2010 A4 (B8)Stuck in limp mode
marc.grille
C?ID=315214
Slowing for a stop sign the car sputtered and stalled upon re starting error lights parking break, TMPS, ABS, check engine lights and the car was in limp mode . VCDS scan gave me the following codes.
Address 01: Engine 4698 - Function Restriction due to Faults in Other Modules;
Address 02: Auto Trans (J217) 2505 - Torque Management Feedback Signal A;
Address 03: ABS Brakes (J104) 01314 - Engine Control Module and 00473 - Control Module for Elect. Park/Hand Brake (J540);
Address 17: Instruments (J285) 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent;
Address 53: Parking Brake (J540) 01314 - Engine Control Module ;
Address 56: Radio (J503) 02635 - Tuner Not Enabled/Activated ;
Since these were standard to limp mode I went through the breaks to make sure everything was working and replaced the rear pads and rotors which would have needed to be done in the fall any way. No change
Replaced the ABS module - only change was the Address 17: Instruments (J285) 00473 went away but Address 19: CAN Gateway (J533) 03041 - Energy Management Active 000 - - - Intermittent came on.
Still in limp mode. Any Ideas?
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
          77
VIN: WAUFFAFL3AN056788   Mileage: 219210km-136210miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AA    HW: 8K2 907 115 D
   Component: 2.0l HPA   TF H16 1631
   Revision: E1H16---
   Coding: 0104010A190F0160
   ASAM Dataset: EV_ECM20TFS8K2907115AA A01007
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 6E86C607701F1D9BB17-803A
          U1113 00 [039] - -
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:57:16
                    Engine speed: 847.50 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 18 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 13.358 V
Readiness: 0010 0100
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H05 0009
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3D24314B6DF9B60378D-8068
          P2637 00 [039] - -
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:57:19
                    Engine speed: 825.00 /min
                    Transmission input speed: 762 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 8 °C
                    Accelerator position: 0.0 %
                    Clutch status: 0
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   Shop #: WSC 02391 823 56573
   VCID: 7AAEFA573CD7413B1DF-802E
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 132
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:57:16
                    Hex Value: 0x0000
                    Hex Value: 0x4082
                    Hex Value: 0x0026
                    Hex Value: 0x46A6
                    Hex Value: 0x00FF
                    Reset counter: 132
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:57:17
                    Hex Value: 0x0000
                    Hex Value: 0x6282
                    Hex Value: 0x0032
                    Hex Value: 0x02A5
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0327
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 78AAE05F02DB532B6BB-802C
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H38 0051
   Serial number: 0510000013627016
   Serial number: 0210000022886001
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01050320100075
   Coding: 64002000
   VCID: 005A88BF5A0B1BEB53B-8054
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000481362
   Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
   VCID: 3C223C4F7663BF0B4F3-8068
   Component: WWS 040310  H06 0070
   Serial number: SWF10030046415
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10807181
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002502102133
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GLD0D28MC
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 45D459AB0529FEC320D-8010
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R10000068EN
   Serial number: 6334MSME5024193DA
   Serial number: 6344MSME4E546B2CW
   Serial number: 6352QSME12520424/
   Serial number: 6362QSME1A541D06I
   Serial number: 63732SME78514C1C6
   Serial number: 63832SME5A542B082
   Revision: --------    Serial number: 90304JC2000J0
   Coding: 000016
   VCID: 3D24314B6D79B60378D-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
   Component: KOMBIINSTR.   H20 0255
   Revision: 00200000    Serial number: CIM24J13A
   Coding: 8B1609000300D705020000
   VCID: 313C1D7BA1214263EC5-8064
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0116
   Revision: GB700052    Serial number: 5200G102268132
   Coding: 00C303
   VCID: 015C8DBB510112E35C5-8054
   Component: J367-BDM  H07 0170
   Serial number: 1000CB92030310
                    Reset counter: 172
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:55:44
                    Bin. Bits:    10111
                    Voltage: 11.30 V
                    Count: 6
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0280
   Revision: 00000000
   Coding: 020302
   VCID: 392C255B79518A23545-806C
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010216830
   Coding: 011C03204000410001
   VCID: 45D459AB05A9FEC320D-8010
   Revision: 00002001    Serial number: 0127676103
   Coding: 0106023A007A440400B0013200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000229755
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS037  H06 0041
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010102
   VCID: 74B2D46F1EB3374B473-8020
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000010236879
   VCID: 44D244AF0E93C7CB373-8010
   Revision: 00000003    Serial number: 00000000581433
   VCID: 3432146F5E33774B873-8060
                    Fault Status: 11101101
                    Reset counter: 132
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:57:17
                    Voltage: 13.40 V
                    Count: 58
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77A8E36303C55C53621-8022
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000008    Serial number: AUZ5Z6J1365488
   Coding: 04020002010185004359070800
   VCID: 46D65EA738AFF5DB297-8012
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Reset counter: 132
                    Mileage: 219213 km
                    Date: 2009.08.15
                    Time: 13:55:24
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000103064620
   Coding: 010C03204000210001
   VCID: 42DE42B71487C9FB05F-8016
   Revision:             Serial number: 0000103064617
   Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
   Component: FSE_256x BT     H39 0600
   Revision: 00000000    Serial number: 00000005072847
   Coding: 0010370
   Shop #: WSC 02156 785 00200
   VCID: 3C223C4F7A63BF0B4F3-8068
End----(Elapsed Time: 01:42, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)
Jef
HQ
Not sure but it seems that maybe there was a communication issue between the ECM and TCM. For giggles, I'd unplug both the ECM and TCM and verify connections are clean/dry/shiny as a starting point.
marc.grille
C?ID=315214
Thanks for the input I will give that a try. I am thinking it is a communication issue as well. I can clear the DTCs it will run fine for about 20 seconds then sputter like a bad misfire and stall. Restart and I am back to limp mode and the same DTCs. I have read where the Parking Brake switch can function engaging and disengaging the parking brake but still be bad. I do have a switch on order, but any suggestions on VCDS approach to looking for that type of issue?
This has been the first time I have had to get this deep into VCDS to determine a problem, auto scan has always told me all I needed to know.
I have done modifications: IE sport head , block and intercooler ; HPA K04, Intake manifold, down pipe and tune; ECS cold air intake. 2 yrs and 30k ago . So I have looked at the advanced measurement features but as the HPA tune functioned so well I never looked much further. Just the little I have been getting to know what the program is capable of wow I guess I have made it to the second step of your sign off "Auto Scan, learn it ..." and while I am not to the "love it" stage yet I can see it happening. Being an old car guy I all ready checked the fuses.
