Checking that car is coded to battery
callipygian
C?ID=369882
I was watching a video about coding battery to car using VCDS and my barcode only has one of the numbers I see on all the examples and the tab in address 61 im told to go to is greyed out. Im trying to post pictures but I cant find the photo button spoken up in the instructions I found on the site.
callipygian
C?ID=369882
I used a qr scanner on the battery and came up with this
205# 5K0 915 105 D
#0602800
#812798517#03061923
*205 EMC3J631YXK*=
I know 5k0925205d is the part # and believe EMC is the vendor code I just cant figure out the serial #
Santos
What kind of car are you working on? Can you post an autoscan.
Battery type and so on is defined in the Long Coding for your 61-Battery Regul. (J840) module and the Long Coding Helper will show you those details.
I'm not sure whether that module (non-UDS in 2019 :eek:) supports History Data or not. Give it a try please.
callipygian
C?ID=369882
This is the battery.
This is the VCDS with the option grayed out
This is the QR decoded
Ill try the history Data right now and let you know how it turned out.
NEtech
Denmark
C?ID=56995
Battery data should be Address 61, Adaptation Channel 04.
From Coding, you have no Battery sensor, and no Battery history.
callipygian
C?ID=369882
Where would i find the battery serial number, according to the VCDS video on coding battery it should be on the sticker but i dont seem to have it
South Molton, UK
Don't worry about the battery serial number, just change the serial number shown in the #61 by one - the BMS doesn't care about the actual serial number just needs it to be different so it knows it's a new battery.
callipygian
C?ID=369882
Ahhh, ok thx alot
