MK7 GOLF 2014 CAN GATEWAY UPGRADE? RANGE ERROR
Gashhey
C?ID=350180
2015 VW GOLF GTD. Upgraded to virtual dash however now have range error. Is someone able to advise which can gateway part no is needed for this car?
Friday,05,June,2020,14:09:59:18214
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: hhhhhhhhhhhhh
Workshop Code: 000 00000 032212
VIN: WVWZZZAUZEW302219   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   X22 7539
   Revision: 81X22---
   Coding: 01190012034505082000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77ABE8368F4936D3621-8022
   Revision: 00000000    Serial number: 603440000001D9
   Coding: 01FA8AA13420096E0379060141CC2980512C90C0608294F5F4605078C009
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 7BA3F406B36112B3069-802E
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0112010420211001100500000010102A
   VCID: 6D87CA5EFD158C0388D-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011403701502
   Coding: 03000A46C24122FB0BA44080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Component: WWS    140203  042 0551
   Serial number:         140205074010
   Component: RLFS  024 0042
   Serial number: Y14M02D06H22M21S12S6
   Coding: 00A8DD
   Serial number: 000000000ZY140161556
   Serial number: 00000000000058683229
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331403704340
   Coding: 0071151001
   VCID: 3E253D12E0F3C79B617-806A
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 13041476510953
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 36352532C8C30FDBB97-8062
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR03HZBA
   VCID: 7F5B0016A7790E932A1-802A
   Belt Pretensioner left:
   Serial number: 34169677B10021441158
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B11021440489
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 003 101 14
   Serial number: 3576700000044C10DE0X
   Subsystem 4 - Part No SW: -----------    HW: 480 002 908 14
   Serial number: 3586700000096251E01O
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3516502C912AB1B2E23E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3526502B313013F2C1A%
   Subsystem 7 - Part No SW: -----------    HW: 480 400 804 14
   Serial number: 3556502C31524DC4837E
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 07021404220123
   Coding: 0C00
Address 17: Instruments
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001606216
   Coding: 030100040B087300EF00027E080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FDB4016E7F9CE936A1-806A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 29140002486260044466
   Coding: 2CFFFF
   Serial number: 6632152503
   Serial number: 27011401100173
   Coding: 003F0220D001048000001000
   VCID: 40D943EA9A07B16B13B-8014
   Serial number: 00000000000001692337
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3537223ED5C504C3B0D-8060
   Serial number: 04091401101824
   Coding: 003F0020DE01048000801000
   Serial number: 00000000000003770916
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A01000B000000
   VCID: 3D273A1EEDF5DC8378D-8068
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0757
   Coding: 02731001FF00000051110101008808001F0102F601200000CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F162E21AD28E3EC5-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3415614
   Subsystem 2 - Part No SW: 5NA 919 866 AH    HW: -----------
   Component: ECE1 2020/21  --- 1410
          B201A 00 [009] - -
                    Reset counter: 149
                    Mileage: 88900 km
                    Date: 2020.05.22
                    Time: 01:41:34
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name: C
   Component: SAS-GEN 2     H06 0013
   Serial number: 140129201271
   VCID: 6B83C446C3018233969-803E
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.2V)-----------
AINils
Germany (AIB)
First way is to change GW to 3Q0 Variant, but it has CP on it, also new Dataset is needed. Your Discover Media is fine for it.
myounus
Northwest UK
C?ID=321059
You need another tool to flash your gateway to software Version AJ which sometimes works, saving the hassle of changing to a 3Q0 gateway. If you get a 3Q0 gateway then go to a dealer as you’ll need to use ODIS to remove component protection and restore FEC’s.
darkchina811
ITALY
C?ID=333184
or flash it to AM index, AM works for sure with AID.
downtime
Finland
C?ID=280813
As others wrote. Your Q index gatewy is WAY too old to support virtual cluster. But you can flash it to newer version and like AINils wrote, you need to parameterize it with a dataset which VCDS is not able to do :(
AINils
Germany (AIB)
Never seen AM Firm for Lear GW, only Conti is available in my mind
downtime
Finland
C?ID=280813
Now you have :
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005002497
   Coding: 030500341F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CCE7ABAF7A3AFAFC5-8028
Gateway that I have in my Tiguan. Whole autoscan here : https://forums.ross-tech.com/showth...hp-DSG-4Motion&p=203058&viewfull=1#post203058
