Please help multiple faulty codes jetta mk5
pegasus19
HC801499 (2nd hand?)
Hi is my first time in the forum, and im trying to fix multiples faulty codes in my jetta 2.5 , im rookie using the Ross-tech software and i dont know what to do, i run the scan and after that i cleared the faulty codes but unfortunately somes faulty codes dont go away please help
Sunday,31,May,2020,16:12:56:11845
VCDS Version: 20.4.1.0
VIN: 3VWEG71K07M156490   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEG71K07M156490   Mileage: 213020km-132364miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 Q    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9650
   Revision: --H01---    Serial number: VWZ7Z0G9050816
   Coding: 0000003
   Shop #: WSC 00999 444 64523
   VCID: 377D92044663C13EFA-8062
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -
                    Fault Status: 01100001
                    Fault Frequency: 23
                    Mileage: 212991 km
                    Time: 00:45:25
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.192 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -  - Intermittent
                    Mileage: 212991 km
                    Time: 00:53:54
                    Temperature: 48.0°C
                    Temperature: 49.0°C
                    Voltage: 6.350 V
001110 - EVAP System
               P0456 - 001 - Very Small Leak Detected
                    Mileage: 213025 km
                    Time: 18:54:58
                    RPM: 1268 /min
                    Load: 18.8 %
                    Speed: 48.0 km/h
                    Temperature: 58.0°C
                    Temperature: 27.0°C
                    Voltage: 14.351 V
Readiness: 0000 1000
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H69000    Serial number:
   Coding: 0000072
   Shop #: WSC 00066 000 00000
   VCID: 000F39D8532D46860B-8054
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 01279 785 00200
   VCID: 73E56614129B6D1E06-8026
   Part No: 1K0 820 047 GS
   Component: Climatic PQ35   120 0606
   VCID: 7BF54E343ACB255E5E-802E
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000610733
   Coding: 14058E234004150007140000001400000008730B5C0000
   VCID: 6BD57E744AABB5DECE-803E
   Component: Wischer 240307 020  0501
   Coding: 00038805
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M01AYZ-
   Coding: 0013889
   VCID: 6CD77D684FA5B2E6C7-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME162E7045A
   Subsystem 3 - Serial number: 6342MSME170D2677F
   Subsystem 4 - Serial number: 6351HSME0C5706300
   Subsystem 5 - Serial number: 6361HSME0C592825B
   Subsystem 6 - Serial number: 63727SME0C380538%
   Subsystem 7 - Serial number: 63827SME0C3566294
   Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
   Component: J0527           056 0101
   Coding: 0000021
   Shop #: WSC 33619 002 1048576
   VCID: 7CF74D283FC5226657-8028
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9050816
   Coding: 0022207
   Shop #: WSC 00066 067 57207
   VCID: 387F91384B7DCE46F3-806C
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 280207F2002663
   Coding: 3FBF034007001002
   VCID: 2F6DAA64BE3309FEA2-807A
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000062078224
   Coding: 0001205
South Molton, UK
That looks like only the first part of the Auto-Scan - the data for module #42 is incomplete and the data for modules #44 to #72 is missing?
pegasus19
hi, im sorry for that, let me copy and paste again the scan,
   Coding: 0000003
               P1643 - 001 -
                    Fault Frequency: 23
                    Mileage: 212991 km
                    Time: 00:45:25
                    Temperature: 19.0°C
                    Temperature: 18.0°C
                    Voltage: 12.192 V
                    Mileage: 212991 km
                    Time: 00:53:54
                    Temperature: 48.0°C
                    Temperature: 49.0°C
                    Voltage: 6.350 V
                    Mileage: 213025 km
                    Time: 18:54:58
                    RPM: 1268 /min
                    Load: 18.8 %
                    Speed: 48.0 km/h
                    Temperature: 58.0°C
                    Temperature: 27.0°C
                    Voltage: 14.351 V
   Coding: 0000072
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Coding: 0013889
   Coding: 0000021
            014 - Defective
   Coding: 0022207
   Coding: 0001205
   VCID: 3B758E347A4BE55E1E-806E
                    Fault Status: 00100101
                    Reset counter: 210
                    Mileage: 213022 km
                    Fault Status: 00111000
                    Reset counter: 212
                    Mileage: 213024 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 3467A50857152A26DF-8060
   Component:    KSG PQ35 RDK 052 0218
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 040735C847355AA62F-8050
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000551378224
   Coding: 0001204
   VCID: 3C778D287F45E26617-8068
                    Fault Status: 01100101
                    Reset counter: 173
                    Mileage: 213022 km
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0017
   Revision: 00014000    Serial number: VWZ4Z7G6233389
   Coding: 0040401
   VCID: 1E3367A0C999907619-804A
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001210080
   Coding: 0001168
   VCID: 3E7387206959F07639-806A
   Component:    RDK              0440
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001233851
   Coding: 0001168
   VCID: 3F8DFA246E53F97E32-806A
End-------------------------(Elapsed Time: 02:09)--------------------------
