- Jun 1, 2020
- 2
- 0
- Brooklyn, USA
- C?ID=405706
Unable to go further once in option 9-Central Electrics. I am trying to see why is my adaptive air suspension is disabled, also identify the actual serial number for my radio unit, and after doing that AUTO SCAN I have noticed a lot of REDS. I would greatly appreciate the help. The minor tweaks I can manage.
Monday,01,June,2020,16:42:49:54641
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WA1DGAFEXFD015106 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFEXFD015106 Mileage: 94210km-58539miles
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 36352384844A2AABB97-8062
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Coding: 001378
Shop #: WSC 21753 003 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 3A2D37B4BCD2CECB5DF-806E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099409
VCID: 3431198C923638BB873-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902182697
Coding: 0000135
VCID: 2517F4C829EC513300D-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Component: FBSAUDIC6 KSG H03 0020
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 228
Mileage: 70994 km
Date: 2018.02.05
Time: 15:52:11
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Status: 00111000
Fault Frequency: 37
Reset counter: 102
Mileage: 76951 km
Date: 2018.05.03
Time: 00:12:24
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Fault Status: 00111011
Reset counter: 71
00193 - Rear Right Door Handle Touch Sensor (G418)
Fault Status: 01100111
Fault Frequency: 19
Reset counter: 212
Mileage: 90868 km
Date: 2019.10.23
Time: 17:35:30
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01110010
Reset counter: 1
Mileage: 91214 km
Date: 2019.11.15
Time: 18:04:10
Reset counter: 251
Mileage: 92970 km
Date: 2020.02.09
Time: 17:55:59
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Revision: 00---031 Serial number: 00000030366370
Coding: 000CC026
VCID: 2517F4C825EC513300D-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0128073577
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0128073142
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6E85CBE4BC9A526BB17-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961501000495
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3431198C9EB638BB873-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90GPDR
Coding: 0014131
VCID: 2B0302F04F086743D69-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME5A4E2276P
Subsystem 3 - Serial number: 6342QSME5D4E145E-
Subsystem 4 - Serial number: 6352QSME1E4D4672S
Subsystem 5 - Serial number: 6362QSME4D4E2658Y
Subsystem 6 - Serial number: 63734SME69483040Z
Subsystem 7 - Serial number: 63834SME604A5760/
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H09000 Serial number: 90026150140061
Coding: 0012242
VCID: 2809FDFC5EFE4C5B3BB-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R00NN1G
Coding: 8BD763040900CF05020205
VCID: 44D1494CCE96883B373-8010
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M1511301FB
Coding: 00C303
VCID: 3FDB46A0A770EBE36A1-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32008E28324121303098
Fault Frequency: 8
Reset counter: 209
Mileage: 93184 km
Date: 2020.03.05
Time: 17:46:56
Bin. Bits: 11111
Voltage: 12.40 V
Count: 7
Text: FFF5646D0482E101
Raw, Index/Key Err.: 245 100 109
Ign. Timing: 127.4 °ATDC
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---011 Serial number: 00000030367301
Coding: 0000006
VCID: 6889BDFC9E7E8C5BFBB-803C
00003 - Control Module
Fault Status: 00100011
Fault Frequency: 14
Mileage: 74255 km
Date: 2018.04.04
Time: 15:48:34
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000132085165
Coding: 00581B00000011110000
VCID: 323D1F946422368B95F-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E050BE47C1A126BF17-807A
Component: J0770_SWA_Slave_H03 0050
Subsystem 3 - Serial number: 5F02.01.1500H03000AMS14558ÿ
Subsystem 4 - Serial number: S14558ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000133879908
Coding: 011F57205E40440004
VCID: 48C95D7CF2BEAC5BDBB-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82009739420000
Coding: 3569949
VCID: 38292DBC8E5EDCDBABB-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000066397
Coding: 030000
VCID: 290FF8F849F47553245-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191083273
Coding: 0693965
VCID: 2313EAD027D8AF036E9-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000209707
Coding: 0012001
VCID: 5EE59B244C3AC2EB017-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000132732260
VCID: 47CB5E40FFA0A323D21-8012
Reset counter: 250
Mileage: 94157 km
Date: 2020.05.30
Time: 15:28:50
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Reset counter: 37
Mileage: 83459 km
Date: 2019.01.26
Time: 16:57:53
Revision: AB001007 Serial number: 156G/0E8034079
Coding: 020007010000000001
Shop #: WSC 06335 000 00000
VCID: 2411E9CC2ED6A83B173-8070
Reset counter: 104
Mileage: 93184 km
Date: 2020.03.05
Time: 17:46:58
Part No SW: 4L2 035 746 H HW: 4L2 035 746 G
Component: H-BNT-NA H42 1040
Revision: -------- Serial number: 513A$0F7508684
Coding: 180200060204E1FF59002F456F632003140000000100000000
VCID: 33331A909B383F839E9-8066
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130L 0E3228377
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002225391
Component: CD-Database 5950
Reset counter: 193
Mileage: 93980 km
Date: 2020.05.15
Time: 15:56:23
Text: ARU9471,TNR,A,1,1af,1
Reset counter: 252
Mileage: 94188 km
Date: 2020.05.31
Time: 17:44:15
Bin. Bits: 00000000 00000000
Bin. Bits: 00000010 00000000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000133915668
Coding: 010E57204040230004
VCID: 46D55344F8AABA2B297-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000356039357
Coding: 0200000000000000
VCID: 313F109861240D93EC5-8064
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0198785
Coding: 020C010001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E85CBE4B01A526BB17-803A
13701377 - Databus
[Funktionseinschränkung wegen fehlender Botschaft (Getriebe_1)]
Mileage: 92923 km
Date: 2020.02.04
Time: 08:27:09
Voltage terminal 30: 11.5 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C1EC8A86A07B9F3-8038
Subsystem 3 - Serial number: RD19.01.15--H58001001C0027ÿ
Subsystem 4 - Serial number: 1C0027ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0133864382----
Coding: 0003595
VCID: 2615F3C454EA5A2B097-8072
Component: J_245_EE16_SKB10H15 0220
Component: J_394_EE16_SKB10H15 0220
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000133915601
End----------(Elapsed Time: 02:18, VBatt start/end: 14.2V/14.2V)-----------
