vw crafter van unable to access security to do DPF UK
fenderjazz
C?ID=400400
Chassis Type: 2F (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
VIN: WV1ZZZ2FZA7007031
Address 91: LT3 Engine        Labels: Redir Fail!
   Part No SW: 076 906 022 P    HW: 076 906 022 G
   Component: R5 2,5L EDC A020SG  9022
   Revision: 24H34---    Serial number: VWXDZ0J1011348
   Coding: 0003032
   Shop #: WSC 60259 001 1048576
   VCID: 2019E65FE6C8BFCB73B-8074
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Voltage: 13.91 V
                    Absolute Pres.: 0.0 mbar
                    Torque: 0.0 Nm
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serial number: VWXDZ0J1011348
   VCID: 6D87CF6B619AA2A388D-8038
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00118 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F7878BE58A0A6350D-8000
Address 95: LT3 ESP
   Part No SW: 9069022800    HW: 0004460153
   ASAM Dataset: 3 4101
   ROD: CRFT_ESP_3_36946.rod (*)
   VCID: 04518ACF5E9043EB773-8050
4296 - Voltage supply: Open circuit
            MIL ON - Test Complete - Stored
4283 - Voltage supply: Lower limit not reached
Address 96: LT3 Instruments
   Part No SW: 9069026400    HW: 9069012000
   ASAM Dataset: 32 787
   ROD: CRFT_KOMBI_32_787.rod
Address 99: LT3 Ign. Switch
   Part No HW: 9065455808
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
9001 - Voltage: Lower limit not reached
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serial number: 12345678901234
   Shop #: WSC 53558 001 1048576
00172 - Key 2 not learned
            002 - Lower Limit Exceeded
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
9021 - Voltage: Lower limit not reached
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3F133236E3C13069-802E
9090 - Interior monitoring: Data wire short circuit
            Test Complete - Active/Stored
Address B1: LT3 Upper Console
   Part No HW: 9065453907
   ASAM Dataset: 67 3
   ROD: CRFT1_OBF_67_3.rod (*)
9036 - Supply voltage: Limit value exceeded
9021 - Instrument Cluster Control Module (J285): No communication
Address B4: LT3 Central Elec.
   Part No SW: 9064420700    HW: 9065453601
   ASAM Dataset: 33 260
   ROD: CRFT_EZE_33_260.rod (*)
90A6 - Fuel level sensor: Short to Plus
9021 - Bulb for Right Taillamp (M2): Short to GND
9036 - Bulb for right brake light (M10): Short to GND
9039 - Back-up lights: Short to GND
9093 - Voltage: Lower limit not reached
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 065590C768AC71FB697-8052
End----------(Elapsed Time: 01:15, VBatt start/end: 12.6V/12.5V)-----------
fenderjazz
C?ID=400400
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ2FZA7007031 License Plate:
Mileage: Repair Order: egr
Mode 03: Emission related fault codes
Address 7E8: 3 Faults Found:
P2BAD - NOx Emissions Exceeded: Unknown Cause
P2BAB - NOx Emissions Exceeded: Incorrect EGR Flow
P2BAC - NOx Emissions Exceeded: Deactivation of EGR
fenderjazz
C?ID=400400
EGR ERROR CODES VW CRAFTER VAN UK
:confused: None of these faults indicate a problem with the DPF.
PS: Threads merged.
