Parking 6 sensor to 4 sensor coding advice
BAB090
Mongolia
Hello guys, i am having 2 problems. First the new bumper has 4 parking sensor and old one had 6 sensor is there anyway i can do coding to change the new parkimg system work thus disable paralel parking function just normal ones. And second i cannot do my G85 calibration tried many times even on ODIS steering angle stays zero but on VCDS it shows my current steering angle please advice guys
siLc
Tallinn, Estonia
C?ID=330192
There are tools to cut the missing holes and the sensor mountings are normally available to buy.
Post an autoscan.
BAB090
Mongolia
here is an autoscan please advice on steering angle calibration not done, its got synchronisation failed error
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 82 85 8B 8E 8F 90
          BA
VIN: WUAZZZ4G9EN906203   Mileage: 101316km-62954miles
1B-Active Steering -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560     HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0012
   Revision: NCH62---
   Coding: 122A00326546130A1000
   Shop #: WSC 34556 001 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560 001013
   ROD: EV_ECM40TFS0114G0906560.rod
   VCID: 6582AF4164DAE2AE91-8030
Readiness: 1110 1101
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H18 1007
   Revision: --H18---
   VCID: 71AACB11A0123E0EFD-8024
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 84BF990121FD9980CB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E30202DA1CC917630-806A
0859 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [DSASanityCheck_SteeringAngleCalculation]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:36:57
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 35
                    Uz: B3
0732 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [SCL_QSP_Ist_Moment_Error]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:36:56
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 08
                    Uz: B3
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0551
   Coding: 05A92F06000000000000
   VCID: 7CB4EA25FF5043665E-8028
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 27081400041298
   Coding: 680200B81D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6A98DC7D8DC4CDD6BC-803E
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [009] - Signal Amplitude Too Low
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:43
                    Compressor current: actual value: 0 mA
                    Outside air temperature: 15.5 ∞C
                    Temperature after evaporator: 15.46 ∞C
                    Engine speed: 0 /min
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001924718
   Coding: 0907201009749FF2B98100C7A0001800CF9CC708AE080221800108546F01
   VCID: 6FAECD69BE2628FEEB-803A
   Component: WWS57X 140801  H37 0080
   Serial number:         140808054202
   Coding: 0045F7
   Serial number: 23116056
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 22 08 2014  00000288
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Serial number: 0000002274537R1NV603
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000013111500010000
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000013111500010210
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA108752000008577284
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 8C28C347000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 AH    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0091
   Revision: --------    Serial number: 56231423700295
   Coding: B82B1B
   Shop #: WSC 34447 004 1048576
   ASAM Dataset: EV_EPHVA2CAU57X0000 002012
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 78BCF635C3686F463A-802C
8 Faults Found:
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [009] - Open or Short to Ground
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:36
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [009] - Open or Short to Ground
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:36
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [009] - Open or Short to Ground
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:36
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [009] - Open or Short to Ground
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:36
1111572 - Side Front Left Parking Aid Sensor
          B10F6 14 [009] - Open or Short to Ground
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:39
1112852 - Side Front Right Parking Aid Sensor
          B10FB 14 [009] - Open or Short to Ground
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:39
13637413 - Databus
          [Bremsensteuerger‰t - ESP_01.ESP_Systemstatus - Fehlerspeicher auslesen]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:43
13679386 - Databus
          [Steuerger‰t f¸r Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                    Reset counter: 229
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:28:38
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 281CE67553483FC66A-807C
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:42
                    Control Module temperature: 25 ∞C
                    Voltage terminal 15: 13.913 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
138752 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
          [FAULT_CIS_ADS_SOLL_INIT]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:43
                    Voltage terminal 15: 13.904 V
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:38
                    Control Module temperature: 27 ∞C
                    Voltage terminal 15: 13.883 V
Address 14: Susp. Elect.        Labels: None
   Part No SW: 4G0 907 376     HW: 4G0 907 376 A
   Component: J250 DRC FahrwerH01 0040
   Revision: 00000000    Serial number: 00894015436900
   Coding: 0000000
   Shop #: WSC 27088 001 1048576
   VCID: 6B96D9794A3ED4DEC7-803E
02646 - Plausibility of Level Control System
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:51
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00JZ0JP
   Coding: 30323436313330303339554A304C34473053
   VCID: 3620380D89FC5936E8-8062
   Serial number: 3575HRB40512OKC2E0C%
   Serial number: 3585HRB40512MSOCA9N1
   Serial number: 3515JRB400Q52MR8AQ2V
   Serial number: 3525JRB401652N82AA6K
   Serial number: 3554VRB40084UPLECA21
   Serial number: 3564VRB40084UPLEPGQ2
   Revision: --------    Serial number: 90372NHS00084
   Coding: 0000FD
   VCID: 373E350986F6A03EF3-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 14 07 2014  E0039913
   Part No SW: 4G0 920 931 B    HW: 4G0 920 931 B
   Component: TBenRdwAccNv  H58 0622
   Revision: 29460237    Serial number: 658190814596008
   Coding: 138F110BAFD50008000400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 2502EF41245A22AE51-8070
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001539501
   Coding: 00ED074800
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72A8C41DA514051604-8026
   Serial number: 9824134103
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 14052100000000000255
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 010100
   VCID: 393A3331B0E2B64E05-806C
                    Fault Status: 00100101
                    Reset counter: 229
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:27:34
                    Count: 40
                    Count: 1
                    Hex Value: 0x05CA
                    Hex Value: 0x05CA
                    Hex Value: 0x138D
                    Hex Value: 0x8900
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:27:34
                    Count: 56
                    Count: 1
                    Hex Value: 0x0088
