
(no units): 7.0
Voltage: 14.10 V
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
RPM: 777 /min
Speed: 50.0 km/h
(no units): 7.0
Voltage: 14.10 V
Component: KSG PQ47 ELV 042 0714
Coding: 1891020051034E7F00021C1F7008CFCE707901
Component: LIN BACKUP HORN H08 9001
Component: Neigungssensor 004 0611
00625 - Vehicle Speed Signal
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:27
Address 47: Sound System (-----) Labels: 5K0-035-456.clb
Part No SW: 3AA 035 466 A HW: 3AA 035 466
Component: KonzernAmp12K H02 6910
Revision: -------- Serial number: AA1108A0000108
ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
ROD: EV_AudioVerst12KanalSTT1.rod
VCID: 2E59245171DF45F6A0-807A
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 00000009
VCID: 6FE7F955BE550CFEEB-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0006086936
Coding: 0011F6
VCID: 36690C31898F7D36E8-8062
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0307
Serial number: 00000000340928
Coding: 0000D0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000055708
Coding: 0000057
Shop #: WSC 12346 987 64321
VCID: 2855D2499B3B1BC66A-807C
Fault Status: 11111101
Reset counter: 9
Mileage: 405540 km
Date: 2020.06.07
Time: 12:20:25
Voltage: 13.70 V
Count: 106
Hex Value: 0x1260
Hex Value: 0x0082
Hex Value: 0x0101
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0252
Serial number: VWZAZ2R8029459
Coding: 02731201AA00000011111103018808001F0106D400200101CF
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2143CF6D3001EA8E2D-8074
Subsystem 1 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Part No SW: 1K0 907 383 D HW: 1K0 907 383 B
Component: Anhaenger H16 0070
Revision: 3A002001 Serial number: 00000110888610
Coding: 0100000200000000
Shop #: WSC 05314 000 00000
VCID: 2E59245179DF45F6A0-807A
End-------------------------(Elapsed Time: 03:38)--------------------------
