Audi tt power steering angle fault
Radiosolutions
C?ID=178437
could someone help with this fault. abs light and steering yellow light. steering is stiff. faults for steering angle in abs. i have done steering angle reset and it programs sucessfull, but fault remains. i have changed steering angle sensor, steering module and abs module and ignition switch. i have done numerous attempts to program angle sensor while driving following all instructions from rosstech, but fault exists. all fuses checked and all part numbers checked with audi. can anyone help with this fault please. ignore radio faults is missing and airbag faults because been stripped to change parts.scan attached
Wednesday,06,May,2020,13:39:39:28694
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: autoelec
VIN: TRUZZZ8J181024074   License Plate: HG57OOX
Mileage: 240210km-149259mi   Repair Order: AUDI TT
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: TRUZZZ8J181024074   Mileage: 240210km-149259miles
   Part No SW: 8J0 907 115 N    HW: 8J0 907 115
   Revision: 5BH16---    Serial number: AUX7Z0G8FNE0NN
   Coding: 0113000318070060
   Shop #: WSC 01236 785 00200
   VCID: 372B2CB3B34A85DF38D-8062
Readiness: 0110 0001
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517     HW: 8J0 614 517
   Component: ESP MK60E1          0130
   Revision: 00H52001
   Coding: 0017424
   Shop #: WSC 01236 758 00200
   VCID: 6A8DC5C7B078E837773-803E
                    Reset counter: 48
                    Mileage: 240211 km
                    Date: 2020.02.22
                    Time: 03:20:15
                    Count: 192
                    Count: 12545
                    Count: 297
                    Count: 47616
   Part No SW: 8J0 820 043 AF    HW: 8J0 820 043 AF
   Component: J255  Klima 1 Zone  0080
   Revision: 00H07004    Serial number: 00000001061493
   Coding: 1573892
01273 - Fresh Air Blower (V2)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 48
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:08:15
                    Temperature: 11.0°C
                    (no units): 210.0
                    (no units): 230.0
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000007652611
   Coding: 01040E8280141C00471800001800000000085E075C210802000000000000
   VCID: 45D7567BF9A6E74FBA1-8010
   Subsystem 1 - Part No: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H08 0060
   Coding: 00064784
   Shop #: WSC 01236
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Reset counter: 48
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:08:00
                    Voltage: 11.50 V
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -t Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K001Y6C$
   Coding: 0011636
   VCID: 79AFEA8BC5DE53AF8E9-802C
   Subsystem 1 - Serial number: 6332DRB405D48995-
   Subsystem 2 - Serial number: 6342DRB405C9D091X
   Subsystem 3 - Serial number: 63747RB402E9BD91%
                    Fault Status: 11100001
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:08:22
01587 - Igniter 2 for Airbag; Drivers Side (N250)
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:08:22
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 48
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:08:24
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Fault Status: 11101010
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:17:06
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:17:06
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0000011
   Shop #: WSC 01236 551 00000
   VCID: 41DF426BED8ECB6F869-8014
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 980 E    HW: 8J0 920 980 E
   Component: KOMBIINSTR. VDO H22 0130
   Revision: D0H22001    Serial number: 2248G001007064
   Coding: 0004428
   Shop #: WSC 01223 210 00003
   VCID: 333318A3A73269FF045-8066
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K079128355
   Coding: E9801F061002024101
   VCID: 303917AF562452E7797-8064
01304 - Radio
                    Reset counter: 48
                    Mileage: 240206 km
                    Date: 2020.02.22
                    Time: 00:08:33
   Revision: D0H22001    Serial number: AUX7Z0G8FNE0NN
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 8J8 959 801 C
   Component: Tuer-SG         H02 0060
   Coding: 0000565
   VCID: 3D273E9B9176AF8FE21-8068
   Part No: 8J2 909 143 C
   Component: EPS_ZFLS Kl.157 H08 1903
   Shop #: WSC 42176 002 1048576
   VCID: 313F12AB5D2E5BEF769-8064
02546 - Steering Limit Stop
                    Mileage: 240200 km
                    Temperature: 46.0°C
                    Voltage: 11.70 V
                    Voltage: 11.50 V
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433 B
   Component:    KSG          H11 0080
   Coding: 9890322201183F3F8505488AD437
   Shop #: WSC 56823 003 1048576
   VCID: 353726BBA94677CF2A1-8060
   Subsystem 2 - Component: DWA-Sens. No Answer
03156 - Sensor for Anti-Theft System (G578)
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 B    HW: 8J0 035 223 B
   Component: J525 Amp Std    H03 0120
   Revision: 00H03001    Serial number: 93802003627406
   Coding: 0106117
   VCID: 2313E8E317D2F97FF45-8076
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 8J8 959 802 C
   Coding: 0000565
   VCID: 3E2539979C70B497FBB-806A
Address 56: Radio
End----(Elapsed Time: 01:04, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, where did you carry out the basic setting, in address 03 or 44? If I am not mistaken, the steering angle sensor is part of the steering, so address 44 if it is a generation "3" steering.
DrPeter
16.4905° S, 151.7375° W
If the G85-Steering Angle Sensor is loosing 30-power intermittently, the fault code [01826] is stored and the ESP/TCS warning is displayed.
As long as the ABS wheel speed sensors are functioning correctly (see Measuring Value Block group 001), typically a short test drive will re-initialize the G85 sensor and it can be calibrated with the Basic Settings.
I would suggest to check the Measuring Value Block group (007) in the [44-Steering Assist] controller, the following information should be seen:
MVB-007 (Key on, engine running while moving the steering wheel)
Field (1) Steering Angle Sensor (G85) = Typically should read the actual sensor's value in (°) [Check the 'lock-to-lock' readings, should be equal from 0°]
Field (3) Calibration Status (G85) = "Yes" or "No"
Field (4) Initialization Status = "SteerAng Init" or "SteerAng n.Init"
You should be able to successfully perform the Basic Settings of the G85 when field (1) is active and field (3) says "SteerAng Init". During a 'parking lot' road test, have someone monitor MVB-007, it may show something, like the G85 stops reading, etc...
I would also suggest to check the power and ground to the J527-Steering Column Control Module, along with the connections of the G85 sensor.
Official Factory Repair Information
ps.. There are two different J527 controllers as per the www.PartsLink24.com and based on the VIN / build date, you should be using [8P0 953 549 F]. The G85 is a [1K0 959 654], both are for vehicles up to (25,05,2009) build dates.
Hope this helps,
drpeter
