MK60EC1 ABS LONG CODING HELP
Golftwincharged
Guyana
C?ID=320847
Hey Guys may i have some assistance with the coding for this car, please find attached autoscan
VIN: WAUZZZ8P9CA121107   License Plate:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 47 52 55 61 62 72
VIN: WAUZZZ8P9CA121107   Mileage: 18850km-11712miles
Address 01: Engine (CAX)       Labels: None
   Part No SW: 03C 906 016 CP    HW: 03C 906 016 S
   Component: MED17.5.5        01 0915
   Revision: L5H15---    Serial number: AUX7Z0L0FNO03I
   Coding: 0000077
   Shop #: WSC 06314 000 00000
   VCID: 6FE7FEBA7ED994374C-803A
               U1017 - 000 -
                    Mileage: 18826 km
                    Date: 2020.05.25
                    Time: 21:30:45
                    RPM: 860 /min
                    Load: 28.2 %
                    Temperature: 57.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
005241 - Brake Boost Vacuum System
               P1479 - 000 - Mechanical Failure - Intermittent
                    Fault Frequency: 14
                    Mileage: 18842 km
                    Date: 2020.05.26
                    Time: 01:08:52
                    RPM: 2660 /min
                    Load: 38.0 %
                    Speed: 18.0 km/h
                    Temperature: 93.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
Readiness: 0010 0101
   Part No SW: 0AM 300 060 D    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5227
   Revision: 00043014    Serial number: CU501201125167
   Shop #: WSC 55506 001 1048576
   VCID: 2B5F2AAA8A41A81720-807E
   Revision: 00H31001
   Shop #: WSC 44110 000 1048576
   VCID: 7BFFDAEAFAA1F897F0-802E
03306 - Coding Not Valid
                    Reset counter: 227
                    Mileage: 18856 km
                    Date: 2020.05.26
                    Time: 01:54:53
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 4161
                    Count: 49920
                    Count: 256
                    Count: 256
                    Reset counter: 227
                    Date: 2020.05.26
                    Time: 01:44:55
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 49920
                    Count: 256
                    Count: 256
                    Fault Status: 01100101
                    Reset counter: 227
                    Mileage: 18856 km
                    Date: 2020.05.26
                    Time: 01:44:43
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 279
                    Count: 49664
                    Count: 256
                    Count: 65280
                    Count: 256
                    Reset counter: 227
                    Mileage: 18856 km
                    Date: 2020.05.26
                    Time: 01:44:43
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 295
                    Count: 49664
                    Count: 256
                    Count: 65280
                    Count: 256
                    Reset counter: 227
                    Mileage: 18856 km
                    Date: 2020.05.26
                    Time: 01:44:43
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 270
                    Count: 49664
                    Count: 256
                    Count: 65280
                    Count: 256
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0180
   Revision: 000251      Serial number: 8P0820043BN
   VCID: 79F3C0E2309DCA87E2-802C
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0667
   Revision: AJ110667
   Coding: 46000A2FA0051AC0207040E001000914427E2BAA206DD92A64008F840041
   VCID: 4281670EDDCB495FF3-8016
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
                    Reset counter: 224
                    Mileage: 18822 km
                    Date: 2020.05.25
                    Time: 00:33:48
                    Voltage: 14.30 V
                        Term 50 On
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 18822 km
                    Date: 2020.05.25
                    Time: 00:38:06
                    Voltage: 14.35 V
                        Term 50 On
03545 - Right Brake Light Lamp 2
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 18822 km
                    Date: 2020.05.25
                    Time: 00:38:06
                    Voltage: 14.35 V
                        Term 50 On
                    Fault Status: 00101010
                    Reset counter: 12
                    Mileage: 18826 km
                    Date: 2020.05.25
                    Time: 23:03:07
                    Voltage: 14.30 V
                        Term 50 On
                    Reset counter: 12
                    Mileage: 18835 km
                    Date: 2020.05.26
                    Time: 00:56:24
                    Voltage: 14.20 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0140
   Revision: 11001001    Serial number: 12561202101960
   Coding: 000303
   VCID: 49937022E0FD9A0732-801C
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
   Component: Airbag AU1042 H10 0250
   Revision: --------    Serial number: 003JU005VRG2
   Coding: 30314238303830303038554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 52A1574E05ABD9DF43-8006
   Serial number: 3572DRB40000E4B0BAE7
   Serial number: 3582DRB40000E4B49A51
   Serial number: 35128RB40000685390DJ
   Serial number: 35228RB400006853E26K
   Serial number: 35547RB4000068AA4F2Z
   Serial number: 35647RB4000068AA487Y
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H38 0070
   Coding: 0012012
   VCID: 46897B1E31E3757FDF-8012
   Component: E0221           H02 0100
01304 - Radio
   Part No SW: 8P0 920 932 Q    HW: 8P0 920 932 Q
   Component: KOMBIINSTR. VDO H03 0150
   Revision: D0H03002    Serial number: 2240L002044245
   Coding: 0256928
   Shop #: WSC 00000 011 2053004
   VCID: 4281670E1DCB495FF3-8016
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 170112F2000973
   Coding: 352103
   VCID: 3B7F1AEABA213897B0-806E
   Revision: D0H03002    Serial number: AUX7Z0L0FNO03I
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
   Component: Tuer-SG         H04 0101
   Coding: 0135860
   VCID: 489575263BF7630F2D-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 232    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 377706DA46091CF754-8062
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158128931780
   VCID: 36690BDE4103E5FF4F-8062
   Part No SW: 8P0 959 802 P    HW: 8P0 959 802 P
   Coding: 0135860
   VCID: 4993702220FD9A0732-801C
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0012
   Serial number: 120116-0002-130
   Coding: 1163951010002100
   ROD: EV_HeadlRegulBasic.rod
   VCID: 4281670ED5CB495FF3-8016
0094 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 223
                    Mileage: 18822 km
                    Date: 2020.05.25
                    Time: 00:34:17
   Component: Batt.regelung H43 1623
   Coding: F32F1864
   VCID: 71E3F8C2A8ED82C75A-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900695228
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131216
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131216
   VCID: 438F620A02D14057F8-8016
End-------------------------(Elapsed Time: 02:45)--------------------------
