DPF Regeneration.
Ronnie.Vincent
C?ID=389395
Skoda Octavia 2.0Tdi 140 CR. 2012
Posted previously about problems with DPF Regeneration and still trying to sort out the issue. However going back to having work done on the turbo plus a new Lambda Sensor and a new Pressure Sensor did a bit rooting around and found this about a G450 Pressure Sensor?
https://forums.ross-tech.com/showthread.php?7711-Adapting-G450-pressure-sensor
Called the garage, unfortunately the guy I needed is not available at the moment but the one I spoke with about 'logging it to the ECU' reckoned they didn't need it so probably not done.
So my question is, does it need setting up on the ECU and if so how? Is it similar to the thread mentioned?
Ronnie.Vincent
C?ID=389395
Hi Uwe, thanks. Even though it's been fitted and ran can it still be logged into the ECU? An different post about the Pressure Sensor said it was a 'One Time Only' and if it was ran would 'adopt' the previous settings?
Also here is a 'snapshot' from a scan on the vehicle, does this give any indication of the ECU fitted?
Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 C HW: 03L 906 018 BR
Component: R4 2.0l TDI H24 9978
Revision: 42H24--- Serial number:
Coding: 00190012042500080000
Shop #: WSC 22007 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018C 003008
ROD: EV_ECM20TDI01103L906018C.rod
VCID: 2A0D056D4C7D279B2D6-807E
Gone But Not Forgotten
Firmware update needed 9981 or higher?
That looks like this car, and if so, I'd want to make sure the cause of the EGR fault codes was resolved because the DPF system may not regen properly while driving.
In regards to Jack's research - I came up with SWL 9981 as well but I wasn't able to locate the RoW market Skoda TPI number. If you happen to have that EDC flash updated on the dealer level please ask them to put the TPI number or SVM code on your repair order so you can pass that along to us.
As far as the new DPF pressure sensor is concerned, that appears to be Basic Setting:
[*IDE01772*] Adaptation of diff. pressure sensor particulate filter
If that alone doesn't reset the Advanced Measuring Values you may also want to try BS:
[*IDE00468*] Resetting of learned values of difference pressure sensor
If you need further assistance please post the Auto-Scan and a pair of Measuring block function maps for review. I believe a Key On, Engine Off map -and- another map with the engine running at Idle would be best.
Ronnie.Vincent
C?ID=389395
Hi, I have posted before about this issue but things have moved on so it is a little different now. 2012 Skoda Octavia 2.0 Tdi CR Engine Code CFHC.
I appear to have rectified other faults that showed up originally with the EGR and partly with the DPF.
Having 'chemically' cleaned out the DPF with the JLM 2 stage process which did have the desired effect in that it removed ash and soot as expected. Checked and reset all the values, filled with Shell Diesel and threw in a bottle of Forte additive, just for good measure. Took the car out for a very long drive, around 1h30m for about 120 miles. As constant speed as possible, 4th gear, 60 mph at 2500rpm. No EML, No flashing Glow Plug Light and No Particulate Filter Light and no smoke of any kind from the exhaust.
Couple of days later, Diesel Particulate Filter Light comes on and if ticking over or low speeds around town smoke appears on pulling away. Ran a scan with VCDS which showed no other fault registered so not looking at EGR or (currently) at any faulty sensors. Tried a 'Service Regeneration' after taking it for a run out to get up to temperature and that did the same as it always has, kicks in, revs increase but soot content increases. I therefore took it out to the 'fast' road near where I live with the intention doing a regeneration when driving. However, firstly, when I pulled to set it up the car was running at fast tick over, around 1000 rpm, so I looked at the figures on the screen and the soot content was reducing so it was obviously attempting some form of regeneration. It got to around 15g and stopped reducing so tried to set up the driving regeneration but could not get that set up because the VCDS process was not as set out. To start with, Coding-II - 11 was 'greyed out and could not access it which was ok because i have the later CR engine. Entered the security code and then into Adaptation - 10, selected the Regeneration while driving, the values were both shown as 0 so entered the 'new value' 1 but VCDS came up with a screen asking yes or no to either using the value, using a default value or a value supplied? I tried using 1 & 2 as obviously I have no values available but it would not "Do It" and if I went back the Meas. Blocks 08 was greyed out so could not get into that.
So, I took it up the road and after around 15 miles the EML light came on and the Glow Plug Light came on and it went into limp mode. Pulled off, checked the fault code, P2458 Regeneration Not Completed in Time.
The one thing I have found is the exhaust temperature readings appear to be a bit on the low side?
