VW CRAFTER Oil level too high after 60 mins driving
Redmoor
C?ID=402037
Hi All,
Long story short, new injectors fitted to this van solved issue with oil level rising.
However, I still get a warning on the display after about 60 mins driving - Oil level too high.
When the van is cold I dont get any error. Oil is 3/4 full on dip stick.
Did a log of some data that looks like it would be relevant, I have 2 crafters so I can compare...they look very similar.
Good van = no warning
Bad van (scan below) = warning
This scan is after driving the bad van so oil temp is high and van is giving the oil too high warning - good van is cold start so not a direct comparison.
Oil fill level mm
Good van : 76.856
Bad Van : 69.216
Oil warning threshold : (I assume low oil level)
Good Van : 50.216
Bad Van : 48.9
Engine oil temperature C :
Good Van : 18.8
Bad Van : 61.5
Oil level: last valid dynamic value (not sure what this is)
Good Van : 19.436
Bad Van : 17.812
Oil level: dynamic average value
Good Van : 131.068
Bad Van : 131.068
Anyone have any ideas as what to try/test?
Many thanks
Mike
Tuesday,28,April,2020,10:54:54:38732
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4524.4
VIN: WV1ZZZ2EZF6031449   License Plate: 15
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 A    HW: 03L 906 012 A
   Component: R4 2.0l TDI   H26 9977
   Revision: 72H26---    Serial number: VWXDZ0O1001354
   Coding: 0119401020440C080000
   ASAM Dataset: EV_ECM20TDI01103L906012A 002016
   ROD: EV_ECM20TDI01103L906012A_002.rod
   VCID: 221C1369C44685DB65F-8076
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 C    HW: 906 900 590 2
   Component: IMMO          1231  1322
   Revision: 00231000    Serial number: VWXDZ0O1001354
   VCID: 270A027DA3E460F3321-8072
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F678B5C588226350D-8000
Address 95: LT3 ESP
   Part No HW: 0009013202
   Serial number: 000901320210851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069026601    HW: 9069014501
   ASAM Dataset: 32 1056
   ROD: CRFT_KOMBI_32_1056.rod
   VCID: 074A62FD4FA440F3121-8052
Address 99: LT3 Ign. Switch
   Part No HW: 9069005902
   ASAM Dataset: 67 259
   ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        1231  1322
   Revision: 00231000    Serial number: 12345678901234
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9069000501
   ASAM Dataset: 33 263
   ROD: CRFT_FTUHR_33_263.rod
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA20E0D036C1413069-802E
Address B4: LT3 Central Elec.
   Part No SW: 9069024301    HW: 9069017501
   ASAM Dataset: 33 852
   ROD: CRFT_EZE_33_851.rod (*)
   VCID: 025C73E9648665DB45F-8056
90C1 - Emergency light activated; rotary light switch: implausible condition
            Test Complete - Stored
Address B6: LT3 Steering Wheel
   Part No SW: 9065402545    HW: 9065402545
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 084861C142BA4F8B1BB-805C
End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/14.2V)-----------
Tuesday,28,April,2020,11:08:06:38732
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
   ASAM Dataset: 21 3
End----------(Elapsed Time: 01:08, VBatt start/end: 12.7V/12.7V)-----------
Thursday,28,May,2020,16:38:34:38732
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
9100 - Drivetrain CAN: No communication
   ASAM Dataset: 21 3
End----------(Elapsed Time: 00:53, VBatt start/end: 12.7V/12.7V)-----------
