Hello everyone,
First post for a problem with my Son's 2008 Rabbit. The instrument cluster lit-up like a Christmas tree with multiple lights on the first drive after sitting for a few weeks. The yellow steering wheel, ABS, and BRAKE lights are on along with the engine symbol. I replaced the L/F wheel speed sensor with no change to the faults. We're suspecting the ABS module, but are not sure. Thanks so much for the assistance!
Monday,25,May,2020,12:42:49:29292
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWAA71K28W063426 License Plate:
Mileage: 215450km-133874mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K28W063426 Mileage: 215450km-133874miles
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BK HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1568
Revision: 1NH01--- Serial number: VWX7Z0G63N68KH
Coding: 0000001
Shop #: WSC 01279 785 00200
VCID: 73B3DA9637B20E535E9-8026
049441 - No Communication with ABS Brake Control Module
U0121 - 008 -
Fault Status: 01101000
Mileage: 215457 km
Time: 00:07:25
Temperature: 73.0∞C
Temperature: 23.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 12.192 V
Readiness: 0110 1101
Address 03: ABS Brakes
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6E85CBE25C9023BBB17-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007253474
Coding: 108D0F214004150047140000001400000008730B5C000100000000000000
Shop #: WSC 02134 444 12533
VCID: 6FBBD6E65B9A2AB3BA1-803A
Component: Wischer 030707 021 0501
Coding: 00038805
Shop #: WSC 02134
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D09475F
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C81C1EA6A8CD1AB9F3-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME1476735EI
Subsystem 3 - Serial number: 6342MSME1B59002FF
Subsystem 4 - Serial number: 6352QSME2C5A3F09X
Subsystem 5 - Serial number: 6362QSME33545609D
Subsystem 6 - Serial number: 63727SME0D4729083
Subsystem 7 - Serial number: 63827SME0D472B211
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksulenmodul 036 0070
Coding: 0000022
VCID: 74B1D98A32BC096B473-8020
Part No SW: 1K0 920 954 F HW: 1K0 920 954 F
Revision: V0002000 Serial number: VWX7Z0G63N68KH
Coding: 0007203
Shop #: WSC 01287 785 00200
VCID: 2F3B16E69B1A6AB3FA1-807A
Reset counter: 158
Mileage: 215457 km
Time: 21:48:23
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 080707F1000102
Coding: 3D8F034007000000
Reset counter: 158
Mileage: 215457 km
Time: 21:48:25
Component: IMMO VDD 1212
Shop #: WSC 18707 002 1048576
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 38292DBA6E54AD0BABB-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3537248E79465063B0D-8060
00625 - Vehicle Speed Signal
Mileage: 215450 km
Temperature: 35.0∞C
Voltage: 13.50 V
Voltage: 13.30 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C80
VCID: 0451894A621C39EB773-8050
Reset counter: 158
Mileage: 215457 km
Time: 21:57:40
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 392F28BE555EB403545-806C
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6261139
Coding: 0040401
VCID: 1F1BE626EBBAFA334A1-804A
Component: RDK 0450
Coding: 0100101
Fault Status: 01111000
Reset counter: 158
Mileage: 215457 km
Time: 21:48:23
End----------(Elapsed Time: 00:57, VBatt start/end: 12.3V/12.3V)-----------