Address 01: Engine (03L 906 018 C)
13:14:24
IDE00433 Particle filter: oil ash volume 0.00 l
IDE00434 Particle filter: soot mass calculated 11.48 g
IDE00435 Particle filter: soot mass measured 26.00 g
IDE02229 Exh.gas temp.sen 1 287.5 °C
IDE02233 Exh.gas temp.sen 2 -0.0 °C
IDE02234 Exh.gas temp.sen 3 133.6 °C
IDE02236 Exh.gas temp.sen 4 137.3 °C
I am wondering if when trying to regenerate it is injecting more diesel in for combustion but because the exhaust sensors are reading low it is not burning correctly and hence creating excess soot or the DPF not being able to regenerate correctly? You can see the soot has climbed from around the 15g it had got down to up to 26g.
fenderjazz
C?ID=400400
Hi your car has to have exhaust over 200 before regeneration make sure you give it a blast and air con is running too along with lights on
you should get good results
Ronnie.Vincent
C?ID=389395
**UPDATE**UPDATE
Though I would update the forum on where I am at with my DPF issues!
These came about after having a replacement Turbo & Throttle Body fitted. All was well initially but after a couple of days things started to go wrong. Took it back to the garage, they did another re-generation but the problems returned very quickly. After many 'tests and fixes' with things still not right went back to basics and the start again. Checked the logging of the Throttle Body, Chemically cleaned the DPF using the JML 2 stage system, ran 2 cans of Wynn's Professional EGR Cleaner through the intake system, reset the values of the Oxygen Sensor and DPF Pressure Sensor (as the garage had changed them) and then having 'cleaned' the DPF rest the learned value for a 'Adaption of Carbon Mass' as per the Wiki. After doing that ran a 'Service Re-Generation' through Basic Settings which took around 40 minutes but finally No EML on, No DPF Filter Light On, No 'flashing' Glow Plug Light (other than when the Re-generation was running), good readings for the Soot Levels & Ash Levels with no recorded faults on anything on the Auto Scan so hopefully good for a while?
Sunday,05,July,2020,14:12:20:08428
VIN: TMBGE21Z7C2140161   License Plate: YR12FEP
Mileage: 312850km-194395mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBGE21Z7C2140161   Mileage: 312850km-194395miles
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 73430 790 00083
   VCID: 7BA3F029FFE76E13060-802E
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CA1F335F669692B0FA-8028
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 48000AB8A05BB1C04010008011000124430000AE726D81605C8440000040
   VCID: 3FDB4439A77FB2336A8-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 26011  26  0601
   Coding: 00D7B7
   Component: RLS 300112 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901202501608
   Coding: 10800E
   Shop #: WSC 13765 790 00083
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 333318099BB766539E0-8066
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2UUYT2
   Coding: 0020788
   VCID: 3D273E31A173A023784-8068
   Subsystem 1 - Serial number: 6332MSME6B037507A
   Subsystem 2 - Serial number: 6342MSME69630C12B
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   015 0140
   Revision: FF010040    Serial number: 20120126801141
   Coding: 5080140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 77ABEC19CF4F4A73628-8022
   Part No SW: 1Z0 920 903 SX    HW: 1Z0 920 903 SX
   Component: KOMBI         H06 0608
   Coding: 410A00
   Shop #: WSC 39206 001 1048576
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 1D67DEB10D33C023584-8048
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 220112F2003030
   Coding: 352303
   VCID: 3A2D352DBC5D971B5D6-806E
   Component: IMMO          H06 0608
   VCID: 6A8DC56D8CFDE79BED6-803E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0000758
   VCID: 76B5E11DC4C5337B79E-8022
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 372B2C19834F8A73A28-8062
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000758
   VCID: 48C95FE5FEB1F58BDB2-801C
   Part No SW: 1Z0 035 156 M    HW: 1Z0 035 156 M
   Component: BOLERO        001 0008
   Revision: -----08S    Serial number: SKZ4Z3M1106732
   Coding: 0D0004000001
   VCID: 3C213335B669A92B4FA-8068
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012563
   VCID: 323D1D0D682D6F5B956-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331809973766539E0-8066
End----------(Elapsed Time: 01:02, VBatt start/end: 12.5V/12.4V)-----------
Address 01,03L 906 018 C,channel IDE00275-Particle filter initialization,adapted from,0 Tkm,to,1 Tkm,
Sunday,05,July,2020,15:05:00:08428
Mileage: 194396   Repair Order:
15:04:34
  IDE00432   Particle filter: time since last regeneration 2831 s
  IDE00434   Particle filter: soot mass calculated 0.79 g
  IDE00435   Particle filter: soot mass measured 0.38 g
  IDE00436   Particle filter: kilometers since last regeneration 0 m
Ronnie.Vincent
C?ID=389395
Hi, I am still having DPF issues with my 2012 Octavia II 2.0 CR but think I may have narrowed it down now. I believe when the new turbo was fitted along with a Throttle Body, Lambda Sensor and DPF Pressure Sensor the new DPF Pressure Sensor was not adapted as is required and it still thinks it is clogged and continually tries a passive regeneration and smokes a bit! I intend to buy a new unit from the dealer on Monday, fit it and code it in with my VCDS. I know the procedure may have been posted at some time on here, or another forum, but can anybody provide me a step by step guide or point me to the previous posting?
