renniedevon
Pirate
Hi guys I have an Audi A3 1.6TDI 2010. To cut a long story short the timing belt jumped, i had it timed back up with a new belt kit and waterpump. The garage said it was running well witch it is once its started but it has an intermittent starting issue. while it was at the garage they also did the fuel filter if that's helpful at all. When I first start the car it turns over for 5 to 10 seconds sometimes longer then it starts but the idle is very rough for about 5 seconds and sometimes it stalls but, once its been started for a while and run around abit it starts up really easily. ive posted and auto scan below as the car is now coming up with a fault for MAF sensor and occasionally MAF signal high and these seem to bring an esp fault with them. The other thing is the car seems to be trying to regen a hell of a lot since ive had it back and evry so often i get a witf of fuel. ill post below the steps ive already tried. sorry for the long story hope someone can help.
Timing checked by third party
Hard run down the motorway
Disconnecting maf sensor (car dose seem to start abit easier sometimes but still rough idle)
[b]Removed. Data from a clone/pirate copy of VCDS is not acceptable here.[/b]