                    Hex Value: 0x891A
                    Hex Value: 0xFFFF
                    Hex Value: 0x0000
                    Reset counter: 229
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:27:34
                    Count: 47
                    Count: 52
                    Hex Value: 0xF234
                    Hex Value: 0x781A
                    Hex Value: 0x00F8
                    Hex Value: 0xC73F
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 002608140001022
0121 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [Steuerger‰t f¸r aktive Lenkung Bitte Fehlerspeicher auslesen  ----------    --- DTC_CAN_SCU_ANGLE_DES]
                    Reset counter: 2
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:42
0122 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [Steuerger‰t f¸r aktive Lenkung Bitte Fehlerspeicher auslesen  ----------    --- DTC_CAN_SCU_ADS_DES]
                    Reset counter: 2
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:42
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [ESP - Steuerger‰t nicht verf¸gbar DTC_FRAY_ESP_SYS_STATE]
                    Reset counter: 2
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:42
0117 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Lenkradwinkelsensor Bitte Fehlerspeicher auslesen  DTC_CAN_LWI_CENTRAL_ERROR]
                    Reset counter: 42
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:27:34
   Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
   Component: KLIMA FOND    H08 0096
   Serial number: 27081400040217
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 3A382C3DBDE4BD560C-806E
   Revision: AA000000    Serial number: 00000114663653
   VCID: 77BEF509C676603E33-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E0157K5
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373E35098EF6A03EF3-8062
   Part No SW: 4G0 907 566 K    HW: 4G0 907 566
   Component: J769  SWA MasterH05 0020
   Revision: 00H05000    Serial number: 6PZ 010 287-09
   Coding: 0000105
   VCID: 373E350946F6A03EF3-8062
   Subsystem 1 - Part No: 4G0 907 568 K
   Component: J770  SWA Slave H05 0020
   Subsystem 2 - Serial number: 6PZ 010 287-29
   Subsystem 3 - Serial number: 5F28.06.1400H05000AMS14766ˇ
   Subsystem 4 - Serial number: S14766ˇ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F1E015E00628002080013
   VCID: 45C24FC1CC1AC2AE71-8010
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0024901731
   Coding: 011101010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 332601199A8E4C1ECF-8066
4205828 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:27:34
                    Write only channel
4208000 - Steering Angle Sensor
          B1168 F1 [008] - Synchronization Failed
                    Reset counter: 229
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:28:38
                    Write only channel
5258753 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [Lenkungsendanschl‰ge nicht angelernt]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:26:57
                    Write only channel
   Revision: 00002001    Serial number: 0344930782
   Coding: 013A0E20A0B97095833009840E0112470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000238065
   Subsystem 2 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO3176199A
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 L    HW: 4G0 947 135
   Serial number: 0000000AP00008651712
   Subsystem 5 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO31761822
   Coding: 801F00
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:45
   Revision: CJ007001    Serial number: 00000000133324
   Coding: 030000
   VCID: 1D72C7A1040AEA6E09-8048
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F1E015E00628002080002
   VCID: 44C452C5C720FBA666-8010
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001174527
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D1217617CAA1AEE99-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140827-0001-030
   Coding: 1122A6601002B300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109H30E7961906
   Coding: 010103010000000001
   VCID: 281CE6755B483FC66A-807C
   Part No SW: 4G0 035 670 M    HW: 4G0 035 670 J
   Component: H-BNT-EU      H53 0814
   Revision: --------    Serial number: 190H30E7595453
   Coding: 070100010303EDEF7DB2CB3E00000003080001000000000000
   VCID: 2D12176174AA1AEE99-8078
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED005CGU6
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NHT000DV
   Component: CD-Database  5950
01524 - Antenna for Telephone
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:54
                    Voltage: 13.80 V
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Component: TSG HL        H03 0507
   Coding: 010F1C004000628002080002
   VCID: 47DE45C9F616D0BE83-8012
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000010197
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A181C7D4D440DD67C-807E
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0171925
   Coding: 0203000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E10106D71AC61F6A0-807A
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 232400058
   Coding: 097205C010
   ROD: EV_HDSGAu571.rod
   VCID: 35223F0194FA522EE1-8060
0114 - Load Space Cover
          B12EF 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:43
                    Voltage terminal 30: 13.94 V
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
   Component: HeadUpDisplay 006 0203
   Coding: C70000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2600E84D595C29B658-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
          U1113 00 [009] - -
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:42
                    Voltage terminal 15: 13.915 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1112 00 [009] - -
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:43
                    Voltage terminal 15: 13.900 V
          U1113 00 [009] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:38
                    Control Module temperature: 26 ∞C
                    Voltage terminal 15: 13.875 V
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120608147
   Coding: 04C0BB1B1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [ESP_ESP_01_Signal_Error]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:43
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 29.0 ∞C
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [QSP_Signal_Error]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:36
                    Outside air temperature: 16.0 ∞C
                    Voltage terminal 15: 13.8 V
                    Control Module temperature: 0.0 ∞C
0173 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [APS_Signal_Error_Master]
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:29:38
                    Control Module temperature: 30.0 ∞C
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 312A0B1160927E0EBD-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 3228041D65944516C4-8066
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97812004095101
   ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 189
                    Mileage: 101316 km
                    Date: 2020.05.30
                    Time: 12:25:45
End----(Elapsed Time: 02:59, VBatt start/end: 14.0V/14.0V. VIgn 0.0V)------
BAB090
Mongolia
Post an autoscan.
Actually the front bumper and parking sensor with wiring harness all has changed. I do have previous parking sensors some of them can i change or add two side ones as you suggested do i need to chamge wiring also?
