Hi guys and gals.
Recently I purchased a MFSW for a 2014 1.6tdi VW Caddy, part number 2K5.419.091 E74 and after doing some research, I realised that I needed to purchased another SWCM as the one fitted would not accept the MFSW but would do CC.
I also need a new BCM due to retro fitting front fogs at the same time; which went flawlessly and worked. Both parts were new and genuine.
Here are the part numbers for the relevant modules SWCM:- 5K0 953 569 BD, BCM:- 5K0 937 087 AC.
The problem that I am having is even though (I think) the coding is correct, the CC is not activating via the MFSW. When i took the van out for a test drive, i made sure that i was going fast enough for the system to activate.
I can alter the volume and change radio station via the MFSW, the horn works and the back lights for the buttons work when i turn the lights on.
Any help would be gratefully received.
Please find below the before and after scans.
Before:-
After:-
TIA
Before:-
Friday,27,March,2020,23:25:01:46247
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ2KZFX020471 License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZFX020471 Mileage: 81950km-50921miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TF HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000
Coding: 00114010030500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TF 003002
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 7DA60B49DD7A249FA23-8028
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 433C400D092403FAC20F02EB901AC081A0000020
Shop #: WSC 35110 377 08192
VCID: 7EA40C45D0FC3F87BB9-802A
Part No SW: 5K0 937 085 AA HW: 5K0 937 085 AA
Component: BCM PQ35 B+ 122 0174
Revision: BB122001
Coding: 411A583A8023186A08800082800000C80701728852020060648000000040
VCID: 72BC287594A46BE7CF1-8026
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 14061 26 0512
Coding: 009795
Fault Status: 01101100
Reset counter: 167
Mileage: 81389 km
Date: 2014.07.14
Time: 16:56:05
Term 15 Off
Voltage: 12.60 V
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 29
Reset counter: 202
Mileage: 80946 km
Date: 2020.01.29
Time: 15:25:10
Voltage: 14.25 V
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02Q H07 0013
Revision: -------- Serial number: 003HL00RDLU3
Coding: 000000000000000000000000000000003251
VCID: 3536D369A5CA3CDF2A3-8060
Part No SW: 1K5 953 521 BG HW: 5K0 953 569 AC
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140614100784
Coding: 0080060000
ROD: EV_SMLSNGVOLWS.rod
VCID: 73B22D71EB3E62EFC47-8026
Part No SW: 2K0 920 966 C HW: 2K0 920 966 C
Component: KOMBI H03 0905
Coding: 480000
VCID: 3038E27D5AA819F7795-8064
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 260614F1000896
Coding: 357401
Component: IMMO H03 0905
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C3015BCF4A327771-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 48C8AA9DCEB8B137415-801C
01340 - Mirror Adjustment Switch
01706 - Switch for Mirror-Adjust (E43)
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 392EDF598552D8BFCEB-806C
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 47CAA9A1C3A6BE4F48F-8012
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 004 0119
Revision: 01000001 Serial number: VWZ1Z2N1865223
Coding: 05000200020013
Shop #: WSC 31414 790 31414
VCID: 3536D369A54A3CDF2A3-8060
End----(Elapsed Time: 00:44, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)---
After:-
Wednesday,03,June,2020,18:19:18:46247
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ2KZFX020471 Mileage: 82490km-51256miles
Coding: 00114010032500080000
VCID: 7DA60B49DD7A2493384-8028
Revision: 00H46001
VCID: 7EA40C45D0FC3F8B21E-802A
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 411A583A8023186A08800082800081C80700728852020060648000000040
Shop #: WSC 18752 008 00032
VCID: 76B41465F8CC77CB79E-8022
Coding: 009795
Reset counter: 236
Mileage: 82495 km
Date: 2014.10.25
Time: 00:49:39
Voltage: 13.00 V
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3536D369A5CA3CD3B04-8060
Part No SW: 5K0 953 569 BD HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: --X01--- Serial number: 20171017200004
Coding: 008A460000
Shop #: WSC 01286 386 08256
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7BA20551C36E2AA3060-802E
Subsystem 1 - Part No SW: 2K0 959 442 HW: 2K0 959 442 Labels: 3C8-959-537.CLB
Serial number: 0861809514600613BA1B
Coding: 280000
Coding: 480000
VCID: 3038E27D5AA819FBE32-8064
Coding: 357401
VCID: 6A8C3015BCF4A32BED6-803E
Coding: 0000624
VCID: 48C8AA9DCEB8B13BDB2-801C
Revision: 00H22000
VCID: 392EDF598552D8B354C-806C
Coding: 0000624
VCID: 47CAA9A1C3A6BE43D28-8012
VCID: 3536D369A54A3CD3B04-8060
End----------(Elapsed Time: 00:45, VBatt start/end: 13.0V/13.0V)-----------
TIA