Three threads merged.
If you're going to ask about the same issues in the same car, please find your previous thread(s) about them rather than opening several new ones.
Ronnie.Vincent
C?ID=389395
So, the saga continues. Still have issues but with no fault codes showing, no EML and not going into limp mode keep trying different things to cure the problem. I don't think the DPF is blocked despite the DPF light coming on eventually after trying something different. Having run an exhaust back pressure test which showed 0 on tick over and very little change at 2000 rpm along with the car driving perfectly. New scan today, still no fault codes showing although I did do some 'playing around' with various other functions on VCDS to see what showed up. One is at the top of the scan through the OBD11 Mode 01 PID 01 Address 7E8 which showed up the failed / incomplete Oxygen sensor issue (which was in red on the screen). I don't know if this is recent or from the fitting of the replacement turbo at the start of they year as this is the first time I have found this. The second one is at the bottom of the scan showing the various temperature readings which I think are all on the low side and the reading for the EGR after cooler if my school science beckons and remember correctly, -270.6C is absolute zero? Can anybody explain that reading.
In addition I did yet another Service Regeneration which ran perfectly right up to the point when calculated and measured soot values reached 0.2g & 0.3g then the engine note changed and the soot contents for both started to rise again!
I would welcome any ideas as to what component to test / check / replace next!
VIN: TMBGE21Z7C2140161   License Plate: YR12 FEP
Mileage: 194700   Repair Order:
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring: Not installed.
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring: Not installed.
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Not installed.
Secondary air system monitoring:  Failed or Incomplete
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring:  Failed or Incomplete
Exhaust Gas Recirculation:  Failed or Incomplete
VIN: TMBGE21Z7C2140161   Mileage: 313340km-194700miles
   VCID: 2A0D056D4C7D279B2C7-807E
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BA3F029FFE76E13071-802E
   Revision: 00001007
   Coding: 0000000002
   VCID: 7CA1F335F669692B0EB-8028
   Revision: 00110 AC
   VCID: 3FDB4439A77FB2336B9-806A
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 10800E
   VCID: 333318099BB766539F1-8066
   Coding: 0020788
   VCID: 3D273E31A173A023795-8068
   Coding: 5080140000
   VCID: 77ABEC19CF4F4A73639-8022
   Coding: 410A00
   VCID: 1D67DEB10D33C023595-8048
   Coding: 352303
   VCID: 3A2D352DBC5D971B5C7-806E
   VCID: 6A8DC56D8CFDE79BEC7-803E
   Coding: 0000758
   VCID: 76B5E11DC4C5337B78F-8022
   Revision: 00H22000
   VCID: 372B2C19834F8A73A39-8062
   Coding: 0000758
   VCID: 48C95FE5FEB1F58BDA3-801C
   VCID: 3C213335B669A92B4EB-8068
   Coding: 0000144
   VCID: 323D1D0D682D6F5B947-8066
   Coding: 0000144
   VCID: 33331809973766539F1-8066
End----------(Elapsed Time: 01:01, VBatt start/end: 13.7V/13.7V)-----------
Thursday,15,October,2020,15:31:44:08428
15:31:22
  IDE00025   Coolant temperature 79 °C
  IDE00192   Coolant temperature at radiator outlet: actual value 65.4 °C
  IDE00194   Coolant temperature at radiator output: specified value 80.0 °C
  IDE01361   exh.gas recirc. (EGR) cooler pump: specified value 95.00 %
  IDE02229   Exh.gas temp.sen 1 139.6 °C
  IDE02234   Exh.gas temp.sen 3 96.2 °C
  IDE02236   Exh.gas temp.sen 4 127.5 °C
  IDE04255   Temp sensor for EGR after cooler: raw value -270.6 °C
