Has anyone got the procedure for remote windows open and closing using VCDS for 2017 Jetta GLI?
We still need that Auto-ScanI didn't notice the mistake. I have a 2017 VW Jetta GLI, not a 2019. Sorry about that.
I've adjusted the thread title.I didn't notice the mistake. I have a 2017 VW Jetta GLI, not a 2019. Sorry about that.
VCDS Release 20.4.1: SRI Reset-SRI1.CLB
Control Module Part Number: 5C6 920 886 A Labels: .*5K0-920-xxx-17.clb-SRI1
Component:KOMBI H02 1104, Coding:331E000000
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status Warning active ---
IDE00510-ESI: distance driven from inspection ESI: Distance since Inspection 13800 km ---
IDE00511-ESI: time from inspection ESI: Time since Inspection 185 d ---
IDE00515-ESI: oil quality ESI: Oil Quality poor oil quality ---
IDE00517-ESI: soot entry ESI: Soot Quantity 0 km ---
IDE00518-ESI: thermal load ESI: Thermal Load 14600 km ---
IDE01153-SIA: maximum value of distance to service SIA: Maximum Distance to Service 15000 km ---
IDE01154-SIA: maximum value of time to service SIA: Maximum Time to Service 365 d ---
IDE03349-FIX: Max. distance until next mileage-related inspection FIX: Maximum Distance to Inspection 30000 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Maximum Time to Inspection 365 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance since Inspection 13900 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time since Inspection 185 d ---
Friday,24,July,2020,09:49:19:54235
VCDS Version: 20.4.1.0 (x64)
VIN: 3VW5T7AJ9HM215346 License Plate: CCH3412
Mileage: 120840km-75086mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 55
5F 62 72
VIN: 3VW5T7AJ9HM215346 Mileage: 120840km-75086miles
Address 01: Engine (J623-CPPA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 BL HW: 06K 907 425 C
Component: R4 2.0l TFS H13 4892
Revision: --H13---
Coding: 00190012242400171000
Shop #: WSC 00066 790 00012
ASAM Dataset: EV_ECM20TFS02006K906071BL 001009
ROD: EV_ECM20TFS02006K906071BL.rod
VCID: 76CD0D3BC914E63621-8022
17178 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B600C492300FF850E06E8921F00412118F028
Shop #: WSC 00066 000 00000
VCID: 75CF0A37DC12ED2E28-8020
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 G HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial number: 0403167759
Coding: 032C0C
Shop #: WSC 00066 000 00295
VCID: 3957C607B88A494E0C-806C
Part No SW: 1K8 907 044 CN HW: 1K8 907 044 CN
Component: Climatronic H08 0405
Revision: 00001K05
Coding: 005000C002
Shop #: WSC 00066 790 00318
VCID: 7DDF1217EC22B56E60-8028
Part No SW: 5K0 937 087 AJ HW: 5K0 937 087 AJ
Component: BCM PQ35 H+ 122 0184
Revision: BL122001
Coding: EF200A1A802F3ED40088008124000D4C0074000645A08DB2E4842000A040
VCID: 7DDF1217E422B56E60-8028
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 270616 04 42 0106
Coding: 0228DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0479
Revision: -------- Serial number: 39331615311520
Coding: 0071155001
ASAM Dataset: EV_EPHVA18VW364GP00 001006
VCID: 364DCD3B8994A636E1-8062
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 001 0207
Serial number: 003RXM06Y4FF
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 63EB446F6A86639E76-8036
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000005CRAES
Coding: 30314D
Subsystem 2 - Part No SW: ----------- HW: 480 001 305 16
Serial number: 3570000000003609DA1E
Subsystem 3 - Part No SW: ----------- HW: 480 001 305 16
Serial number: 35800000000EC0952B1R
Subsystem 4 - Part No SW: ----------- HW: 480 022 405 16
Component: SideSensor_Dr 000 0148
Serial number: 3510001B3210BB03426L
Subsystem 5 - Part No SW: ----------- HW: 480 022 405 16
Component: SideSensor_Pr 000 0148
Serial number: 3520001B3210BB03471M
Subsystem 6 - Part No SW: ----------- HW: 480 022 405 16
Component: FrontSensor_D 000 0189
Serial number: 3550001B520E18B59543
Subsystem 7 - Part No SW: ----------- HW: 480 022 405 16
Component: FrontSensor_P 000 0189
Serial number: 3560001B520E18B2E614
Part No SW: 1K5 953 521 CR HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20160531100650
Coding: 0002440008
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7F23E81FE62EA77E72-802A
Subsystem 1 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H04 0103
Serial number: 29160000847760096166
Coding: B0FFFF
Part No SW: 5C6 920 886 A HW: 5C6 920 886 A
Component: KOMBI H02 1104
Coding: 331E000000
Shop #: WSC 57566 003 1048576
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3041FB236BF08806BB-8064
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 21061603010150
Coding: 351032
VCID: 7BDB1C0FFA36BB5E5E-802E
Component: IMMO H02 1104
Coding: 000007
VCID: 6AF5294B8DAC32D6B5-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000092027009
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: 3147FE2760FA810EB4-8064
Component: HRE_Master H12 0071
Serial number: 0405233403
Coding: 02011102
Shop #: WSC 01383 790 50316
ROD: EV_HREntryHella_VW32.rod
VCID: 3C59DF13B7B87C6617-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0404560205
Coding: 020111
Part No SW: 561 959 701 B HW: 3C0 959 793 H
Component: TUER-SG FT 002 0631
Revision: 13100010 Serial number: 0010505456
Coding: 0404BD
Shop #: WSC 00066 790 00164
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
VCID: 1D1F32970C62156E00-8048
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14202745160627060702
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3957C607708A494E0C-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H09 6831
Revision: -------- Serial number: EAA098C0094590
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 287113435320C0C663-807C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 01030100
VCID: 6FC3385FBE4ED7FEE2-803A
Subsystem 1 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST000Z8GOB00000
Coding: 180000
Part No SW: 561 959 702 B HW: 3C0 959 792 H
Component: TUER-SG BT 002 0631
Revision: 15100010 Serial number: 0010515126
Coding: 0404BC
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
VCID: 1E1D359B01640E7619-804A
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14202744160629001012
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 081200010B000200
VCID: 3753C03F8E9E5F3EFA-8062
Subsystem 1 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Part No SW: 5C0 035 684 B HW: 5C0 035 684 B
Component: MU-S-NS-US H30 0357
Serial number: VWZAZ2S0222904
Coding: 02630102AA00000011220003001828001F0100D400200105C6
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 246907732F0824A64F-8070
Subsystem 1 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [008] - Missing message
Reset counter: 38
Mileage: 116015 km
Date: 2020.05.29
Time: 14:54:37
Voltage terminal 30: 12.9 V
System_Software_Error-SW_Status_Consistency: 02 01 00
System_Software_Error-SW_Status_Device: P
End-------------------------(Elapsed Time: 03:19)--------------------------
Friday,24,July,2020,09:59:03:54235
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI ESI: Service Reminder Status Warning active 0
Address 17,5C6 920 886 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,
